Old 05-04-2012, 07:04 PM   #1
mrbindc OP
Oddometer: 75
R100GS custom exhaust on a R65?
I have a 1982 R65 and I've been thinking about a 2 into 1 exhaust for it. A custom set up for a R100GS just posted on IBMWR and I was wondering how hard it would be to modify it to fit the R65. I know the exhaust nuts are unique on the R65 and there is a thicker metal exhaust gasket but it seems these challenges could be overcome with enough $$ or am I crazy?
Any thoughts?
mrbindc is offline   Reply With Quote
Old 05-04-2012, 07:07 PM   #2
Beater
Airheaded, eg Simple
Beater's Avatar
Oddometer: 3,247
Originally Posted by mrbindc View Post
I have a 1982 R65 and I've been thinking about a 2 into 1 exhaust for it. A custom set up for a R100GS just posted on IBMWR and I was wondering how hard it would be to modify it to fit the R65. I know the exhaust nuts are unique on the R65 and there is a thicker metal exhaust gasket but it seems these challenge could be overcome with enough $$ or am I crazy?
Any thoughts?
I like crazy. Really I do ... the GS exhaust head is 38mm. The R65 is 36. The length will be a problem too, as the R65 is a 'short wheelbase.
Not impossible ...
Fred
'85 R80RT G/Sified <|> '73 R75/5 LWB
Simply Simple and getting more so.
Beater is online now   Reply With Quote
Old 05-04-2012, 07:12 PM   #3
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,492
The bigger issue that you'll have is that the R65 engine is about 2.5" narrower (shorter stroke) than the R80/100 engine and the exhaust ports are closer together. Headers from the R100GS might just hit the oil pan before you can even fit them into the exhaust ports. I don't know this for sure as I've never tried it, but that's what I would guess.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler is online now   Reply With Quote
Old 05-05-2012, 12:34 AM   #4
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,475
If you use the R65 headers coming out of the heads(about 12" of it), then into the GS header, get rid of the presilencer for a Y pipe and open up the GS muffler a bit you might have a good flowing exhaust.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 05-05-2012, 02:02 PM   #5
mrbindc OP
Oddometer: 75
thanks for the inputs. I like the idea of using the R65 header to make it adapt.
I could modify the header pipe with 6-12" of my R65 header. Once it was welded up and installed I could use exhaust wrap back to the collector to cover up the joint and make it less obvious. I planning to do a mild scrambler build with this bike so the upswept muffler is ideal.
this custom GS exhaust is actually 5 pieces, there are 2 headers, the 2 into 1 collector, and it uses a Supertrapp 10 disk muffler.
Old 05-05-2012, 02:09 PM   #6
Boxer Metal
Mad Scientist
Oddometer: 3,475
Your R65 exhaust will slip right into the GS exhaust. Do more than 6".
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Times are GMT -7.   It's 07:37 PM.
