Old 05-14-2012, 03:56 PM   #1
khale OP
ride dirty
khale's Avatar
Oddometer: 557
Average lifespan of Odyssey PC680 battery in motorcycle
I'm looking to find out what the average lifespan of the Odyssey PC680 is. I have a 1973 r75/5 that doesn't want the battery to stay charged. I'm trying to figure out if my battery needs replacing or I need to dive into the electrical of my bike. The battery is 6 years old. Was put in the bike in 2006.
2013 BMW R1200 GSW | 1972 BMW R75/5 toaster | 2011 Husky TE310
"4 wheels move the body, 2 wheels move the soul"
khale is offline   Reply With Quote
Old 05-14-2012, 04:05 PM   #2
ozmoses
Ride On
ozmoses's Avatar
Oddometer: 4,075
Hopefully much longer than a Westco... yup, I'm gonna be "that guy"!
Cereally, I'm wondering the same thing about the PC680 i recently purchased.
Opinions are like internet connections- everybody has one.
ozmoses is offline   Reply With Quote
Old 05-14-2012, 07:14 PM   #3
Hawk Medicine
Coyote's Brother
Oddometer: 3,304
Forget about the battery until you've taken time to test your charging system for proper operation.
Meanwhile, place the battery on a charger and see it it holds it's charge. Odyssey PC680 have a rep for long life. Westco? None for me thanks...
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Old 05-14-2012, 07:16 PM   #4
khale OP
ride dirty
khale's Avatar
Oddometer: 557
What should I be reading at for certain RPM's on my voltmeter? I imagine around 13.5V and higher correct?
Old 05-14-2012, 08:19 PM   #5
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,548
What he said. Even if it is your battery, 6 years out of a battery isn't bad.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 05-14-2012, 09:15 PM   #6
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,635
I'm reminded of:
Originally Posted by Donkey Hotey View Post
I had an Odyssey catastrophically die when it was under a year old (internallly shorted). If not for riding with somebody who could jumpstart my GS with the battery disconnected, I would have been stranded 9 miles out in the desert.
Then to compound matters, they would not honor the warranty because I bought it on the internet (excuse me, my nearest 'dealer' was 100 miles away). They wouldn't return emails and at the time, wouldn't take phone calls either. I got stuck replacing it on my own (not another Odyssey).
I still have that battery here and someday, I'm going to shove it up somebody's ass at that company. They never have a rep at their display at the Long Beach Motorcycle show--ever (I've been looking for three years now). I've got 14 bikes and they'll never sell me another battery again.
crazydrummerdude is offline   Reply With Quote
Old 05-15-2012, 07:10 AM   #7
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,195
Remove the negative lead from the battery. Set the meter to amps. Attach the positive (red) lead to the battery negative terminal. Attach the negative lead to the cable.
With the ignition off, the meter should read zero.
Switch the meter to milliamps. It should still read zero. If not, find out what is draining the battery.
Old 05-15-2012, 07:26 AM   #8
Biebs
BMW Airhead
Biebs's Avatar
Oddometer: 531
2 simple tests
Assuming you have a volt meter.
1. check battery voltage (after charging) static bike off should be about 12.5 volts. Then wait a couple of hours ( go have coffee or a beer) check again should still be 12.5 volts it it has dropped then bike is drawing power when off or battery is bad. Disconnect battery and repeat above test this will test just the battery.
2. With bike running check voltage at battery should read ~13 volts more as RPM increase if not check bike charging system.
This is a way of isolating the probem to either battery or bike.
I have had a PC680 in my 74 R75/6 for 4 years no problem great battery. Uses half the space as original and I can remove it without dropping subframe.
Only problem is the price of a new one I see they are about $150 now.
Biebs is offline   Reply With Quote
Old 05-15-2012, 10:58 AM   #9
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 1,025
These are "storage" batteries and bigger = more storage.
But, in motorcycles they are small and don't store much.
Your approach should be: if the motor's not running, a battery charger should be attached. This is a fact of life of motorcycle ownership.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Old 05-15-2012, 11:42 AM   #10
alister102
alister102's Avatar
Oddometer: 260
I got 7 years out of my 680-
alister102 is offline   Reply With Quote
Old 05-16-2012, 09:20 AM   #11
boxerkuh
Oddometer: 232
I was going through a simular problems a few years ago.... Here is what I did and found out: I took the battery out and took it to Auto Zone and had it tested. Did not know what the cold cranks were so I told them about maybe 400.... they tested it twice and it came back both times as good. Then I emailed Odyssey to find out some info. They told me that the cold crank is only 220 and if it tested good at 400 twice the battery was as good as new. The battery was 6 years old at the time and I heard about abrupt battery failures... well that was 4 years ago and the battery is still in the bike and is working wonderfully. Odyssey told me that the average life of the battery is anywhere inbetween 7 and 12 years. After some further investigation it turned out that the diode board had a bad ground. It was repaired and no problems since. Hope that helps.
boxerkuh is offline   Reply With Quote
Old 05-16-2012, 10:19 PM   #12
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,690
I killed my 320 at 3 years +
I put chokes on the bike and tidied up the charging system then slotted the 680 back in.
It was 2 years old when I benched it for the 320 and it seems to be holding up well.
Conclusion. you can kill these things but you have to try really hard.
My bike is slow but the earth is patient.
Rucksta is offline   Reply With Quote
Times are GMT -7.   It's 12:06 AM.
