Old 05-15-2012, 09:04 AM   #1
4puf OP
4puf's Avatar
Oddometer: 59
Which Sahara 3 Metzeler for a G/S?
I know this has been discussed before but I wasn't able to see a straight answer.
I want to install the widest tire that would fit on my R80G/S
The Metzeler documentation suggests to install the Rear 4.00-18 which is 118mm wide...
They also have the 120/80-18 which is 123mm wide
and
the 140/80-18 which is 142mm wide
Anyone was able to fit the 140 on this bike? (I have the stock shock and stock rim).
4puf is offline   Reply With Quote
Old 05-15-2012, 09:26 AM   #2
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,569
The 120 will fit with under a 1/4" of space off the swingarm. The 140 won't fit unless you dish your wheel out to the left quite a bit.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 05-15-2012, 09:36 AM   #3
4puf OP
4puf's Avatar
Oddometer: 59
mmm... I don't want to make any changes to my wheel.
Currently I have installed a Michelin Sirac 120/80 and it has a good 1/2" of space to the swingarm I was hoping I could fit something bigger.
Anyone has a suggestion for a tire similar to the Metzeler Sahara (50%-50%) on a 130 size that would fit a G/S?
Old 05-15-2012, 09:52 AM   #4
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,814
look for a tire w/ better mileage,Saharas don't last. .
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 05-15-2012, 09:55 AM   #5
Airhead Wrangler
Adios Mexico
Oddometer: 6,569
I like MEFOs for a 50/50 tire. I haven't tried heidenaus yet though. 120 is really the biggest size that should be fitted to a monolever G/S unless you modify the wheel.
Old 05-15-2012, 10:06 AM   #6
One Less Harley
Oddometer: 4,814
I have Heidenua K60's on my G/S and like them, way better than the Sahara 3's. I'd choose Dunlop 606's or TCK 80's before the Saharas.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 05-15-2012, 11:15 AM   #7
4puf OP
4puf's Avatar
Oddometer: 59
I can't find a Heidenau K60 in 120 size. What size do you have on your G/S?
Old 05-15-2012, 12:56 PM   #8
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,809
The Original fitment tyres for your bike are still available. They were designed for your machine wear well and are very cheap for a pair. You'll also never find better tyres for handling on and off road Metzler Enduros 1 & 2
Rob Farmer is offline   Reply With Quote
Old 05-15-2012, 01:25 PM   #9
4puf OP
4puf's Avatar
Oddometer: 59
[QUOTE=Rob Farmer;18693338]The Original fitment tyres for your bike are still available. They were designed for your machine wear well and are very cheap for a pair. You'll also never find better tyres for handling on and off road Metzler Enduros 1 & 2
You can't find enduro 1 and 2 in the US any longer... :-(
Old 05-15-2012, 04:05 PM   #10
One Less Harley
Oddometer: 4,814
I'm running a 120/90x18 if you have an Ohlins shock the tire may hit the spring. It's close to my YSS spring about 1/4" clearance.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Times are GMT -7.   It's 12:58 AM.
