Old 05-14-2012, 07:14 PM   #1
DiabloADV OP
Semi-Occasional
Oddometer: 2,321
Next bit of advice -- Big Bore or Stock?
I've resolved the next step in my refurbishment of the R90/6 with the bad cylinder. This motor has R90 cylinders, bored out to fit R100 pistons,but with stock R90 heads. I found a nice set of R90 cylinders so I can start over.
So...I could go one of two ways with this. Have the new set of R90 cyl's bored one over, and put new pistons in it. About $750 total cost, sticking with the R90 setup.
Or -- have the R90 cyl's bored to accept the R100 (93.97) pistons that I already have. About $250 total cost. More low-end grunt, which is where I like to ride.
Obviously, I'd like to spend less. But is it a good idea to do that overbore? The machinist is quite experienced with airheads and says he can do it.
I googled the topic and there are some folks who have run 100s with R90 heads. But, the ones I found were cylinder swaps, not big-bore treatments. Can the R90 cylinder be safely bored out that far?
1974 R90/6 motor w/1050 kit; twin plugged; installed in...1970 R60/5 frame; RM125 front end; KZ1000 Police Tank.
DiabloADV is offline   Reply With Quote
Old 05-14-2012, 08:06 PM   #2
bmwrench
Oddometer: 2,181
1000cc pistons in the early R90 cylinder is risky-the oiling groove in the cylinder spigot makes it very thin in that location. It's been done (I've done it myself), but I was not confident that it was a good idea. You can buy a 92mm piston set from a certain independent shop...
bmwrench is offline   Reply With Quote
Old 05-14-2012, 08:17 PM   #3
DiabloADV OP
Semi-Occasional
Oddometer: 2,321
And that shop would be...?
edit...found it.
DiabloADV screwed with this post 05-14-2012 at 08:24 PM
Old 05-15-2012, 02:24 AM   #4
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,571
Go `one` oversize and get the heads twin plugged. When the gearbox has to be done up, fit the 5% higher 5th gear.
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is offline   Reply With Quote
Old 05-15-2012, 03:51 AM   #5
carpetburn
Oddometer: 129
i run 1000cc nikasil jugs with 75/6 heads[twin plugged but otherwise standard] and has run well for 4 years or so, just replaced exhaust valve guides but heads work fine on bigger jugs.
carpetburn is offline   Reply With Quote
Old 05-15-2012, 10:49 AM   #6
DiabloADV OP
Semi-Occasional
Oddometer: 2,321
Higher 5th gear...part number?
My gearbox is getting overhauled in two weeks at a tech day...
Old 05-15-2012, 04:02 PM   #7
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,571
Um....dunno; someone else here will have that info. Do others` think the higher 5th gear will be a good idea on this bike?
David Hunn:
Old 05-15-2012, 04:32 PM   #8
DiabloADV OP
Semi-Occasional
Oddometer: 2,321
It would be a good idea on mine since I have a 37:11 final drive.
Old 05-16-2012, 09:53 AM   #9
sigpe57
Oddometer: 340
Keep it original. I had 2 r80gs that had been converted to 1000cc by PO. Never liked it. More noise and vibration. I found out how balanced a 800cc motor is after I bought 2 more STs. It's perfect balance between r65 and r1000. German engineering like Porsche and Mercedes, keep it stock is the best. Go try a r1100 oil head, u will know how much more vibration with just 100 cc more.
TT
sigpe57 is offline   Reply With Quote
Old 05-16-2012, 10:18 AM   #10
DiabloADV OP
Semi-Occasional
Oddometer: 2,321
Originally Posted by sigpe57 View Post
Keep it original.
I hear you, but original is my most expensive option since I already own the 93.97 pistons. They are known good pistons and I'm reluctant to buy used (and more possible trouble).
I have it on good authority that what the bike came with (97mm-spigot R90's bored to 1000) is problematic on a number of levels. The spigot is too thin, mainly. Plus, the cylinders don't line up with the squish band in the R90 heads.
After a visit with the machinist (veteran airhead guy) yesterday, and after picking up two very nice 99mm-spigot R90/6 cylinders with new SS pushrod tubes, the plan is to...
Bore the case to 99mm. Easy and cheap to do.
Bore the new cylinders to match my nice 93.97 dome-top pistons. New rings and pins (which I needed anyway).
Machine the squish band ring on my nice R90 heads to match the new cylinder diameter. Doing a valve job anyway, so this is simple to do while it's apart.
Run it with the compression-reducing cylinder-case gasket.
This shop work will only run me about $300. Total cost of the repair, over what I had to spend on refurb anyway, is about $400. To change piston size would cost a lot more in parts and only save half the shop costs.
A bonus is that the cylinder and head work include having them fine-grade bead blasted, cleaned and returned to me looking like new.
Times are GMT -7.   It's 09:48 AM.
