05-14-2012, 06:05 PM
#76 |
Aaron S
Oddometer: 6,107
![]() ![]() This is what I used, I'll just have to see how well it holds up:
05-14-2012, 06:20 PM
#77 | |
I'll Go Second...
Oddometer: 3,667
Nice...time for another run through the sandwash..... ...let's test these babies out....
MTS 1200 Pikes Peak....Touring Beast 950SE......Desert Beast 'Berg 570..Trail Beast |
05-14-2012, 07:49 PM
#78 |
Aaron S
Oddometer: 6,107
05-14-2012, 08:17 PM
#79 |
hook-em
Oddometer: 487
Sure wouldn't mind some of these for the stocker tank....
Indecision always goes to the left... '09 BMW R1200GSA '09 KTM 950SER Erz |
05-15-2012, 05:43 AM
#80 |
No neck tie, Ti neck
Oddometer: 572
Carbon performance
05-15-2012, 06:20 AM
#81 |
Oddometer: 1,385
As I started this thread, its only fitting for me to say, as well, PM sent.
![]() ktm950se |
05-15-2012, 07:52 PM
#82 |
Oddometer: 2,200
Get your orders in guys, I want mine!
07 SE PG007 "Up there where you eat moose-cock you must all be rockets scientists." |
05-15-2012, 09:24 PM
#83 |
Oddometer: 366
Totally worth it
If anyone is on the fence about these guards I can assure you that they are made to last. Daryl spent a lot of time a several visits to make sure all the test pieces and molds were correct to ensure a proper quality part. I have several other off the shelf carbon parts and none even come close to these.
05-17-2012, 08:30 AM
#84 |
Oddometer: 493
Got mine and they look great
![]() Now I need to round up some clamps to get them installed.
I heard the North Star saying, kid you're so lost even I can't bring you home. RIP Jason Molina |
05-17-2012, 10:17 AM
#85 | |
Oddometer: 910
just a note.. I had a PM about one side did not quite fit as snug as the other. This could be due to tank swelling or something else. Be cautious not to flex the guards to much on install . It would be better to use a bit more adhesive and allow a slight gap then to have the guard trying to pull itself off the tank. If anyone has any issues please let me know..Your feed back is extremely important to me.
When Quality matters,Its all about choices. Performance LED Vendors thread http://advrider.com/forums/showthread.php?t=839163 www.cyclopsadventuresports.com http://youtu.be/1fmEJO3ftFI |
05-18-2012, 08:05 AM
#86 |
Oddometer: 493
Well I got mine mounted and I think they are going to be great.
On a dry trial fit I found the right side fit very well and the left did not follow the tank as well. Daryl had noted this may be the case in a post above. There are butt loads of posts about Safari tanks not fitting well or deforming when removed,ect, ect....so I'm sure no two are the same. Once the adhesive was applied it fit fine. This is how I did it. ![]() I resisted the urge to spread it out and just left it in globs. My father in law is a wood working hobbiest and has every kind of clamp known to man so I borrowed an assortment before starting and guess what? None of them would work. After some head scratching and a beer or two this is what I came up with. ![]() Cam straps from my white water gear bag. These worked great for holding them in place without flexing them. ![]() ![]() The painters tape was probably not needed but it made me feel better. I'll post up a finished pic when after I get it all back together.
05-18-2012, 12:44 PM
#87 |
Aaron S
Oddometer: 6,107
Damn I wish I had thought of that.
05-18-2012, 01:30 PM
#88 |
Oddometer: 1,385
OK, So what is the recommended silicone to use to mount these?
Is it the Dow Corning 732 shown if this pic, or something else? ![]() I want to have a tube on hand when my guards arrive so I can mount them immediately. ktm950se |
05-19-2012, 07:33 AM
#89 | |
Oddometer: 910
05-19-2012, 07:49 AM
#90 |
More Undestructable
Oddometer: 3,546
Here's how I did it...
Step 1: Find motorcycle.
![]() Step 2: Find where the guard goes. ![]() Step 3: Use RVT adhesive. ![]() Step 4: Use clamps. ![]() Step 5: Wait 24 - 36 hours. ![]() Step 6: Admire how nice the new guards are. ![]() ![]() Thanks Cyclops. Q~
Ride Reports: National Parks Tour 2008 Trans-America Trail 2009 Continental Divide Trail 2009 Alaska 2010 Empty West 2011 Questor screwed with this post 05-20-2012 at 06:11 AM |
