Old 01-14-2012, 05:43 PM   #46
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Nice one, Jdub! It's always good to see a DIY repair thread. Thanks for taking the time.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 02-26-2012, 11:08 AM   #47
StellerBeemer
Oddometer: 6
Excelent Thread
I have just completed replacing the main input shaft seal and clutch assembly on my '05 R1200GS with 54k. using this thread. It went without a hitch! I was seriously overwhelmed at the scope of the project before starting, however, after about an hour into it, I realized that it simply was a series of minor procedures - disconnect shift linkage, side stand switch, rear wiring harness, etc. It was way less daunting after that realization. I was amazed that there were so few bolts in the tray after the split. It took 3.5 hours to get to the clutch and took equally as long to reassemble. The cleaning, however, was super time consuming as gear oil makes a sticky mess.
Thanks for taking the time to create this well illustrated how-to.
StellerBeemer is offline   Reply With Quote
Old 05-18-2012, 02:48 PM   #48
S-curvy
In my dreams....
S-curvy's Avatar
Oddometer: 57
Thoughts on splicing a quick connect into that harness?
Jdub, that is an excellent contribution to the collection. My '05 GS has 16K on the clock and has been leaking erl from the front tranny seal for the last 3K miles. Considering the $1,000 ++ repair quotes I've gotten so far, and the fact that I'm not working much right now, it appears I've got a leetle project staring me in the face. Is this a common leak story? I'll probably go ahead and replace the clutch w/ a Kevlar unit as well -- Any thoughts on these?
I know it's a ballsy proposition, but what's the consensus on solving that persnickety wiring harness exercise by simply splicing in a Molex type (or other appropriate) quick-connect up near the gas tank, as Jdub mentioned? While this does introduce a man-made break in the conductors, BMW and all other mfrs use quick-connects all over the place on the cars, trucks, and motos.
S-curvy is offline   Reply With Quote
Old 05-19-2012, 10:34 AM   #49
Lensgrinder
Oddometer: 1,323
Nice thread jdub, I printed it out and started a notebook.
The only thing that confused me was step 17, maybe a better location discription would be next to the transmission drain plug facing forward. removing it toward the rear of the bike.
I also just removed the nut that holds the gear shift linkage together, didn't remove it from the gear shift shaft.
I also thought about a connector to unplug in order to separate the rear subframe, but there were about twenty wires of different sizes so I just removed the fender liner, it wasn't too bad.
2012 R1200GSA
2009 F650GS (Wife's)
1987 Husqvarna WR 430
Lensgrinder is offline   Reply With Quote
Old 05-21-2012, 09:43 AM   #50
jdub OP
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,846
farmerger's post #27 in this thread has a good picture of the referenced bolt under step 2, which is a great visual aid.
I expect to be going through this process again with my bike probably January 2013ish, hope to be at the 115k-120k mile point by then and looking forward to see what I encounter different from the first time at 68k miles. I figured at that time I'd do a major edit/update on my original post in this thread with more and better pictures and text. For ease of reading/condensing into one area I was thinking of including lots of the other suggestions and tips contributed by others in the thread, so I'll see how that goes.
Thanks again for all of the additional info and feedback everyone.
Current: 2014 R1200GSW
jdub screwed with this post 05-21-2012 at 09:59 AM
jdub is online now   Reply With Quote
Old 05-21-2012, 10:05 AM   #51
Lensgrinder
Oddometer: 1,323
I think that's how I found it.
I was standing there looking at the side of the bike thinking I must be blind to not see it.
Then I stopped, went in the house and read the entire thread again and found it.
Thanks again to all who added their insight. With the combined input the job wasn't so daunting.
Thanks again jdub, great thread.
Richard
2012 R1200GSA
Old 03-17-2013, 07:35 AM   #52
Frani
Frani's Avatar
Oddometer: 26
Very interesting information
Frani - Braine-l'Alleud (next to Waterloo, Belgium)
GS 1200 Adventure (2011) - Garmin Zumo 660 - Tripy II - Coyote - ttps://sites.google.com/site/gsadventure2011/
Frani is offline   Reply With Quote
Old 03-18-2013, 03:14 PM   #53
Eagleavn
EagleAvn
Eagleavn's Avatar
Oddometer: 111
Cool2
Dude you got the wrong bike.....you need a Goldwing, you dont have these kinds of problems.....LOL
The Eagle
1958 Piper Tri-Pacer
2004 Chevrolet Corvette
1985 Honda GoldWing
2008 Honda CRF450X
Eagleavn is offline   Reply With Quote
Old 03-18-2013, 04:32 PM   #54
jdub OP
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,846
The Eagle
This from a guy who sells his GS just so he doesn't have to buy me a bottle of single malt in exchange for my help with his clutch spline lube.
Old 03-18-2013, 04:35 PM   #55
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,377
Jim
Old 04-04-2013, 08:07 AM   #56
Guy Young
Guy Young's Avatar
Oddometer: 8,498
Going this very procedure, but have run into a problem.
Getting really close to separating the frame for a clutch replacement - BUT - I cannot get the front drive shaft splined joint to release from the transmission output shaft.
I've worked on similar bikes before and they've all just popped off with no drama. This one ain't budging.
Have spritzed Kroil in at the joint hoping it might provide a lubrication to the retaining snap ring, but still no go. I've tried a medium screwdriver, a BIG screwdriver, and am now using a small pry bar, but still no movement.
Any ideas are most welcome.
GB Young Services, LLC
Garage Project: http://gbyoung2.smugmug.com/Family/Garage-Project
Guy Young is offline   Reply With Quote
Old 04-04-2013, 08:15 AM   #57
JimVonBaden
"Cool" Aid!
Oddometer: 53,377
Don't forget the bolt from the frame to the motor near the driveshaft just above the swigarm. It doesn't show in the early BMW DVD.
I have a photo at home, but it attaches the frame from a small brackeet to the trans.
Also, I had the driveshaft get slightly cocked and it took significant force to pry it off the end of the trans shaft. It get's caught in the C-clip groove.
When it comes to splitting the trans from the motor, you might find it hard to do. It is the locator pins that have rusted/corroded. You will need to carefully wedge it apart near the locator pins. This is bottom right and top left on the trans.
You can see one of the pins here.
I used a smooth edged flat screwdriver and drove it in with a deadblow hammer with gentle blows. You will see it pulling apart.
Jim
Old 04-04-2013, 08:27 AM   #58
TXjames
High Sider
TXjames's Avatar
Oddometer: 1,091
I had a lot of trouble splitting mine for that very reason. What a PITA. It's very easy to damage the aluminum housing once this has happened so find the strongest purchase you can when splitting a stuck tranny. I think I anti-seized the pins on reassembly but it may not help since the clearance between pin and case is so small.
I hope you replaced that balancer shaft seal JVB. That's nasty. Or is that leaking down from the rear main seal?
Roll The Bones V - No premature incinerations. Oct 24-26, 2014.
http://www.rollthebonesrally.com/
TXjames is offline   Reply With Quote
Old 04-04-2013, 08:34 AM   #59
JimVonBaden
"Cool" Aid!
Oddometer: 53,377
Balancer shaft, and I am waiting parts right now!
You are right on the split. Pay close attention and you can see where the solid parts are, and where to slip in a wedge/screwdriver.
As it sits!
Needed parts.
Jim
Old 04-04-2013, 09:25 AM   #60
jdub OP
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,846
I'm pretty sure when mine is installed w/ the snap ring engaged you can still detect a tiny bit of fore/aft movement of the splined adapter on the gearbox output shaft. I'm sure that's attributable to some tolerances between the snap ring and its groove.
The only reasons I can think of why yours isn't coming off is that the adapter is seized to the shaft by corrosion (especially is there is no fore and aft play at all), or that the snap ring is just really locked into its groove (corroded and/or the snap ring is expanded more than normal and doesn't want to compress and release from the groove).
Maybe try tapping on the rear of the driveshaft with a rubber mallet to break the front adapter loose a bit, and then try prying it off again?
Good luck and let us know the results.
Times are GMT -7.   It's 04:11 AM.
