Old 05-21-2012, 09:07 AM   #16
charlie264
charlie264's Avatar
Oddometer: 8,314
lift the front wheel say 3/4 meter off ground, remove rad cap and let it run to full temp. Top off coolant and put the cap on. Done.
Old 05-21-2012, 09:15 AM   #17
walstibsf
ADVENTURE-HOLIC
walstibsf's Avatar
Oddometer: 212
Mine did too, when new!
My second day on my '10 990 had the same problem when I was a noob to the 990.(still am compared to some of the extensive experience here with OC)!
Check this thread: http://advrider.com/forums/showthread.php?t=720421
Not to worry, thanks to all the help on ADV. Burped her, broke her in. No more temp woes(so far) I still plan on getting a second fan someday.
Good luck and laters......
W A L S T I B........ S F......................
what a long strange trip it's been......SO FAR......
walstibsf is offline   Reply With Quote
Old 05-21-2012, 09:22 AM   #18
killurtv
free range moron
killurtv's Avatar
Oddometer: 640
I had an overheat issue on my 07 990 last year, turned out my thermostat was not functioning therefore no fan turned on. I did the Adventure Machine additional fan and got the thermostat that turns the fans on 20 degrees cooler. No issues since then.
one day I will learn, until that day... fuck it.
2001 HONDA XR650R
killurtv is offline   Reply With Quote
Old 05-21-2012, 11:25 AM   #19
Kelvininin
Kelvininin's Avatar
Oddometer: 187
I have had mine nearly overheat in a warm Seattle day in stop and go traffic. I have since verified the system was bled, installed the second fan and lower temp switch and problem solved.
Riding through snow last weekend, there was no doubt in my mind that my Adventure would have overheated if it were not for the second fan and switch. There was lots of low speed high RPM flogging to work through the snow.
Kelvininin is offline   Reply With Quote
Old 05-21-2012, 05:12 PM   #20
Bowline
Bowline's Avatar
Oddometer: 32
My new 2010 990 (under warranty) overheated on me at least twice in 80F temps and many times came close to overheating. Dealer and mechanic couldn't find anything and told me not to worry and just ride. KTM corporate told me to take the radiator cover off as a solution. I came to the conclusion that I was going to have to battle if I wanted the issue to get it resolved. I've seen threads where fighting something like this turned into a protracted nightmare, full of anger and wasted time. I opted for the more peaceful option and traded the bike with 15 months of warranty remaining. Shame cause I really liked the bike otherwise, but I couldn't enjoy riding while waiting for the other shoe to drop. I hope your luck and resolve lead to better results for you.
Bowline is offline   Reply With Quote
Old 05-21-2012, 05:49 PM   #21
crashmaster
ow, my balls!
crashmaster's Avatar
Oddometer: 5,278
Interesting this issue on the 2010 and up bikes. Is that the year the water pump impeller design changed?
Riding the Americas: No Fumar Español
_____________________________________________
crashmaster is offline   Reply With Quote
Old 05-21-2012, 09:27 PM   #22
The Gobbler
The Gobbler's Avatar
Oddometer: 194
You don't even want to know what the Gobbler is...
Current bike:
2007 KTM 990 Adventure
Past bikes:
2 97 VFR's,
2001 ZX9R,
2004 ZX10 and 3 (yes 3) 2006 ZX10's
2005 Vee
The Gobbler is offline   Reply With Quote
Old 05-22-2012, 07:53 AM   #23
dirtbikebagger OP
dirtbikebagger's Avatar
Oddometer: 89
Originally Posted by Capt.saveaho View Post
Sounds like my brand new 990 might need a bleed. MIne runs hot everywhere, even when it's cold out. I LOVE this bike but there are a lot of quirks that I feel KTM should have taken care of by now, I guess I just have to take care of them myself. Maybe KTM should do the 2 engineers to 1 lawyer meetings and these problems would go away.
Hahahah its like buying a Harley in the 80s. buy it then fix it. Im no beemer guy tho so i bought the KTM becasue i knew i would have to work on it... weird.
dirtbikebagger is offline   Reply With Quote
Old 05-22-2012, 07:55 AM   #24
dirtbikebagger OP
Oddometer: 89
Thats kinda cool that they told you to take that cover off. like they know it impedes flow alot!
Times are GMT -7.   It's 11:21 AM.
