Old 05-18-2012, 08:47 PM   #1
toothy OP
Grin
toothy's Avatar
Oddometer: 14,187
Is my starter failing?
04 R1150GS.
When it's hot, as in I'm at a long traffic light or draw bridge opening and I go to restart it the starter barely works. It'll cycle very slowly.
Is that symptomatic of a failing starter motor?
Thanks.
"Great minds discuss ideas; average minds discuss events; small minds discuss people.
(Eleanor Roosevelt)
toothy is offline   Reply With Quote
Old 05-18-2012, 10:17 PM   #2
Jarvis
DC GSer
Jarvis's Avatar
Oddometer: 10,882
Battery?
Support DC voting rights.
Jarvis is offline   Reply With Quote
Old 05-18-2012, 10:48 PM   #3
toothy OP
Grin
toothy's Avatar
Oddometer: 14,187
Originally Posted by Jarvis View Post
Battery?
It's not an issue when the motor is cold.
(Eleanor Roosevelt)
Old 05-19-2012, 07:55 PM   #4
WoodButcher
WoodButcher's Avatar
Oddometer: 2,108
Yep, sounds like the starter.
Rusty
2009 BMW R1200GS Adventure
WoodButcher is offline   Reply With Quote
Old 05-21-2012, 10:36 AM   #5
Jim Moore
Jim Moore's Avatar
Oddometer: 14,135
Mine always soudns a little "tired" on a hot start. No idea why. It's just enough to make me think, "Wtf?" then it fires up and all is well.
Jim Moore
Jax, FL
Pay the lady, PirateJohn, you thieving piece of garbage.
http://advrider.com/forums/showthread.php?t=949341
Jim Moore is online now   Reply With Quote
Old 05-21-2012, 12:08 PM   #6
99p38a
99p38a's Avatar
Oddometer: 293
Originally Posted by jim moore View Post
mine always soudns a little "tired" on a hot start. No idea why. It's just enough to make me think, "wtf?" then it fires up and all is well.
+1.
Brian
Mid-Michigan, USA
2001 BMW r1150GS
99p38a is offline   Reply With Quote
Old 05-21-2012, 01:34 PM   #7
MeanMoe
one really mean cat
MeanMoe's Avatar
Oddometer: 2,909
Had similar problems with my '01 two years ago. Was going to rebuild it but didn't have the time. A new Valeo starter can be had for less than $200 off eBay.
MeanMoe is offline   Reply With Quote
Old 05-21-2012, 02:03 PM   #8
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,739
Mine fried at work when trying to start, it sounded like it was slow to turn things. I looked down and noticed the wisp of smoke trailing out from under the plastic cover.
I guessed at that point I'd let the smoke out.
The tow truck driver wanted to pull start me with the truck. By the look of him I was certain that movie of that would have hit a million on YouTube.
I opted for the platform tow ride home. Slick inclined oil streaked bed. Overloaded top heavy Adventure bike... What could go wrong.
I didn't drop it, but it was close a couple of times.
And FWIW, don't buy the OEM starter. That thing is not KLR-priced.
If I had known about the Valero I'd have bought it.
Originally Posted by toothy View Post
04 R1150GS.
Thanks.
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head is offline   Reply With Quote
Old 05-21-2012, 03:52 PM   #9
vagueout
vagueout's Avatar
Oddometer: 1,743
They are relatively straightforward to remove, dismantle, clean and lube and of course a good close look inside, especially the magnets. They always operate well after this task.
i just seek clarity
vagueout is offline   Reply With Quote
Old 05-22-2012, 07:51 AM   #10
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,739
On mine the field magnets unglued and locked the armature, this let the smoke out.
...Dick
Smugmug
Old 05-22-2012, 07:54 AM   #11
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,541
What do you folks use to reattach the magnets?
def is online now   Reply With Quote
Old 05-22-2012, 08:02 AM   #12
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,716
use epoxy glue to reattach, or order he new housing for $40 that has updated ( glued and retainer clips) magnets.
http://www.euromotoelectrics.com/pro...6ra-magccw.htm
Smoke em if you got em, and drink your glasses to the bottom...-Will Whitmore
Charter member: T.O. club.
mouthfulloflake is online now   Reply With Quote
Old 05-22-2012, 08:07 AM   #13
ragtoplvr
Oddometer: 6,504
I have had very good luck thinning regular silicone seal with toluene into a thick paint, and reattach the magnet with it. But if any chipping you will lose torque, so the updated housing is best.
Rod
ragtoplvr is offline   Reply With Quote
Old 05-22-2012, 12:18 PM   #14
PNWRR
not fragile
PNWRR's Avatar
Oddometer: 930
Replaced my valeo starter after the magnets loosened and made the starter useless on my '98 GS. Replaced with a starter from these nice folks, a bit pricier than the frog starter, they use nippondenso components.
http://www.motoelekt.com/starter.htm
BTW, if you have lights, fuel pump and can push start the bike, you're probably shunting a lot of current through an 'iffy' starter which tells you it's probably not a battery issue. My .02. Let us know what you find, yellow, right?
Also, here's an inspection procedure: http://www.largiader.com/tech/valeo/
PNWRR screwed with this post 05-22-2012 at 12:29 PM
PNWRR is offline   Reply With Quote
Old 05-23-2012, 06:37 PM   #15
toothy OP
Grin
toothy's Avatar
Oddometer: 14,187
Thank you kind people, I will try taking it off and cleaning it.
(Eleanor Roosevelt)
Times are GMT -7.   It's 09:39 AM.
