05-26-2012, 06:43 AM
#1 |
Oddometer: 22
Have a '99 1000gs. Barely ridden bike and the brakes are locked up... Dirty calipers? Any ideas would help. Thanks
05-26-2012, 07:50 AM
#2 |
SHED (Shit Head)
Oddometer: 224
not familar with the model
1000gs?
05-27-2012, 06:24 AM
#3 | |
Sounds like a case of contaminated brake fluid.
Radar 98 R1100GS AE, 84 R100RS, 00 K1200LT 76 R75/6 (undergoing rebuild) "Insanity is doing the same thing over and over again, but expecting different results" - Albert Einstein |
05-27-2012, 12:03 PM
#4 |
Oddometer: 4,437
rubber hoses are coming apart inside... makes like a check valve, This is fairly common on bikes around Y2K if you still have the original lines. DO NOT bleed the front brakes if you have ABS because it will puke bits of rubber into the power module. This happened to me. get new lines or have them made local. clean & purge all the steel lines. maybe pull the pistons on the ABS & check them too.
05-27-2012, 12:26 PM
#5 | |
Oddometer: 2,704
This aint twitter. Details on your '99. Did you buy it and the brakes locked up? Did you do anything mechanical prior to the brakes locking up? Did you drop the bike and the brakes lock up? First time that they locked up? Has it unlocked on it's own while just sitting over time?
Where will you be when you get where you're going? Terminus Incognito 1999 1100GS 2007 KLR 650 |
05-27-2012, 09:01 PM
#6 |
Which way is north?
Oddometer: 149
stuck calipers
On my 1997 R1100RS I did a caliper rebuild because they were caked in accumulated break dust. However a solid cleaning of the pistons and bores with the seals pulled off (and then installed before assembly or course) would not hurt. I used isopropyl (sp?) alcohol as the cleaner and put everything back together using brake fluid to lubricate. I may give that a try.
Help fund Owen Motoworks Folding Lighbars for the BMW GSs here at indiegogo.com! 2006 V strom. sold 1996 R1100GS
05-28-2012, 03:56 AM
#7 |
Love those blue pipes
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,096
The front brakes started dragging on my 95 and I stripped the calipers to find lots of sediment behind the lower pistons that was not getting flushed out during fluid changes. Cleaning that out seemed to fix things for a while but changing the brake hoses was the thing that eventually cured the problem completely.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100 January 2010 New Zealand South Island ride Summer 2009 UK to Alps ride Summer 2008 UK End-to-End ride |
