Old 04-18-2012, 07:45 PM   #91
BleedbeemR
Oddometer: 55
T/b
ooooppps , fast fingers
BleedbeemR is offline   Reply With Quote
Old 04-19-2012, 01:25 AM   #92
Dan Căta OP
Dan Căta's Avatar
Oddometer: 1,650
I'm glad you got it sorted ;)
Dan.
Dan Căta is offline   Reply With Quote
Old 04-25-2012, 07:59 PM   #93
greginky818
Oddometer: 10
Left and Right for a 2002 1150 gsa please shipped to 42135.
greginky
greginky818 is offline   Reply With Quote
Old 04-26-2012, 02:08 AM   #94
Dan Căta OP
Dan Căta's Avatar
Oddometer: 1,650
PM sent.
Dan.
Old 05-03-2012, 10:35 PM   #95
RuskinRowe
RuskinRowe's Avatar
Oddometer: 31
Kit Is EXELENT!!
So, I ordered my Kit, Recived it about 15-ish days after payment, which included the Easter public holiday weekend.
It was as described and simple to do with the exception of removing the old bushing.
I tried the Heat + Bolt + Copper Wire but it refused to come out. The next day I tried plastic Cable Tie and bolt but still didn't come out.
I priced a M10 Tread cutter to Cut it's way in and remove the old bush but they where a little on the high price side (Not so much though).
Finally I thought about a broken bolt remover. It was $8. Some places call them screw extractors?
ABOVE: Screw Extractor digs into the Bushing and makes it very easy to pull out.
It came out EASY with this and the rest of the job was VERY simple.
Somthing not many people are talking about, and maybe it's obvious, but for any Newby out there wanting to do this, Dont forget you WILL need to Throttle Body Sync afterwards, and if you do the Left side (?) you will need to do the ZERO=ZERO job for the position sensor.
A Big Thanks to Cata Dan for making this fantastic Kit. Much cheaper then paying someone else to rebuild my units.
-Bryan.
RuskinRowe is offline   Reply With Quote
Old 05-04-2012, 02:34 AM   #96
Dan Căta OP
Dan Căta's Avatar
Oddometer: 1,650
Hi Bryan,
Yes, I mentioned before that the best way to remove the old bushings is via an extractor kit. I found out that later, after trying using a screw.
Regarding the 0=0, that should not be necessary unless you alter the stopping screws. The spindles I make are the same as on the bike. If the plate does not rest on the stopping screw, it's most probably because the butterfly plate is not centered perfectly inside the TB.
I'm glad you got yours working fine.
Thanks,
Dan
Old 05-06-2012, 10:01 PM   #97
twinsig
twinsig's Avatar
Oddometer: 187
FYI=TB kit was huge success!
Struggled getting everything right with the zero & sync (noob) but the rebuild went well, also struggled a bit with removing bushings. Large plastic tywrap cut to size to find the sweet spot, its all in a nicely labeled bag now for the next 50k rebuild. Another merit badge!
Thanks Dan, nice work...
2002 1150RT
twinsig is online now   Reply With Quote
Old 05-07-2012, 11:11 AM   #98
walrond
Earth Wanderer
walrond's Avatar
Oddometer: 1,066
I finally bit the bullet and did the rebuild on both TBs. I was nervous because I had the throttle body pulleys with the shafts pressed into them. When I compared the ends of the shafts supplied by Dan I noticed that they were significantly smaller. I shouldn't have worried though because his fit perfectly.
I also used a 4" C Clamp to press the new bushings in. I felt I had more control than using the hammer method.
One word of caution.... I thought I had the butterfly valve in the TPS side TB centered because it open and shut with ease. Once I put the TPS on the TB the butterfly valve no longer would shut. I had to re-center the butterfly valve with the TPS mounted to the TB in order to get the correct orientation.
I now have two good as new TBs and for the first time in 40K miles I was able to have them synced at both idle and at 3500 RPM with ease. A big thank you Dan for coming up with this kit. Here are a few clarification pictures that I took that might help others out.
TB with a pressed in shaft
How to remove the Aluminum Cap
Using a C Clamp to press in the bushing
Save $5 when you open a SmugMug account. Use the following coupon: 7ztkgApOHBurY
walrond screwed with this post 05-07-2012 at 11:33 AM
walrond is offline   Reply With Quote
Old 05-08-2012, 02:40 AM   #99
Dan Căta OP
Dan Căta's Avatar
Oddometer: 1,650
Thanks all for the reviews
Dan.
Old 05-17-2012, 07:24 AM   #100
Crackenback
Oddometer: 34
Left and Right for a 2002 1150 RT please shipped to 39402.
Thanks...
Crackenback is offline   Reply With Quote
Old 05-17-2012, 07:31 AM   #101
Dan Căta OP
Dan Căta's Avatar
Oddometer: 1,650
I have sent you a private message on this.
Thanks,
Dan.
Old 05-18-2012, 04:03 PM   #102
AugustFalcon
AugustFalcon's Avatar
Oddometer: 1,052
Left & Right 2004 R1100SA
Pricing please for a Left and Right for a 2004 R1100SA (VIN is WB10432AX4ZB53238) shipped to 06385-3615.
Thanks...
cheers... jack
04 BMW R1100S
02 KTM 250 Exc Racing
SmugMug referral code: jXF8ohDWlTm56
AugustFalcon is offline   Reply With Quote
Old 05-19-2012, 01:19 AM   #103
Dan Căta OP
Dan Căta's Avatar
Oddometer: 1,650
PM sent to you back ;)
Dan.
Old 05-28-2012, 06:37 AM   #104
ice racer
Oddometer: 1
throttle body repair kit
Can you send info about getting repair kit for r1100rt 2000. Thanks Ice Racer
ice racer is offline   Reply With Quote
Old 05-28-2012, 06:43 AM   #105
Dan Căta OP
Dan Căta's Avatar
Oddometer: 1,650
PM sent.
Dan.
Times are GMT -7.   It's 02:23 PM.
