Old 05-25-2012, 10:41 PM   #811
sorebutt
Oddometer: 1,772
I agree. You should see the rims on my ATV and it is tubeless. That doesn't affect the tube so carry on.
sorebutt is offline   Reply With Quote
Old 05-26-2012, 02:30 AM   #812
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,607
hammer it back in the right position
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road One month to find the rising sun
Loutre is offline   Reply With Quote
Old 05-26-2012, 08:43 AM   #813
malloy
Oddometer: 720
Agree with Itsatdm. It can be repaired with a press or this guy can do it: http://www.motorcycleframeman.com/wheel001.html Meanwhile a tube should work.
F650GS (Build Date 11/11)
malloy is offline   Reply With Quote
Old 05-26-2012, 08:28 PM   #814
ba_
ba_'s Avatar
Oddometer: 2,722
Headlight bulbs
The bulb for the that comes on when the engine is on went out today. looking at the parts fiche it says that there are two identical bulbs on that side. That doesn't seem correct. Can someone help me out?
'09 Triumph Bonneville 50th Anniversary, '14 KTM 690 Enduro R
ba_ is offline   Reply With Quote
Old 05-26-2012, 08:52 PM   #815
Bigolechalupa
Bigolechalupa's Avatar
Oddometer: 149
F650gs low/high seat?
Hey all..........Just wondering. When you buy an F650, do you have the option of picking a "tall" seat? Or do you have to take the low.
Bigolechalupa is offline   Reply With Quote
Old 05-26-2012, 10:08 PM   #816
grndzr0
its Ground Zero
grndzr0's Avatar
Oddometer: 598
You can pic either. The F800 and F658 use the same seat, you can put the high or low on either bike, and the dealer should give you whichever one you want.
The regular height f658 is lower than the F800. You can get a factory lowered F658 as well to make it super low.
Ryan
2010 F800gs (Mine) 2011 F650gs (Wifes)
grndzr0 is offline   Reply With Quote
Old 05-26-2012, 10:10 PM   #817
grndzr0
its Ground Zero
grndzr0's Avatar
Oddometer: 598
The low Beam, which is the larger bulb on the larger side of the headlight assembly, is a H7 bulb, should be available at most automotive / spares stores.
Ryan
Old 05-27-2012, 05:56 AM   #818
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,729
Originally Posted by grndzr0 View Post
A couple days after we were on the trails, I noticed this spot on the 650 twins rim.
What is the best/cheapest course of action?
Ryan
A block of wood and a hammer!
Remove the wheel from bike. Remove the tire from Rim (preferably). Brace the rim over two or three large blocks of wood (beneath it.....stabilized). Then, place a smaller block of wood (like a short piece of 2x4 on end) against the ding and began whacking hard with the hammer. Should be able to get it back close, it won't be exactly perfect.....but doesn't need to be to function properly.
Don't hit the rim directly with the hammer. You will have to hit the block of wood very hard, several times (most likely). I've done this procedure countless times on all kinds of bikes. However, they have all been spoked wheels. Never tried it on one like yours, but can't see why it wouldn't work equally well.
Yes, you will get some scratches on the rim. Get over it. Scratches are battle scars with character. They are better then big dings. Just sayin
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 05-27-2012, 06:01 AM   #819
ba_
ba_'s Avatar
Oddometer: 2,722
Ryan
What is the other bulb that acts like a running light before the engine is running?
Old 05-27-2012, 06:02 AM   #820
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,729
Ryan
Yup....+1. And they usually have several brightness options. I swapped both of my bulbs to a much brighter version and the headlight is producing plenty of light for me now.....where it was rather lousy before (with stock bulbs). About $25 for a pair at O'Reilly's Auto Parts, in my little town.
By the way, this is the easiest bike to change bulbs on I've ever touched in my life. BMW really made a smart design for this. Just unscrew the round black cover on the back of the headlight assembly. Flip down the wire clip and voila!
Easy peasy.....no tools required.
HF
Old 05-27-2012, 08:44 AM   #821
ba_
ba_'s Avatar
Oddometer: 2,722
I went and looked at the bike and now see the two H7 bulbs. Off to the auto parts store
Old 06-01-2012, 07:46 AM   #822
seaswood
seaswood
seaswood's Avatar
Oddometer: 170
Remove wheels
Repalcing tires, Pirelli Scorpion for Anakees.
Manual mentions not to remove grease from axle?
Is there a reccomended grease for axle?
Can one use wheel bearing grease to coat axle with.
The front did seem quite grayish?
Or is it best to do as they say just not remove grease from axle?
I read most of this thread did not see mention.
Tire threads too long to reread.
That Pirelli really did not want to leave that rear wheel.
1200GSA /7/5
seaswood is offline   Reply With Quote
Old 06-02-2012, 07:01 AM   #823
toolbox77
Oddometer: 65
What temp?
Stupid new owner question: what temp do other F800s run at? I'm steady at 4 bars and was just wondering if that's normal. Thanks!
toolbox77 is offline   Reply With Quote
Old 06-02-2012, 09:52 AM   #824
HappyHighwayman
Oddometer: 278
WHat is the crank of the F800GS's cylinders?
HappyHighwayman is offline   Reply With Quote
Old 06-02-2012, 10:13 AM   #825
epicxcrider
epicxcrider's Avatar
Oddometer: 645
Always at the bottom line - what kind of conditions are you riding in? Much mud? Might gently wash the rad with a hose - being cautious not to bend fins.
Times are GMT -7.   It's 12:24 AM.
