06-02-2012, 08:52 AM
#826 |
Oddometer: 274
WHat is the crank of the F800GS's cylinders?
06-02-2012, 09:13 AM
#827 |
Oddometer: 598
Always at the bottom line - what kind of conditions are you riding in? Much mud? Might gently wash the rad with a hose - being cautious not to bend fins.
06-02-2012, 09:14 AM
#828 | |
Oddometer: 598
06-02-2012, 10:10 AM
#829 |
NoMoTDM still Gary
Oddometer: 3,761
Not sure what the question is. Crank is usually means crankshaft, the thingy the pistons connect to via connecting rods. If referring to the direction it turns, counter clockwise. If you mean type, it is referred to as a 360 degree type. On most vertical twins, it means both pistons rise and fall at the same time, but only 1 is on the power stroke. The engine has 1 power stroke on every 360 degrees of crank rotation.
If this question is referring to the change Husqvarna made to this engine, I posted. They changed the crank throws, so instead of 1 power stroke every 360 degrees of crank rotation, the power stroke occurs at 315 and 405 degrees. I hope your answer is in there somewhere.
BMW Motorrad USA customer service: "We make superior motorcycles and continue to improve them." |
06-02-2012, 10:40 AM
#830 | |
Oddometer: 217
06-02-2012, 11:12 AM
#831 |
NoMoTDM still Gary
Oddometer: 3,761
Because it sounds cool.
The theory behind it, is the further the power strokes are apart, the less wheel spin or at least the better the rider can control wheel spin. Must be some merit to it, as Yamaha introduced it in their 4 cyl. GP bikes in 2005 and HD still wins races on National dirt ovals with an antique engine. The new Yamaha Tenere 1200 uses it on their current twin and have been using it on the TDM for years. There are limits. In the 1920's some vertical twins ran 180 degree cranks. I piston up and the other down. Results in a firing order of 180-540. It also induces side to side vibrations so bad, it would shake the bike apart. V twins all have it. What the firing order will be depends depends on what angle the cylinders are to one another. Ktm's 950 cylinders are 75 degrees apart and the crank rotation is 285-435 degrees. If you own a 800xc with 240/240/240 crank, it is all BS.
06-02-2012, 12:04 PM
#832 | |
Oddometer: 274
06-02-2012, 12:57 PM
#833 |
Oddometer: 62
Paved and dirt roads mostly, but it's been running at 4 bars since the day it left the dealer. Is that more or less than where anyone else is?
06-02-2012, 01:03 PM
#834 |
House Ape
Oddometer: 2,178
Yes, that's where it should be under normal conditions. Mine occasionally shows only three bars when I'm riding in very cold weather. But after 42,000 miles I can probably count those instances on one hand. Four bars is normal.
David I'm tryin' ta think, but nuttin' happens! --Curly |
06-02-2012, 01:23 PM
#835 |
Oddometer: 62
06-02-2012, 02:08 PM
#836 | |
NoMoTDM still Gary
Oddometer: 3,761
It takes two rotations of the crankshaft (720 degrees) to go through all 4 cycles of a 4 stroke motor(Intake,compression,power,exhaust). When 1 piston is in the Compression stroke(TDC) , the other is finishing the exhaust stroke. The only other option for a vertical twin and still be called a 360 would be if both were on the compression stroke. A Twingle. The same as a single cylinder engine only in duplicate. It is the position the pistons are in relation to the bore that makes the determination of a 360 engine. The opposed piston BMW is a 360, because both pistons are at TDC at the same time, they too are on different strokes.
BMW Motorrad USA customer service: "We make superior motorcycles and continue to improve them." itsatdm screwed with this post 06-02-2012 at 02:55 PM |
06-02-2012, 07:02 PM
#837 |
Oddometer: 3,482
06-02-2012, 08:44 PM
#838 |
its Ground Zero
Oddometer: 574
The dipstick on my wifes 650 twin has warped badly, has this happened to anybody?
I noticed it a while ago, but it has slowly gotten worse... Ryan
XOVERLAND.COM Our vendor thread HERE Season 1 Done!! HERE 6 Full Episodes Free on our website!!! If you like it, "Like" us on FaceBook 2010 F800gs (Mine) 2011 F650gs (Wifes) |
06-03-2012, 05:47 AM
#839 | |
Oddometer: 3,482
I've been tracking the "twins" for about 4 years now and yours is the first I've hear of...........
06-03-2012, 11:58 AM
#840 | |
its Ground Zero
Oddometer: 574
