Old 06-04-2012, 04:34 PM   #1
Bloodweiser OP
honestly
Bloodweiser's Avatar
Oddometer: 2,618
RD400 Pistons - WTF
So after concentrating on my bottom end which has been like forever,
I finally broke out dial gauge and crap to figure out what to do about my pistons.
1 looks great, 1 had a seizure at some point but was free when I got it.
Anyhow, I can't believe it took me so long to notice this:
I've got 2 different pistons!
And different sizes to boot!
The one on the left measures 2.545ish, which an estimate on that thousandths digit. It has 383 stamped on the inside wrist pin boss.
The one on the right measures 2.55 dead. Numbered 458 on the inside wrist pin boss. (I think anyway, that 4 is a little sloppy).
I'm thrown off on several fronts.
The difference between the 2 is not .25mm which relates to available piston sizes, but almost half of that. WTF?
Is/was this common practice to just bore 1 cyl? Is that even what happened?
I mean, I reckon to get a set of 65.00mm pistons and bore them both just so they match.
Would still like to hear if anyone has a clue what's going on here
Bloodweiser is offline   Reply With Quote
Old 06-04-2012, 04:47 PM   #2
wfopete
Suffer Fools; Gladly!
wfopete's Avatar
Oddometer: 489
What you have there is a 1st Generation Yamaha power valve!
A collectors item fer' sure, don't change it!
I believe that was the set up Kenny Roberts was going to run before they talked him into riding the TZ750 Flat tracker.
Or someone was really hard up for parts when they put that motor together.
Suffer Fools; Gladly!....
RIDING the TAT? CHECK IT OUT: TAT SHAK
ARA - Adventure Riders of Arkansas
wfopete is offline   Reply With Quote
Old 06-05-2012, 04:47 PM   #3
tripodtiger
I used to be SCRay
tripodtiger's Avatar
Oddometer: 4,728
Where is the rest of your story?
One of the first things I found when I started cleaning the oily, dirty, spider infested parts resting in a plastic ice cream container was a piston with the skirt broken off.
I left it at that point for a few months. Bit scared what else I may find.
Anyway, I'm getting back into it. The frame, swing arm and steering head are done. I've bought a set of period looking new shocks and am waiting on bearings etc so I can put the first few pieces together. Nothing terribly exciting at this stage.
So, long way of saying, I want to read what you've done, what you had to change and what you've learnt.....
rayb Crash Dummy (no testing involved)
Old 06-05-2012, 05:00 PM   #4
Bloodweiser OP
honestly
Oddometer: 2,618
^Check out my sig, Bulletproof vs. bloodweiser.
Once I get this top end settled, it shouldn't be long before we have a runner
Old 06-05-2012, 05:31 PM   #5
backroadbob.com
Roads Scholar
backroadbob.com's Avatar
Oddometer: 264
RD Pistons
No it's not common practice, but there's no reason to redo a cylinder thats OK.
You may have pistons for two different models or someone modified a stock piston for higher performance.
That was common practice. The scored piston is exactly how we used to cut them in the 70s on racebikes. The numbers may be piston weights. What year is it? Was it raced?
New Motorcycle Adventure Website <www.backroadbob.com> Featuring a Four-Decade Distillation of Motorcycling in 38 American States, Five Canadian Provinces, Five National Forests, Ten Pennsylvania State Forests, and Eight Foreign Countries.http://www.backroadbob.com
backroadbob.com is offline   Reply With Quote
Old 06-05-2012, 06:45 PM   #6
Bloodweiser OP
honestly
Oddometer: 2,618
It's a 76. I doubt it was ever raced. Bought it off the original owner who seemed very reserved. Bike was stock anyhow.
Are you saying to keep the good piston and just replace the scored one? The cyl looks just like that piston.
Old 06-05-2012, 07:23 PM   #7
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,699
Seeing how your aim was to do it as cheap as possible... why not do the bad cylinder .25 over and RTF
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is online now   Reply With Quote
Old 06-06-2012, 05:18 AM   #8
Bloodweiser OP
honestly
Oddometer: 2,618
Wouldn't that throw the balance off?
I'm into doing things cheap,
But not sloppy.
Already put $590 into the crank,
Would feel silly trying to save $100 that way.
Old 06-06-2012, 07:38 AM   #9
FloridaSteve
FloridaSteve's Avatar
Oddometer: 2,082
If you've gone through the trouble and expense of redbuilding the crank it would be foolish to skimp on the top end. Get a matched set of ART's or Pro-X pistons in there and have it bored correctly. With conservative jetting and todays oils you'll be set for a lot of miles.
2 cents.
FloridaSteve is offline   Reply With Quote
Old 06-06-2012, 08:05 AM   #10
Bloodweiser OP
honestly
Oddometer: 2,618
That's how I feel Steve.
I just really don't understand the discrepancy between the diameters of the 2 pistons.
They only come in .25 mm sizes,
So how does one only measure half that?
Could it be a difference between forged or cast?
I thought I remember that the expansion rates are different and maybe the come in weird sizes to compensate?
Old 06-06-2012, 08:24 AM   #11
FloridaSteve
Oddometer: 2,082
I have no idea what the piston on the left is. There could be a lot of reasons for the slight differences in sizes though including slight differences in manufacturing. Forge vs cast etc. Looks like someone just made something they had work in a pinch after a seizure. I've seen some wildly mismatched bores and piston on some old 350's and 400's that ran just fine. I even pulled apart an old H1 triple that had 3 different size bores. You just never know. People will sometimes just keep seizing one side without ever really getting to the source of the problem (often an air leak) and keep boring that side larger.
With that crank rebuilt it looks like you're on your way to a smooth running ride. Keep em coming.
Old 06-07-2012, 07:35 AM   #12
Shocktower
Shocktower's Avatar
Oddometer: 9,485
Dead on , get a fresh topend since you have already done the crank JMHO
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower is offline   Reply With Quote
Times are GMT -7.   It's 09:30 PM.
