Old 06-01-2012, 02:43 PM   #31
LukasM
Oddometer: 5,386
Originally Posted by Foot dragger View Post
75 HP,out of a dual purpose single? At the rear wheel? What might be required to have this happen?
Curious.
Trust me man, you don't want to go there.
75 RWHP is 25% more power than the '12 690cc version makes (67 at the crank, about 60 at the wheel), and more than the 710cc Factory Team Rally bike as well.
You would need the 84.5mm stroke crank (all '12 690 or earlier Duke R), a big bore kit with custom cast reinforced cylinder (108mm bore), head work and high flow valves, bigger cam, bigger injector and custom tune, bigger throttle body, free flowing air box and a dual exhaust system.
This graph shows PS at the crank, yellow is with exhaust noise inserts, black without.
Don't forget that you will need a stronger clutch to actually be able to put the power down. The complete 690 Rally clutch assembly will work, but the cover alone is about €1000, let alone new basket, pressure plate, discs, etc...
A cheaper alternative is the spacer to use the stock LC4 cover and the billet pressure plate made by Engine Art in Germany.
Old 06-02-2012, 09:38 PM   #32
LanceSA
LanceSA's Avatar
Oddometer: 80
I've had my 2012 for just over a month now. Done about 2000 km including one long weekend trip.
Apparently there is not an Acrapovic exhaust for it currently. I took my spare Akra left over from my 2 into 1 conversion on the 950 se and fitted that and a Rally Raid foam air filter. It was ok with just the occasion cough and die.
Then my dealer changed the mapping and everything went south. Constant stalling. The foam air filter was very exposed as I have installed thE RR tanks without the screen so I went back to the standard air filter and mapping with the Akra (can't stand the heat & sound of the std pipe) and alls good.
Loving the bike
Ktm 690, Wr 450f, Kdx200
Honda XR125L - wife & son
Pw 80 - other son
Never argue, never justify, never defend
LanceSA is offline   Reply With Quote
Old 06-03-2012, 04:35 AM   #33
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,126
Loving the bike
I have a stock 12. I've ridden about 1200 km including a 6 hour dual sport ride with a group. I haven't noticed any unique heat at the muffler. After you get the thing up to temperature all mufflers are hot, including the Akro systems on my other bikes. The only place I noticed the heat on this one is when I was wearing shorts and sandals while riding across town last weekend to install my Scott's stabilizer at my son's shop. Unprotected left leg is not a good idea. That left side header system will cook your ankle!
In any event, mine runs perfectly as a stocker. Idles and fuels through the range like a well-tuned motorcycle should. Never a stumble anywhere or a delayed start. Instant fire with just a touch on the starter button and no throttle. Still a little vibey in the mid 60mph range, though. Hopefully smoothes out with more km.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 06-03-2012, 09:28 PM   #34
okanoganJim
Oddometer: 6
I am right there with you. My muffler is hot, but nothing unusual. the turn signal is not showing any signs of melting. Thinking maybe they richened up the mixture a bit on the 2012 bikes. So far the bike runs perfectly. I am not seeking more power that is for sure. My only complaint is its a bit jerky on slow fist gear trails. I tried the Soft power setting for tight single track riding, that seems to smooth things out a bit, but still the bike does not feel in its element with slow going. My focus now with the bike is adding some small carrying capacity so I can bring tools, water, and tire patch items with me while exploring about. Ya Hoo !
okanoganJim is offline   Reply With Quote
Old 06-05-2012, 11:49 AM   #35
modeselector
Common as muck
modeselector's Avatar
Oddometer: 624
Originally Posted by edra View Post
2012 enduro R is a good bike but it has some issues those being
- bad tank bolts
- radiator fan shroud and blades wearing into radiator quickly
- leaking coolant on metal pump face thingo
- stalling at idle at lights,ecu fuel tuning etc
- polycarbonate sub frame ?
- rubber fuel or coolant? hose needs to be zip tied to frame to avoid wear
Anyone have or addressed the above issues with their 2012?
Excuse my silly question - but where/how does one get the Akra update?
modeselector is offline   Reply With Quote
Old 06-05-2012, 05:24 PM   #36
ramjet
ramjet's Avatar
Oddometer: 2,132
According to my dealer today-nothing available for the Akra on a 2012.
Coffee first. Then your mundane socialist bullshit.. Lenny Bruce
ramjet is offline   Reply With Quote
Old 06-05-2012, 06:01 PM   #37
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,494
Thinking about adding a FMF pipe just to have something a little cooler running. Notice on my friends 2011 that the FMF and tune make a difference, better throttle response for sure, not huge difference but noticeable and improved over a stock 2012. I'll wait a bit on the pipe as there are other bits to add first and there certainly isn't a lack of power in it's stock form.
CanadianX is offline   Reply With Quote
Old 06-07-2012, 10:59 PM   #38
modeselector
Common as muck
Oddometer: 624
After much time searching/reading went with the Wings - any issues and I will report back but hope no map update needed, we will see.
Old 06-08-2012, 04:27 AM   #39
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,126
I am struggling with where to put my tools/spares as well. For now I am using the KTM flip-off rear tail bag. It has the tool kit now, but plan to add an elec pump, Motion-Pro spoons, patch kit, portable jack stand and a few other extra's and spare levers. Prolly a tube too. I use the KTM tank bag up front. It's pretty big so I can use that for travel stuff.
I have a Wolfman rack and saddlebag system, but haven't mounted it yet. I imagine I could modify that to take a tool kit somewhere and the jack stand too.
Old 06-08-2012, 06:27 AM   #40
Oldbear
Don't want a pickle
Oddometer: 217
Just a quick update: after 1 600 miles the rear shock is busted again
First rebuild was at 400 miles.
Oldbear is offline   Reply With Quote
Old 06-08-2012, 08:09 AM   #41
Maurizio
2 smoker
Maurizio's Avatar
Oddometer: 163
Have a look here:
http://www.tomhamburg.net/KTM_Tune_list.html
maurizio
'14 250 EXC E "Sparkling Orange"
'08 FLHCTUSE3 - '76 CB 750 F ss
sold: '03 950 adv s, '05 450 exc, '08 690 e
Maurizio is offline   Reply With Quote
Old 06-08-2012, 09:21 AM   #42
Maxacceleration
Awol
Maxacceleration's Avatar
Oddometer: 2,190
My experience is coming along nicely.
My wacked out speed ended up being a fault wheel sensor. Swapped one out off of a demo bike.
Speedo works as it should, Yay!
With the RR air filter and FMF Q4 Ti slip-on my bike ran stellar with the stock map.
I am not sure what KTM is calling the performance map for the 2012 bike.
I hear 'Akro' map or 'off-road' map, both used terminology wise.
With the performance map my bike runs good when on the gas. But it stalls repeatedly on warm up, and occasionally at traffic stops. There are 'dead spots' off idle too.
I am going to put another week on the performance map, evaluate it, and then possibly try the stock map again. Off idle stalling is not good.
I may settle for the map that stalls less off of idle.
My dealer has a dyno and I have thought of dynoing it but I get into a lot of expense running each map on the dyno.
Does anyone have a dyno comparison between the stock map & performance map?
I suspect that would be telling.
Likewise. I want to get fueling closer before I go adventuring.
Maxacceleration is offline   Reply With Quote
Old 06-08-2012, 09:24 AM   #43
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,611
Originally Posted by kmann51 View Post
I too was excited about the NEW improved 690 enduro. Picked it up Tuesday and didn't have an opportunity to give it a shake down until today. It started stumbling and it seemed ready to die so I pulled over and then it did stall. Long story short, I got it home and the blinking F1 light indicates it's a fuel pump issue. 4 longs and 1 short was the code. I'll take it in Tuesday and I'm pissed off enough to ask for my money back. I'm accustomed to Honda, BMW and Ducati reliability. It's been 10-15 years since my last KTM and obviously those were carburated.
wow that's what I call bad luck! did you finally keep it?
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road One month to find the rising sun
Loutre is offline   Reply With Quote
Old 06-09-2012, 10:40 AM   #44
modeselector
Common as muck
Oddometer: 624
Sent you a PM
Old 06-29-2012, 10:44 AM   #45
wsmc831
wsmc831's Avatar
Oddometer: 706
Anyone used the 2012 SMC-R with Akra map on this? Friend just picked up a 12 and as i have the cable wants to drop a better map on, but is a bit hesitant. Done a bit of research and looks good, just wondering....
97 TL1000S
2010 690 EnduroR
2013 500 Exc
wsmc831 is offline   Reply With Quote
Times are GMT -7.   It's 06:47 AM.
