Old 06-06-2012, 12:44 PM   #1
DiabloADV OP
Semi-Occasional
Oddometer: 2,277
Airhead battery
What is the smallest battery that will reliably start an R90/6 that has a solid charging system? I mean physically smallest. Don't care about weight. Just dimensions.
On that note, has there been any consensus about the Li-iron batteries?
1974 R90/6 w/1050 kit. Motor only. Seeking a frame.
1970 R60/5
'91 Bill Holland Steel w/Dura Ace
'01 Z3 3.0 Coupe. The Clownshoe.
DiabloADV is offline   Reply With Quote
Old 06-07-2012, 10:32 PM   #2
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,682
I killed a 7amp Odyssey AGM in years running a valeo started.
I'll try Lithium next.
It will have to be more than 7 amp equivalent
Some of the Li batteries have a maximum charge rate at a significantly lower
value than the output of a std airhead alternator.
Make sure yours are up to the job from your enhanced alternator.
I think failure to do this is where the exploding Li battery stories originate.
As for consensus - no idea
There is a thread either here or in garage where a guy is testing different battery types.
Might pay to have a look for a wide sample of opinions
My bike is slow but the earth is patient.
Rucksta is offline   Reply With Quote
Old 06-08-2012, 09:20 AM   #3
bikecat
bikecat's Avatar
Oddometer: 1,115
There is a link on ADV about a guy testing shorai on R80G/S.
bikecat is offline   Reply With Quote
Old 06-08-2012, 11:27 AM   #4
yaktackler
Oddometer: 14
Shorai battery install
I put one of these shorai batteries ( http://www.shoraipower.com/p-152-lfx14a2-bs12.aspx) in my 90/6 about 2 months ago and It has been a champ. It is tiny. I wanted one to fit under the seat. I was worried about the cranking power but it has been perfect.
yaktackler is offline   Reply With Quote
Old 06-08-2012, 11:33 AM   #5
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,478
For a standard lead acid or AGM battery I wouldn't use anything less than a 17 amp hour battery.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 06-08-2012, 12:40 PM   #6
DiabloADV OP
Semi-Occasional
Oddometer: 2,277
That's good to know. Isn't the stock recommended battery 30 Ah?
1970 R60/5
Old 06-08-2012, 12:42 PM   #7
Boxer Metal
Mad Scientist
Oddometer: 3,478
Correct, but R65, /5 and some K75 models used a 18-20 AH battery stock from BMW.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 06-08-2012, 03:47 PM   #8
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,364
I looked at the Shorai battery at a dealer's parts counter this past Spring. It was $300. I didn't get it.
---Albert Einstein
Old 06-08-2012, 04:02 PM   #9
DiabloADV OP
Semi-Occasional
Oddometer: 2,277
I don't think I need to go the Shorai route to do what I want. I just want to squeeze a battery into a smaller space, maybe under the gearbox.
1970 R60/5
Old 06-08-2012, 04:07 PM   #10
yaktackler
Oddometer: 14
Ended up paying $151.95 (with shipping) from atbatt.com - service was good - They said I could return it for 30 days if it didn't work correctly. I was concerned about the ability to turn over the motor and was planning on going to the next size up if I needed to. Didn't need to.
Times are GMT -7.   It's 09:30 PM.
