Old 05-18-2012, 10:43 AM   #121
sagedrifter
Southern Explorer
sagedrifter's Avatar
Oddometer: 1,410
Originally Posted by Ride-til-sore! View Post
I am trying to have more lights on for safety on my DR. My old XT225 had the front turn signal lights on all the time along with the head light. How would i go about making that happen on my DR? Would I have to put on new turn signal light sockets?
Look here: http://dr650.zenseeker.net/SignalLights.htm
Scroll to the bottom and you'll find the directions for turning the signals into running lights/turn signals.....
I would think seperate running lights on the rear tied into the brake light is far more pratical and easy to do though.
Like a Whelen TIR6 or some other plug and play deal for bikes. The stock lamps aren't worth messing with really, just some thing to tinker with for some. Lots of ideas on that zenseeker page.
I might add a brite rear stop light one day.
sagedrifter is online now   Reply With Quote
Old 05-20-2012, 04:42 PM   #122
Ride-til-sore!
still 20 in-my-mind
Ride-til-sore!'s Avatar
Oddometer: 380
Thanks for the feed back guys. Great info sagedrifter!
Ride-til-sore! is offline   Reply With Quote
Old 06-10-2012, 02:32 PM   #123
greener556
Oddometer: 112
Originally Posted by ER70S-2 View Post
There's a black plug with a brown and a black/white wire over the headlight. It's used for the tach light, which we don't have, and it's switched.
Has anyone used this for a 12v outlet - phone charger?
greener556 is offline   Reply With Quote
Old 06-10-2012, 06:49 PM   #124
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,109
Almost everyone
NordieBoy is offline   Reply With Quote
Old 06-10-2012, 07:02 PM   #125
greener556
Oddometer: 112
Originally Posted by NordieBoy View Post
Almost everyone
No problems with blowing fuses or anything?
Old 06-11-2012, 03:52 AM   #126
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,109
People have been using it for heated vests. A gps/phone is no problem.
DR650 Wiki
Old 06-11-2012, 09:17 AM   #127
sasha_j
full time RV'er
sasha_j's Avatar
Oddometer: 91
Thanks for the tip on the " black plug with a brown and a black/white wire over the headlight". I used it for a 12V powerlet for my GPS. Been working great for a while now.
Different issue: Couple days ago, my horn gave it's last beep....worked normal, then dying sound, then nothing....
Before I check for 12V there and buy a replacement, I gotta ask if this happened to anyone else, horn just dying out of the blue @ 18,000 miles?
Sage Green 2014 Ural Gear Up expertly dialed in by UNIQUE RIDES in Fort Collins, Colorado
http://www.laura-n-sasha.com/
sasha_j screwed with this post 06-11-2012 at 11:13 AM Reason: spelling
sasha_j is offline   Reply With Quote
Old 06-11-2012, 09:33 AM   #128
sagedrifter
Southern Explorer
Oddometer: 1,410
Originally Posted by sasha_j View Post
Thanks for the tip on the " black plug with a brown and a black/white wire over the headlight". I used it for a 12V poweret for my GPS. Been working great for a while now.
Yeah, they don't last long. Especially if you ride in the rain and freezing weather will get the wet ones quick. Mine quit around 8K, I replaced it at 12K or so...
Needed it for the DOT inspection. I just used a regular one from the local auto parts store. High tone was my choice, about $9 to $20 depending on the model. I think the cheap ones work best and draw less power. TPI probably has one for motorcycles, they had a chrome one last time I looked.
My fiam one has lasted much better than the stocker.
Old 07-15-2012, 11:38 AM   #129
eakins
Butler Maps
eakins's Avatar
Oddometer: 17,521
weak starting? part of the issue is an undersized battery cable.
tpi has a cable upgrade kit.
http://www.tpimotorcycleparts.com/in...category_id=69
Alaska
AZ map COBDR AZBDR IDBDR South East map
Butler Maps website:
http://www.butlermaps.com
Old 07-15-2012, 12:18 PM   #130
sandwash
sandwash's Avatar
Oddometer: 1,223
Watch out for auto horn's they take amps to work.You will fry the horn button(contacts),wire a relay for it and you will be safe
97dr650
sandwash is online now   Reply With Quote
Old 10-17-2012, 06:36 PM   #131
eakins
Butler Maps
eakins's Avatar
Oddometer: 17,521
http://www.motobattbatteries.com/rev...uct/list/id/3/
motobatt for $8 and 40 more CCA.
it's chinese vrs US made on the Deka if that matters to ya.
Originally Posted by eakins View Post
even better price on the same awesome Deka AGM battery.
$60 shipped. for that price no reason try use any other battery!
http://www.tristatebattery.com/produ...roducts_id=973
Alaska
Old 10-18-2012, 04:21 AM   #132
greer
Oddometer: 3,637
A bit pricier, but if you need it right now, O'Reilly's carries the Deka. Might be rebadged as the SuperStart ETX9.
Sarah
'08 DR650; '06 XL883 Standard
greer is offline   Reply With Quote
Old 10-18-2012, 07:05 PM   #133
Kommando
Grumpy Young Man
Kommando's Avatar
Oddometer: 6,712
To use front signals as marker lights, you can buy dual-filament sockets to fit your signals. NAPA usually can get a pretty wide selection of this stuff. You could also buy dual-filament signals. I bought some stock-looking dual-filament signals on Ebay, got some CycleGear adapters to connect the flasher filament wires (w/bullet connectors) to the stock wiring harness, and spliced the marker filament wire into the tail-light circuit. My tail/brake bulb and my signal bulbs are LEDs, so I don't worry about over-taxing the circuit. I also don't worry about overheating the signal housings, as LEDs stay much cooler than incandescent bulbs. I can also turn the engine off, turn the ignition to the "Park" position, and leave the bike lit up on the side of a dark road for a considerable time without killing the battery.
If using LED bulbs in stock-type housings, get some rated for around 1W or better. The lesser LED bulbs are not very bright.
You could also get some amber LED strips from Autozone/Advance/Pepboys/etc., and stick them on your handguards. Again, wire them into your tail-light circuit and they will work in the "Park" ignition position. I'd also use an LED tail/brake bulb, so you don't over-tax the tail circuit. The stock 1157 tail/brake bulb is about a 3W/23W bulb, so a 1W/3W tail/brake LED, and 1W (x2) marker lights will be similar to stock wattage requirements on the tail circuit. You'll actually use approx. 20W less than stock when sitting at a stoplight with the brake lit. My LED brake bulb also flashes 3x before going solid.
LED bulbs like this are available all over the web. I got mine from www.superbrightleds.com.
Kommando is offline   Reply With Quote
Old 12-10-2012, 05:04 PM   #134
Cobain
night owl
Cobain's Avatar
Oddometer: 132
Just a couple Hella 700ff's with custom mount. $80 total. Added a $4 switch to turn them off in the day.
Cobain is offline   Reply With Quote
Old 12-31-2012, 10:02 AM   #135
ER70S-2
ER70S-2's Avatar
Oddometer: 5,108
Unused connectors are circled in red. For instance: tach light, throttle position switch, headlight flash, NSU optional circuitry, etc.
Edit: Uhoh, I wonder where someone else's photo went?
nmerrill at DRRiders has added color. Check out the green arrows, he's even added useful notes.
2004 DR650: 60,933 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 screwed with this post Yesterday at 05:23 PM
ER70S-2 is offline   Reply With Quote
Times are GMT -7.   It's 07:02 AM.
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
