Old 06-22-2012, 01:50 PM   #16
Dan-M
Dan-M's Avatar
Oddometer: 988
Originally Posted by JimVonBaden View Post
Old thread. IMHO get a Fuzeblock.
www.cyclenutz.com
Jim
+1
Compact, nicely made unit.
Dan-M is offline   Reply With Quote
Old 06-22-2012, 04:06 PM   #17
El Gato
El Gato's Avatar
Oddometer: 696
www.cyclenutz.com
Jim
Another option would the be the Eastern Beaver PC-8. I'm not crazy about how the Fuzeblock uses screw terminals for the input power and ground leads. The PC-8 also has an external relay, 8 outputs vs 6 on the Fuzeblock, and a max capacity of up to 50A. Just my $0.02.
El Gato is offline   Reply With Quote
Old 06-22-2012, 05:03 PM   #18
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,309
It really depends on what you are planning to use it for, and your relative skill level. The PC8 takes more room, and has more complicated wiring. The Fuzeblock is compact, easy to wire, and well known as reliable.
An external relay is not necessarily a plus, unless you tend to heavily load your fuse box. The screw terminals have not proven to be an issue so far, at least in the last several years.
Jim
Old 12-27-2012, 04:25 PM   #19
Reislust
Still alive
Reislust's Avatar
Oddometer: 106
2006 1200GS Blue Sea 2025 install
Decided to post a few pics of my Blue Sea 5025 2006 1200GS install. I wanted a completely removable bracket that would not require any screw holes and left room below for relays as well as minimal clearance from seat. I have no need for the laughable GS tool kit so utilized that space.
bracket is .063 aluminum
Holes tapped to prevent screws hanging down below.
Fits like a glove and took about 30 minutes to fab.
Will be adding some tie down anchors for cleanliness sake prior to install in the bike. Will take some more pics after install.
Reislust is offline   Reply With Quote
Old 12-27-2012, 04:31 PM   #20
JimVonBaden
"Cool" Aid!
Oddometer: 52,309
Very clean!
Jim
Old 12-28-2012, 12:22 PM   #21
Reislust
Still alive
Reislust's Avatar
Oddometer: 106
Very clean!
Jim
Thanks! Here's a pic of it installed on the bike with some zip tie anchors. I will be adding loomed 10ga wire straight to the battery, more pics to come.
Old 12-28-2012, 12:59 PM   #22
kk3an
kk3an's Avatar
Oddometer: 84
I mounted the 5025 using (4) standoff spacers underneath the unit with long screws shown in the four corners.
For what it's worth, all connections are silver-soldered, and certain wires jacketed with convoluted tubing for abrasiion resistance. Both of which will mitigate electrical issues on the road.
Dan
kk3an screwed with this post 04-12-2013 at 04:35 PM
kk3an is offline   Reply With Quote
Old 12-28-2012, 01:24 PM   #23
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,022
Really outstanding work!
Old 12-28-2012, 02:42 PM   #24
Ayrshire Bull
why the hell not?
Ayrshire Bull's Avatar
Oddometer: 2,594
Originally Posted by kk3an View Post
now that's some of the tidiest wiring on a bike, I've ever seen! Really nice work there Dan
"It's not what you look at that matters, it's what you see." - HDT
Ayrshire Bull is offline   Reply With Quote
Old 12-28-2012, 03:46 PM   #25
kk3an
kk3an's Avatar
Oddometer: 84
Thank you, gents.
Dan
Old 12-28-2012, 06:28 PM   #26
Reislust
Still alive
Reislust's Avatar
Oddometer: 106
Nice, looks clean. Similar to what I am doing with all ring terminals soldered, wire split loomed and heat shrink installed over ring terminals and meeting the loom for extra protection. Going to be constructing a very clean light bar for the bike over the next two weeks. If it turns out well enough I may mass produce some if the demand is there as the quality will be concurrent with much more expensive models.
Old 12-28-2012, 06:55 PM   #27
Ayrshire Bull
why the hell not?
Oddometer: 2,594
lightbar? for the gs1200 (canbus friendly version?) interested.
Old 12-28-2012, 07:11 PM   #28
Reislust
Still alive
Reislust's Avatar
Oddometer: 106
Talking
It will be an aluminum solid roundstock mount for the driving lights of your choice. Mine will support dual HID Micro DE's but the bar will be built to last with final dimensions (measurement from bike fairing to the furthest point away) that can be specified with order. The standard dimensions will hug in pretty tight as I don't want them to be beaten in a light crash. The point is to match the size of the front fender support/oil cooler mount/subframe and flow nicely with the contours of the bike. Colors will be customizable as well to match frame or 60% black. I am going to try to keep the cost below 50 dollars, I have materials coming for prototypes next week. We'll see how she goes!
Reislust screwed with this post 12-28-2012 at 11:54 PM
Old 04-12-2013, 02:41 PM   #29
Borderbeemer
Borderbeemer's Avatar
Oddometer: 10
Clearance under 1200 GS seat
Reislust. I LOVE how clean your setup is, but did you have to raise your seat to it's highest position in order to fit the 5025 under it? I borrowed a buddy's before he installed it on his 1150 GSA and I could not get the seat to latch shut while at the lower setting.
Borderbeemer is offline   Reply With Quote
Old 04-12-2013, 04:14 PM   #30
JimVonBaden
"Cool" Aid!
Oddometer: 52,309
I had that on my old R1200 GS, fit just fine with the seat in the low position!
Jim
Times are GMT -7.   It's 07:43 AM.
