Old 06-23-2012, 09:02 AM   #1021
OnkelPopanz
Oddometer: 64
Hopefully, you will report after testing... :)
OnkelPopanz is offline   Reply With Quote
Old 06-24-2012, 12:36 AM   #1022
Marc_CH
Oddometer: 4
Originally Posted by toniguedes View Post
Is this the GIVI Trekker 52 there? - If so, could u post some pics from behind and from the side?
Im still looking for a topcase... as much room as possible, but shouldnt look like an UFO
Marc_CH is offline   Reply With Quote
Old 06-25-2012, 05:51 AM   #1023
toniguedes
Oddometer: 62
Nope, It's the Trekker 46!
I've bought that thinking it could carry two helmets, but doesn't...
It looks really big, but I need it to take my notebook/backpack and rain suit in my daily commute.
pros:
- good water resistance;
- good impact resistance;
- not so ugly.
- cheap than an all-aluminium.
cons:
- heavier than a aluminum top case;
- looks like a small ufo;
- My wife says I can start working delivering pizzas.
You can see some pictures here
toniguedes is online now   Reply With Quote
Old 06-26-2012, 07:01 AM   #1024
dem
Oddometer: 18
Madstad @ 7000 miles
7000 miles, 23 days, lots of rain, lots of bugs. A+
dem is offline   Reply With Quote
Old 06-26-2012, 10:55 AM   #1025
costas68gr
Oddometer: 55
WRS screen have a hole! why have this hole? any feedback for this screen or similar screens with this type hole
Wonderful Greece
costas68gr is offline   Reply With Quote
Old 06-26-2012, 11:43 AM   #1026
toniguedes
Oddometer: 62
Good question!
There is no info at wrs website about that...
California Scientific says their windshields are "vented for minimum turbulence and back pressure"
Old 06-26-2012, 12:12 PM   #1027
markymcd
markymcd's Avatar
Oddometer: 882
The theory is that the air that passes through the lower area creates a low pressure area under where the air above passes over. this should create less buffeting.
Same theory with most all hole/dual screen fairings.
cheers,
Mark
www.adventuredecals.com
markymcd is offline   Reply With Quote
Old 06-26-2012, 12:17 PM   #1028
ride2little
MoveAlongNothingHere
ride2little's Avatar
Oddometer: 1,960
cheers,
Mark
Yep, the air isn't so much going through the screen, rather up the back side of it. That's why it's not just a round hole. More of an air intake-like design following along with the airflow.
~MK~
BMWF800GS
KTM 400 EXC
AMA-262640
ride2little is offline   Reply With Quote
Old 06-27-2012, 06:35 AM   #1029
Jon_PDX
Oddometer: 1,119
I had a screen like that and one day while I was cleaning the bugs off I could not figure out why they would not come off. That's when I realized the bugs were on the other side of the screen
Jon...
Bikeless at this time
Past Bikes.....Check with my Wife.....I've lost count :-)
Jon_PDX is offline   Reply With Quote
Old 06-27-2012, 09:25 AM   #1030
Marc_CH
Oddometer: 4
Ty
Old 06-27-2012, 09:35 AM   #1031
Teep
Oddometer: 294
My Madstad looks like yours..
After 3000 miles to Big Bend NP and 5000 miles to and around Alaska I find it nearly perfect. The wind protection is great cruising at 75mph on the long straight roads. After 9 days of riding in the rain it looked real bad but cleaned up nicely. In my opinion you can try any screen you want but the Madstad is an excellent screen with enough adjustment to fit nearly anyone. I'm 6' 1" riding an F650GS and the screen set about 4" below my line of sight and i have no buffeting or much wind hitting my helmet; I do get some bugs on my face shield though.
Teep is offline   Reply With Quote
Old 06-27-2012, 10:54 AM   #1032
OnkelPopanz
Oddometer: 64
Originally Posted by teep View Post
after 3000 miles to big bend np and 5000 miles to and around alaska i find it nearly perfect. The wind protection is great cruising at 75mph on the long straight roads. After 9 days of riding in the rain it looked real bad but cleaned up nicely. In my opinion you can try any screen you want but the madstad is an excellent screen with enough adjustment to fit nearly anyone. I'm 6' 1" riding an f650gs and the screen set about 4" below my line of sight and i have no buffeting or much wind hitting my helmet; i do get some bugs on my face shield though.
20 or 18 ?
Old 06-27-2012, 11:15 AM   #1033
JRWooden
Oddometer: 4,267
Continuing the "question assault"...
How much do the winglets help?
Old 06-27-2012, 12:33 PM   #1034
markymcd
markymcd's Avatar
Oddometer: 882
I made some custom winglets when I had a stock screen and was experimenting. The winglets made a big difference with buffeting.
It's quite a challenge to find a system that has a good balance of noise/buffeting removal and not being a monstrously large screen.
Old 06-27-2012, 01:45 PM   #1035
dem
Oddometer: 18
Madstad winglets
The winglets definitely keep a lot of cold air off you. Actually, I notice them most in reverse. If it starts getting warm, I need to pull them off or I start roasting.
The madstad screen IS a huge barn door - no way around it. Definitely NOT suitable for real off roading, it moves around quite a lot (IMHO, due to the mass of the metal faring bracket and the cantilever effect of the adjustable mounts themselves) and it is tall. Gravel and dirt roads are fine.
If I'm doing anything more exciting, I pull it off, stick it in a t-shirt and bungie it to my duffel bag. Both due to the height hitting me in the face and how hot it would be at low speeds.
The only other system I would consider would be the Mirage-type set up, but that sure is pricey.
You can see it strapped on the back here:
Times are GMT -7.   It's 01:36 PM.
