Old 06-18-2012, 01:22 PM   #241
benthic OP
glutton 4 punishment
benthic's Avatar
Oddometer: 397
Originally Posted by Bill Harris View Post
...These bolts are a high-preload (high fitting torque), high shear part, so why risk it? THey don't have a history of failure in use, but why risk it-- they are a nominal-cost item and can be replaced with no $$ distre$$. This view is also colored by a /5 10mm flywheel bolt background, where that bolt has been known to fail in shear.
Bare frame: do check the "crack-prone area" on the muffler-hanger, passenger-footpeg, sidecase-mount bracket behind the swingarm bearings. Weld it up or do a pre-emptive reinforcement.
You are going to remove the swingarm bearings before powdercoating? Make for sure that machined surfaces (like bearing bores) will be masked off.
Yeah, i will just order some new bolts, I have to order a few other bits and bobs anyway.
Frame! I did check those places already and they look good. I'm going to clean off some gunk a bit more and reinspect, but i think i'm alright. And yes, there is plenty to mask from powder coating - I'm not sure if I do this, or i just tell the powder coater what to mask. I'll ask when I go in to check them out.
I've been giving some thought to some sort of bolt kit. many of my bolts have some pretty tired threads, so I don't want to just plate what I have. Any thoughts?
Spencer
1978 BMW R80/7
"all we need is time and courage." - Renner
"A lightened flywheel on your bike is like me getting into Spandex and putting on track shoes to walk the dog." - M
www.blindfishz.com
benthic is offline   Reply With Quote
Old 06-18-2012, 11:26 PM   #242
supershaft
Oddometer: 9,110
The cadnium plated BMW fasteners are the best in the business. I would get those if you can while you still can.
Old 06-19-2012, 03:20 AM   #243
RagerToo
vroom vroom
Oddometer: 303
Originally Posted by supershaft View Post
The cadmium plated BMW fasteners are the best in the business. I would get those if you can while you still can.
I recently acquired an '80 R100 and noticed the plated bolts pretty quick. When I first told a buddy about the bike he said "whatya gonna do, part it out?" Ouch.
RagerToo is offline   Reply With Quote
Old 06-24-2012, 10:48 PM   #244
benthic OP
benthic's Avatar
Oddometer: 397
hi all:)
as i get ready for powder coating I'm going to have the center stand touched up. the bottoms are ground through the tube! but I was inspecting the frame and i noticed the mounts for the center stand are not quite straight. anyone know if this is normal? I suspect it is correct, but just want to be sure:
both tabs seemed cocked the same, but I had to repair the threads in the holes so i want to be sure there wasn't more damage. thanks!
I also started to take apart the swing arm. got the final drive off:) will take the bearings out tomorrow. I'm going to take the swing arm to a local bmw dealer to have the shaft pulled (they'll also put it back in for me after powder coat)
a few frame questions to toss out there - anyone know what the tab is for in the middle of the cross piece below (near the brake lever pivot)? I don't remember taking anything off that.
how about the tab in between the horn mounts below? Nothing came off that tab either...
Finally, how about the tab on the bottom of the swing arm? opposite the u-joint?
there is also a few little nipple like things on the swing arm that I don't know what they are for (forgot to take a picture). Do all these things have uses on other models of bikes? Should/could I grind them off?
Hope everyone had a great weekend. I'm thoroughly sunburned;)
Spencer
1978 BMW R80/7
www.blindfishz.com
Old 06-26-2012, 09:32 AM   #245
benthic OP
benthic's Avatar
Oddometer: 397
Hi all!
Last night I dropped off my frame and center stand with a local guy for some fixing. He's going to straighten those center stand tabs, fill them, re-drill and re-tap. He's going to fix the hole I made when I cut off the fork lock;) (more of those friendly bad influences at work;), and finally he's going to fix the center stand where the tube has been ground through. Really nice guy - I have high hopes for some good work:)
After that I came home and removed the swing arm bearings. What a clever tool! (thanks to Mike V. for letting me borrow it!)
I was going to try to unscrew the shaft bolt but I didn't have a big enough socket so I'm hoping the shop that is going to pull my shaft out will not give me a hard time about the bolt... That's on tonight's menu:)
oh, and here's that picture of the POR15 liner. not my best work. I got a little stripper in the gas cap well so I decided to just paint the well with the POR15. You can see the silver liner through the hole. As I mentioned, it was a pain, and I'm not sure how good a job i did. Time will tell. I'll be keeping a close eye on the filters and will probably drain the tank again in 6 months to check it out.
Spencer
1978 BMW R80/7
www.blindfishz.com
Old 06-26-2012, 09:40 AM   #246
Horsehockey
A GPS? Huh?
Oddometer: 328
Nice job on that tank. As long as you hit the two key spots: on the base at each petcock opening (where water collects and sits and rots her out) you're good. Doing the fuel filler neck area is good too, because the neck and overfill well are subject to oxidation too + you get to admire your hard work at every fillup. Nice job.
Horsehockey is offline   Reply With Quote
Old 06-26-2012, 09:42 AM   #247
blaine.hale
blaine.hale's Avatar
Oddometer: 3,068
That tab near the brake arm lever is where the rear brake light sensor mounts.
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is offline   Reply With Quote
Old 06-26-2012, 10:20 AM   #248
Renner
infamous wrench
Renner's Avatar
Oddometer: 2,174
Spencer
tab at top-center for brake light switch, as you know.
tab near center, on crosspiece... no idea at this time.
blaine, you're referring to that tab mounted on the inboard side of the passenger footpeg flange, yes?
"If you want to fix it with a rock, you have to stick to stone-age technology" -Anton
"...solving the latest crisis that is preventing my Airhead from taking me to the bar." -Beater-
Renner is online now   Reply With Quote
Old 06-26-2012, 10:23 AM   #249
blaine.hale
Oddometer: 3,068
Well, to be specific, the tab on near the foot peg and exhaust mount is the brake light switch.
The two tabs on that center piece above and behind the swing arm pivot are just stays for the rear fender. They simply poke into the read fender to line it up properly and prevent it from vibrating all crazy like.
That weird one in the almost dead center of the picture? You got me, haha
1974 BMW R90 /6
Old 06-26-2012, 10:45 AM   #250
benthic OP
benthic's Avatar
Oddometer: 397
yeah, that's the one I was refering to;) that, and the other 2 i mentioned did not have anything attached to them since I've owned the bike. They must be for something on a different version of the bike?
Thanks all!
1978 BMW R80/7
www.blindfishz.com
Old 06-26-2012, 10:29 PM   #251
benthic OP
benthic's Avatar
Oddometer: 397
I got the shaft pulled out of the swing arm this afternoon at a local BMW shop. Well worth the time. I handed them the swingarm and $40. 10 minutes later they handed me my swingarm, shaft peices and the nut. boom baby. and when the powder coating is done i take the peices back and they'll reassemble for no further charge.
I think i'm going with "steel grey" for the powdercoat color. it's a dark grey and will go well with the orange tank and just about any color i might decide to paint in the future...
this evening I took apart the forks i bought...
yuck. luckily I also have the forks that came off my bike so I have plenty of parts to pick the best from.
Tomorrow I pick up my frame parts:) I can't wait to see how the repairs turned out! And then all the parts will go to the powder coater on Thursday! Exciting!!!
Spencer
PS - i'm still curious about those superfluous tabs if anyone knows what they are for!
1978 BMW R80/7
www.blindfishz.com
Old 06-27-2012, 06:27 AM   #252
Renner
infamous wrench
Renner's Avatar
Oddometer: 2,174
What I'm seeing there is fresh inspiration for your frame paint scheme... sort of a mottled rose-orange with flecks of brown and puce.
It's not too late to change your mind regarding that passé gray
You may also consider starting a new thread entitled Superfluous Tabs to gain a larger audience.
seriously, those damper rods look like prime candidates for electrolytic rust removal.
looking forward to seeing the frame repairs & modifications.
Old 06-27-2012, 07:53 AM   #253
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,464
And those forks are a good argument for regular changes in fork oil.
Don't suppose that they've been underwater? Even sitting outside at the breaker's I can't imagine forks getting that much water inside.
A couple of pages to look at, if you need:
http://www.advrider.com/forums/showp...0&postcount=36
http://aatherton06.home.insightbb.co...age/TITLE.html
'73 R60/5 Toaster
Bill Harris screwed with this post 06-27-2012 at 07:59 AM
Old 06-27-2012, 09:13 AM   #254
benthic OP
benthic's Avatar
Oddometer: 397
why do you do this to me Renner?
yeah, disappointing. I'll see how well they clean up:/ the forks that came on my bike actually look really good (clean) except for the fact that the previous owner must not have had a circlip plier thingy and the screw in spacers seem to be a bit stripped... (no pic of that yet). The good thing though, is like you say, i've now learned why we're supposed to change the oil regularly;) This project teaches me so much;)
1978 BMW R80/7
www.blindfishz.com
Old 06-28-2012, 01:40 PM   #255
benthic OP
benthic's Avatar
Oddometer: 397
I just dropped my parts off at the powder coater - RW Little here in San Diego! I'm so excited!
The parts I'm having done are:
frame
sub-frame
swing arm
center stand
battery box
handle
kick stand
all for $255. From what I've heard that is a good price. They told me 5-7 business days, and I hope it is 7 because I'll be out of town a bit next week;)
The repairs turned out fantastic! Spinner, the guy that did the work, exceeded my expectations. If anyone needs some work done (large or small) in San Diego, I can give you Spinner's email via PM. I'll try to post some pictures tonight...
GAH! Even though i have a ton to do in order to get the forks ready, and the engine put back together, and the wheels back together, I'm ITCHING to start reassembling the whole bike. ITCHING i tell you. I don't think they make a cream for this.
Spencer
1978 BMW R80/7
www.blindfishz.com
Times are GMT -7.   It's 07:55 AM.
