Old 06-29-2012, 09:00 PM   #46
troy safari carpente
Team f5ool
troy safari carpente's Avatar
Location: "Pearl of the sound" - f5ederation of scandwegia
Oddometer: 20,467
from the above link... c/o Roberto Boasso/facebook
CONTENTS MAY SETTLE DURING TRANSPORT...
troy safari carpente is offline   Reply With Quote
Old 06-29-2012, 10:53 PM   #47
beaney
rally racer
beaney's Avatar
Oddometer: 124
Trellis frame and TM engine
Ferrari Motorcycle Italiana Bordone-E1
E1 is a thoroughbred racing, created to take the bull without compromise. It is at the same time a wonderful example of adaptation to almost endless series of technical and technological constraints. The motorcycle rally is heavy at the start with a full tank and lighter ends in reserve, it must be equally effective on the sand and impalpable on the slopes of rocky highlands, go gently winding mule tracks and be super fast on Large areas of Grand Prix of the Desert . It must guarantee high power and reliability essential. Handling and comfort, stability and security. Achieve a win for the Motorcycle Rally Raid means finding the perfect balance in the management of variants, the key that unlocks the door of efficiency.
Advanced Solutions
The E1 is a comprehensive collection of advanced solutions to subordinate information Renato Ferrari , ordered and granted them according to the experience of technicians chosen to achieve it. For its construction were used the best materials available and most suitable technologies to optimize performance.
chassis, directed by Fernando Prades , is a lattice tubular chrome molybdenum steel, and it was drawn on the geometry a revolutionary motorcycle that can provide the maneuverability necessary for critical situations and at the same time high stability and safety at any speed.
The engine was done by TM on the specific Bordone-Ferrari , and he enjoys the experience the company of brothers Serafini Pesaro in the Enduro, Supermoto and Rally's. It has excellent power and a new, more efficient distribution diagram.
Innovative also regarding suspensions, especially for the rear, which was projected for a new fork and a progressive kinematic advantage of a single innovative Donerre shock.
Design
Congestion imposed by the specifics of the mechanical and superstructures of E1 were optimized based on the weight distribution and center of gravity of the bike. They have applied to the result "raw" ergonomic and aerodynamic research in order to achieve an efficient and comfortable bike, easy to drive and little tiring. The next step, which refers to one of the original impulses of the proposed Renato Ferrari , was to gather all the functional specificities of E1 in a "shell" inspired aesthetic values ​​essential for Bordone-Ferrari Motorcycle Italiana . The silhouette of the E1 was developed by designer Rodolfo Frascoli, and architect Luca Mattavelli is responsible for the graphics and color choices, since E1 be a Motorcycle Rally winner and beautiful. A dream, for one year transported into reality and finally result in the realization that we can now finger touch and admire.
Technical Data
  • Type ....................... Motorcycle Rally Competition
  • Brand ........................... Bordone-Ferrari Motorcycle Italiana
  • Model ........................... E1 Rally
  • Engine 4 stroke ........................... TM
  • Displacement 449 cc .......................
  • Bore / stroke .............. 97 mm x 60.8 mm x 1
  • Compression ratio ...... nd
  • Power ...................... nd
  • Power .................. Keihin diam. 41 cm
  • Digital electronic ignition ........................ Keihin
  • Starting ..................... Electric
  • Multiplate clutch ..................... oil bath
  • Transmission 5-speed ...............
  • Secondary transmission Chain ..
  • Trellis frame ........................... tubular chrome molybdenum steel
  • Double Fork ........................... aluminum arms
  • Front Suspension Kayaba inverted fork ............. diam. 48 cm
  • Rear Suspension ........... kinematic progressive Donerre a shock,305 mm total stroke
  • Front brake Brembo 2-piston ...................... 300 mm
  • Rear brake Brembo 1-piston ..................... 240 mm
  • Wheels / tires 90/90-21 ........ 21 "130/80-18 18"
  • Dry weight 130 kg ........................
  • Curb weight 158 ​​kg ....
  • Total length 221 cm ..................
  • Wheelbase 1535 mm ...................
  • Seat height 996 mm ..................
  • Fuel tank capacity 32 l ..
690 enduro/ rally
350 exc
RALLY-RAIDPRODUCTS.CO.UK
beaney is offline   Reply With Quote
Old 06-30-2012, 12:50 AM   #48
schattat
schattat's Avatar
Oddometer: 1,445
Am I blind or does this bike not have any headlights?
RNS - Rallye Navigation Solutions
Yamaha WR450F Rallye Spec
schattat is online now   Reply With Quote
Old 06-30-2012, 01:09 AM   #49
Brodovitch
Team ⌘R
Brodovitch's Avatar
Oddometer: 3,171
and no kick starter.. though I can see the spline in the motor
the body work is beautiful, fluid, very compact for the claimed 32 litres it carries
even the radiator scoops which were probably added to accommodate more sponsors -if for nothing else- bother me less now...
Also can't tell if the skid plate accommodates water & tool box (it juts out to the front quite a bit)
I wonder what internals the KYB fork has.
so, the million dollar question...
How much?
TALES FROM THE BIVOUAC
TWOONEZERO
Brodovitch is offline   Reply With Quote
Old 06-30-2012, 03:19 AM   #50
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,040
Lots of odd design choices, like the exhaust can being not tucked under the rear tank. One good slide on that side of the bike and the can will be ripped off. The rad shrouds...would have to see the bike but the rad looks unprotected and using a single seems an odd choice. As mentioned no kick start as well. Not saying bad designs as they likely know a ton more than I do, just some odd ones at a glance.
Love the slick look though
When does it debut in a race ?
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 06-30-2012, 05:56 AM   #51
Carlos M
www.motoxplorers.com
Carlos M's Avatar
Oddometer: 3,397
The bike looks blind without the headlight. It's for daytime use only "With its superbly designed blah bla blah, it is made to arrive at each bivouac by early noon" the propaganda will claim
It looks nice, nonetheless.
Carlos M.
MotoXplorers.com
Carlos M is offline   Reply With Quote
Old 06-30-2012, 06:11 AM   #52
schattat
schattat's Avatar
Oddometer: 1,445
Regardless, it still has to comply withthe international highway code, i.e. headlights, horn and yes, even a mirror
Old 06-30-2012, 07:36 AM   #53
Brodovitch
Team ⌘R
Brodovitch's Avatar
Oddometer: 3,171
going back to the kick starter, I think someone fucked up the mold for the right hand tank...
there's no indent when the kick-starter is folded in place
typical designer going off and doing his own thing material
Nit-picking aside, can't wait to see what the team do with the bike in the Pharaoh Rally
TWOONEZERO
Old 06-30-2012, 09:15 AM   #54
Hausi1
asd
Hausi1's Avatar
Oddometer: 49
Maybe they just forgot the headlight... Like when you're so focused on getting the details right that you forget something big...
Hausi1 is offline   Reply With Quote
Old 06-30-2012, 02:10 PM   #55
Gian OP
dreamer
Gian's Avatar
Oddometer: 1,229
Be sure that after the first races a lot of details will change, it's normal
Gian is offline   Reply With Quote
Old 06-30-2012, 11:52 PM   #56
Team f5ool
Oddometer: 20,467
Talking It's a justa da' small details.... eh?!
EGYPT RALLY (october) - Post race technical debriefing at B/F headquarters:
Team Chief (to technical director): "Okaaay... Luigi... Prego... you thinka we canna putta kickstarter onna da' bike now... eh? Jordi and Alex; they go through technical inspection in Egypt; no problemo...! And a she looooka soooooo sexy in alla da' magazine photo's... no?
...but they still on podium trying to starta da' bike, eh...?"
Old 07-01-2012, 02:50 AM   #57
Aussie66
Aussie66's Avatar
Oddometer: 862
Nit picking, the 690 never had a kickstarter either.
"If at first you dont succeed then skydiving is not for you."
Aussie66 is offline   Reply With Quote
Old 07-01-2012, 04:32 AM   #58
tHEtREV
Captain Awesome
tHEtREV's Avatar
Oddometer: 7,788
Might be like the Rallye Pan Am 525s with the 660 Rallye tanks and have a kick starter stashed somewhere on them just in case (from memory, in Neduros rallye bike rehab thread, they did it that way because the 660 tanks didn't have the cut out in the tank as the LC4 is a left kicker.)
The bike is growing on me though.
tEAM iDIOT.
A KDX is way cooler than what ever you ride...
tHEtREV is online now   Reply With Quote
Old 07-01-2012, 05:27 AM   #59
tehdutchie
tehdutchie's Avatar
Oddometer: 1,875
Loving it more and more..
trellis frame indeed.
tehdutchie is offline   Reply With Quote
Old 07-01-2012, 05:32 AM   #60
schattat
schattat's Avatar
Oddometer: 1,445
More pics grabbed from their site
Times are GMT -7.   It's 11:12 AM.
