Old 06-22-2012, 05:58 AM   #76
radianrider OP
Adventurer wanna'be
radianrider's Avatar
Oddometer: 473
Thanks, VTwin. I'll probably order one. Was looking at that one earlier, but hadn't thought to mount it in the console a you suggested.
Was optimistic in my earlier report. Haven't resolved the misfire and running on one cylinder issue. Now believe three bike is flooding out in the left carb.. Another tear down coming up on Monday. Stuck in FL until late Sunday.
radianrider is offline   Reply With Quote
Old 06-22-2012, 06:23 PM   #77
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,373
Bad luck. Are you certain it's the left carb? "Driver's" side that is? If it's the right, it could be the petcock causing flooding through the vacumn hose.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 06-22-2012, 08:59 PM   #78
radianrider OP
Adventurer wanna'be
Oddometer: 473
Definitely on the left (driver's side.) Gas coming out of the air box, so opened it up and found gas sitting in the throat of that carb boot.
Suspect float needle and/or float is at fault.
Old 06-29-2012, 08:12 PM   #79
radianrider OP
Adventurer wanna'be
Oddometer: 473
Float needle was the problem. Running beautifully again.
Took it out for a ride. Had to bump start it after a stop. Starter destroyed the brushes three weeks after I rebuilt it. Sheesh.
New to me used one on the way from TN thanks to a GSResources forum member. About the same cost as the parts to rebuild the original would have cost.
Eventually, I WILL be able to ride more than an hour before taking on another repair.
Old 07-01-2012, 07:53 AM   #80
vtwin
vtwin's Avatar
Oddometer: 7,373
Congrats. Mine was loading up on the last ride. Stalling and running badly. Looks like mine have to come off again. Maybe just some bad gas.
Monroe.
unknown
Old 07-01-2012, 09:25 AM   #81
radianrider OP
Adventurer wanna'be
Oddometer: 473
Both cylinders? If so, suspect petcock...if one, probably the carb.
Right cylinder was running great. Could pull the sparkplug boot of the left and it made no difference. Pulled the right and it stalled immediately.
Old 07-03-2012, 06:12 AM   #82
radianrider OP
Adventurer wanna'be
Oddometer: 473
Got a used starter and installed it. I think I'll be able to actually RIDE the thing!
Old 07-03-2012, 09:33 AM   #83
Fire Escape
Fire Escape's Avatar
Oddometer: 1,554
Wink For A While
Well yeah ...... for a while ........ until something else .........
That's generally the way with any old bike, sure some (mythical?) bikes never seem to have a problem, where's the challenge in that? Have fun riding!
Bruce
No one calls the Fire Department because they did something smart!
06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco, TKCs summer/17" SM wheels winter 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225
Fire Escape is online now   Reply With Quote
Old 07-03-2012, 11:04 AM   #84
radianrider OP
Adventurer wanna'be
Oddometer: 473
Bruce
Far too true! I took it out for a short 20 miles today and it ran beautifully. (Well, slight popping on deceleration out of the left cylinder--screw mixture set too lean I would guess.)
Have to admit, I was riding along waiting for something to go wrong.
Old 07-13-2012, 09:14 AM   #85
radianrider OP
Adventurer wanna'be
Oddometer: 473
Took it out yesterday and it ran beautifully for about 40 of 45 minutes. Five minutes from home the left cylinder started loading up again.
Knew immediately that the left float needle was sticking again. Pulled the carbs and installed one given to me by a GR rider in PA. Seems to be running well again. The old needle is permanently out of service.
Figured out why my choke was sticking and resolved that while I had the carbs off as well.
I pulled the Superbike bars off the other day. Just hurt to ride it longer than about 25 minutes. Went back to the MX bars I had installed a year ago. Resolved the neck pain and nerve numbness kicked up by the lower bars. I can also see things in my mirrors--an ongoing issue with the narrower bars. The MX bars don't look as classic, but they feel WAY better. That'll do for now.
So, starter issue resolved, carb flooding issue taken care of, neck pain gone--should be good to go until the neck
Old 07-13-2012, 07:20 PM   #86
vtwin
vtwin's Avatar
Oddometer: 7,373
Nice. I've yet to pull the carbs again to find out my loading problem.
Monroe.
unknown
Old 07-13-2012, 07:56 PM   #87
radianrider OP
Adventurer wanna'be
Oddometer: 473
Bummer. Have you determined whether it is one cylinder or both?
Got mine out for a shakedown ride tonight. I don't think I've had it running better than it did this evening. Makes me nervous.
Old 07-25-2012, 06:32 AM   #88
radianrider OP
Adventurer wanna'be
Oddometer: 473
Bike continues to run well. Figured out an inexpensive way to mount
The GoPro, so videos to come
Old 07-28-2012, 05:48 PM   #89
vtwin
vtwin's Avatar
Oddometer: 7,373
I'm going to send the carbs to one of our club members that supposed to be a wizard at carbs. Dog knows I'm not too good at it.
Monroe.
unknown
Old 07-28-2012, 06:40 PM   #90
radianrider OP
Adventurer wanna'be
Oddometer: 473
They aren't real complicated and there are some really good walk-throughs on thegsresources.com. A GSR member, basscliff, has bunch of tutorials on his page.
Times are GMT -7.   It's 06:21 AM.
