Old 07-05-2012, 02:04 PM   #106
urbanXJ
urbanXJ's Avatar
Oddometer: 3,103
I have been using Starter Fluid Spray (diethyl ether) from walmart.
The can is $2, and I can get my chain very clean with just 1/3 a can.
Some tell me it's not oring safe, but it's not in contact very long and works so great..just blasts the dirt off and dries quick.
DO NOT USE AROUND FIRE or KABOOM
...SPEEDING PAST THE LINE OF GOOD TASTE...
urbanXJ is offline   Reply With Quote
Old 07-05-2012, 03:44 PM   #107
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,078
Originally Posted by ChrisRiedinger View Post
Not sure if this has been mentioned before, but you were measuring (rubber) with precision measuring instruments?
Really?
OK, OK - if thats ok-
You put these solvents in a plastic container that youre sure didnt degrade when you added them AND the o-rings into?
I know Im a few years behind on this.. but really? What kind of scientist are you?
Do you ask for an MSDS before accepting your Quarter Pounder?
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 07-05-2012, 07:30 PM   #108
Jud
Jud's Avatar
Oddometer: 2,438
Really?
Oh,,, that was just fer quick reference as he had all the data from the measurements taken on the MicroView stored on an ExcelDoc. at the time.
Pics- http://s563.photobucket.com/albums/s...eon/?start=all
Places visited on two- http://s563.photobucket.com/albums/s...0two%20wheels/
Endeavor to Persevere
Blue Skies Coming
Jud is offline   Reply With Quote
Old 07-06-2012, 04:51 AM   #109
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,078
It's a viloation of Harris County Law to use starter fluid like that. It's OK in Waller though.
I just use a stiff brissle brush to knock the crud off then relube with some type of silicone lube.
Regards
Fritzcoinc
Old 02-03-2015, 11:43 AM   #110
locorider
Loco, pero no estúpido!
locorider's Avatar
Oddometer: 2,515
Great report. Ive been using wd40 for a long time in my bike's o ring chain and no problem. Then I blow air before adding Motul Offroad chain lube...
Carlos locorider
From Puerto Rico to Georgia and beyond...
Old 02-03-2015, 12:25 PM   #111
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,453
I've found WD-40 to be a great grunge cleaner for any grimy parts of an engine, chain, or frame. It's not a lubricant, but it seems compatibility with o-rings is more important than lubrication. However, I'm using an automatic chain oiler with 2-stroke engine oil for the chain. The oil is about the same viscosity as ATF and should provide some level of lubrication, since it's an engine oil. But, back on topic, a gallon of WD40 and the the spray bottle can be bought at Lowes, Home Depot, etc and is much more economical and easy to apply than the aerosol spray can.
Stan_R80/7 is offline   Reply With Quote
Old 02-03-2015, 01:15 PM   #112
chornbe
Oddometer: 57
Exposure PLUS heat and friction would have been a very interesting over-time test, but... you'd need a lot of exact bikes being ridden identically - or a machine to keep the chains in constant motion.
chornbe is offline   Reply With Quote
Old 02-03-2015, 01:16 PM   #113
chornbe
Oddometer: 57
Great for cleaning. I continue to laugh at those who think it's a lubricant no matter how often you can read a plethora of things that flat out say otherwise.
Old 02-04-2015, 09:37 AM   #114
acap650
acap650
acap650's Avatar
Oddometer: 710
I use WD after cleaning the chain with a water based degreaser, S100, Simple Green, etc.. It takes care of the water after rinsing and prevents rust until the chain is dry and ready for proper lubing. WD=Water Displacement.
acap650 is offline   Reply With Quote
Old 02-04-2015, 05:50 PM   #115
superspeed123
superspeed123's Avatar
Oddometer: 54
I have been using RP7 for many years cleaning my chains with it with a rag. Chains looks fine even after 50k km. I also use scottoiler with dual injector to oil my chains.
Dun worry too much, just enjoy the ride.
2011 Suzuki GSX1250FA
superspeed123 is offline   Reply With Quote
Old 02-05-2015, 09:34 AM   #116
Johnf3
Oddometer: 1,055
Meant to be light-hearted here, but I would laugh at you if you sprayed your MC brake rotors with WD 40 and then tried to stop your motorcycle before hitting whatever object you were trying to avoid.
Of course WD 40 has some lubricating properties. It may not be up to your defining standards, but try my little empirical experiment and report back.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Johnf3 is offline   Reply With Quote
Times are GMT -7.   It's 01:10 PM.
