07-06-2012, 09:54 AM
#1 |
Padawan Learner
Oddometer: 16
KTM 690 Enduro/SMC Performance
I tried searching several ways to find a thread with the information I was looking for with no luck so I created this forum for all of us 690 owners to discuss performance options for our bikes. I just bought a '12 690 Enduro R and I'm getting ready to uncork it and I had some questions, first, does anybody have the EVO stage II kit from KTM installed w/ the cone filter, cam, battery relocation kit, and Akro pipe? I'm looking at buying the kit w/o the Akro pipe and using an FMF Factory 4.1 to save money but I wanted to know if the battery relocation kit was necessary? if not I'll see if I can get it from KTM Twins w/o the battery kit either.
Brakes are for quitters. |
07-06-2012, 11:08 AM
#2 |
Padawan Learner
Oddometer: 16
Also
Anyone know of an SAS(Secondary Air System) removal kit out there? something to make it clean and easy.
07-06-2012, 03:04 PM
#3 |
Oddometer: 28
Subscribed.
07-06-2012, 06:43 PM
#4 | |
Oddometer: 65
Just picked up a 690 Enduro Thursday last week. Put a leo Vince on it to dump the Nuclear Heat Exchanger on the back and --------Yeah, much better. Loud when you throw the fuel to it but not bad cruzzing at 60. After pipe install it stalled twice at idle. Let it idle for 15 minutes and all is good so far. The ECU had to catch up with the mods. Been looking into maps and all the stuff but this machine has plenty of power so-----------Don`t pay to try and fix it ! Just ride the thing . My thoughts. Mossback |
07-09-2012, 09:02 AM
#5 |
Padawan Learner
Oddometer: 16
Pipe
Yeah, one of the local guys has a 690 w/ the Leo on it, its the same price as the FMF and a little better looking, only thing holding me back is I counldn't find the weight online to compare to the FMF, and like you said the thing has plenty of power so weight is a bigger issue to me.
07-09-2012, 09:21 AM
#6 |
Oddometer: 2,293
consider the vortex ecu also as it has different maps with different fueling,ept maps and ign advance built into it.
07-09-2012, 11:35 AM
#7 |
Oddometer: 7
Definitely re-map with new silencer...
These bikes are mapped VERY lean from the factory to meet EPA standards for emissions... putting a new silencer will open up the exhaust flow, causing it to run even more lean. The EFI will try to accommodate by adjusting to the new MAF (mass air flow) rate, but the base fuel mixture is still going to be very lean.
Regardless of the "feel" or how much apparent power there is, the valves and head will suffer with a mix that is too lean. |
07-09-2012, 12:44 PM
#8 | |
icanhazdirt?
Oddometer: 396
So, is there a solution that allows owners to enjoy less weight, better heat management and yet, keeps airflow the same as the stock exhaust? THAT I would be interested in. After a test ride last week, I'm convinced the extra HP or two that *may* appear from a pipe swap would be largely lost on me (not that I might not feel it, but I don't feel I need more). The bike rips as is, so I'd be happy with a stock pipe...though I'd love to ditch the weight and not melt signal lights, too... ;)
My Stuff: Jeep News l Online Marketing News ...and my dogs are cooler than your dogs! |
07-09-2012, 04:05 PM
#9 | |
when in doubt GAS IT
Oddometer: 1,661
These three are the must do,s Muffler , vortex ,suspension , then go for it as much bling as you want On smj ( super moto junkie) look for the evo thead ( Intune )started ,Adam has done a great job working with Richard from vortex getting the fueling spot on . Lucky for me vortex is only 10 minutes away so I can update at any time But if you want 75hp+ you might want to send your motor to gwr in Germany , Glenn was one of the engineer on the rfs motors $5k will will get you a 728cc monster |
07-09-2012, 07:15 PM
#10 | |
8 lug oil burner
Oddometer: 9,171
With the pipe, a re-map, and the RR air filter. I doubt I'll be searching for power anytime soon. |
07-11-2012, 09:34 AM
#11 |
Oddometer: 28
Anybody have any opinions on the Power Commander? Looks like it's a little less expensive than the Vortex, and it has an onboard display option which seems kind of nice.
07-12-2012, 07:59 AM
#12 |
Red Sox Nation
Oddometer: 8,896
Pretty much all roadrace bikes use Power Commanders. Probably more knowledge around that device as a result.
Straight ahead and faster -Bo Weaver 1970 "There I was..." -Griffin Niner Three Hotel |
07-12-2012, 08:09 AM
#13 |
Kool Aid poisoner
Oddometer: 4,827
PC's only control fuel mapping. Vortex controls fuel mapping, spark timing, and voltage output.
Good. Bad. I'm the guy with the gun. Guess what doofus, nobody reads your lame blog. |
