Old 07-14-2012, 03:00 PM   #16
Boxerworks
g00b
Boxerworks's Avatar
Oddometer: 57
Maybe...?
Waiting for it to warm up could be a symtom of having too heavy a gear oil in the box. And that screech noise could be a worn clutch rod end...
before you take it apart you could make sure you have the right oil in it. And you could pull the clutch pushrod out and check to see if the rod is worn funny at the end.
Just a guess off the top of my head....
Matt
Boxerworks.com
Boxerworks is offline   Reply With Quote
Old 05-18-2013, 09:16 PM   #17
TheForefront
Oddometer: 1
::::BUMP::::
Originally Posted by khale View Post
More symptoms:
1. The bike has a horrible screeching noise when I'm at the end of the clutch lever to engage the gears. I'll try to post video if I can.
2. The problem really shows up when I'm on an incline. If I first start the bike and have to go up a small hill, even if the grade is less than 5% I hear the awful screeching noise and the bike barely moves, as if the bike is not in gear
Did you ever get this fixed? I'm having a very similar issue. Thanks!
TheForefront is offline   Reply With Quote
Old 05-19-2013, 08:58 AM   #18
khale OP
ride dirty
khale's Avatar
Oddometer: 557
Originally Posted by TheForefront View Post
::::BUMP::::
I did get the issue corrected. It was the original clutch (40 years old). I replaced the entire clutch and the problem is no more.
2013 BMW R1200 GSW | 1972 BMW R75/5 toaster | 2011 Husky TE310
"4 wheels move the body, 2 wheels move the soul"
khale is offline   Reply With Quote
Times are GMT -7.   It's 03:33 PM.
