View Results: Definite Committed Interest in this bracket?
950 SE-R 18 13.95%
990, 950 ADV 111 86.05%
Voters: 129. You may not vote on this poll
Old 03-10-2012, 03:29 AM   #106
Peanuts
Peanuts's Avatar
Oddometer: 1,576
Originally Posted by pchGS View Post
Have to add Charlie worked with me to get the sidestand to me prior to my trip.
Comments:
Part is HEAVY and by that I mean that is a good deal. It's stout and should fend of any offenders that want to take a whack at that sidestand area. It fitted up 'PERFECTLY' even with the tighter tolerances that you've spec'd.
One comment to those mounting it up. Be sure to get the lower front bolt through the side stand bracket troqued to spec prior to bolting the mount plate up on the bike itself. There is no room to tighten the nyloc nut supplied due to lack of clearance on the casting for the stand. This isn't a problem nor a oversight on Charlie's part just the circumstances of the new superior strength nuts/bolts supplied.
BTW I have a Slaven's Racing Skid plate and there were no issues fitting it with that skid plate.
Good stuff, now off to Baja to test it out...
Thanks Charlie!
I used KTM nuts to match the rest of the bike. These have a smaller head so I did not have that problem :)
Peanuts is offline   Reply With Quote
Old 03-10-2012, 03:41 AM   #107
charlie264 OP
charlie264's Avatar
Oddometer: 8,238
As long as you use loctite/thread lock no problem using the KTM nuts, I can’t source nylocks any smaller, nylocks are just easier in the field and less likely to come loose. This isn’t a problem if you torque the bolts using the allen heads in the countersunk’s and a spanner before you offer the plate up...as per instruction.
charlie264 screwed with this post 03-10-2012 at 03:51 AM
Old 04-10-2012, 08:05 PM   #108
SauceSquatch
SauceSquatch's Avatar
Oddometer: 257
does anyone know the torque specs for the 10mm bold and 8mm bolts?
SauceSquatch is offline   Reply With Quote
Old 04-11-2012, 04:43 AM   #109
charlie264 OP
charlie264's Avatar
Oddometer: 8,238
All M10's are 45NM and M8 is 25NM
Old 04-11-2012, 08:40 AM   #110
SauceSquatch
Oddometer: 257
Thank you sir!
Old 05-07-2012, 12:18 PM   #111
charlie264 OP
charlie264's Avatar
Oddometer: 8,238
Got the latest batch in, orders were posted Saturday....
Old 05-17-2012, 04:53 PM   #112
WoodbneK
Raisin AZ in AK
WoodbneK's Avatar
Oddometer: 32
Installed mine today. It fits perfect and, it was easy to install. Just did a little Dremel toolin' to the frame on my 04 as required.
Peace of mind is a good thing. Great Product.
2004 KTM 950 ADV(Sold)
2007 KAW KLR-650(sold)
2009 KAW Super Sherpa
2012 Victory Vision
WoodbneK is offline   Reply With Quote
Old 07-03-2012, 09:28 AM   #113
charlie264 OP
charlie264's Avatar
Oddometer: 8,238
Nice one. Thanks for the feedback, its on quite a few pre 05.5 bikes, any props just give us a shout.
Old 07-17-2012, 01:30 AM   #114
etingelefunts
retem-odo
etingelefunts's Avatar
Oddometer: 815
Ready for one!
I've researched as many relocators as I can find, and this one looks like a winner.
PM sent, hoping you have some left.
Less pondering. Simply march ahead, to the ends of this majestic planet.
etingelefunts is offline   Reply With Quote
Old 07-17-2012, 10:42 AM   #115
SauceSquatch
Oddometer: 257
I did the relocator and skid plate, they are both quality items, I'm very happy with it.
Old 07-17-2012, 11:27 AM   #116
etingelefunts
retem-odo
Oddometer: 815
Does he make a skid plate too?
I have the Weld86 installed. I also have the Weld86 relocator, which would be perfect if it were steel instead of aluminum. It continues forward and has an additional mount through a bushing to an unused hole in a very beefy portion of the case.
Old 07-17-2012, 02:33 PM   #117
SauceSquatch
Oddometer: 257
http://www.weld86motoparts.com/KTM-950-990-ADV.html
Old 07-21-2012, 06:39 AM   #118
charlie264 OP
charlie264's Avatar
Oddometer: 8,238
Not the same Charlie as Weld86, this has caused some confusion. My plate dosen't attach to the engine at all but still has five fixing points and is made from steel alloy not aluminium.
Old 07-25-2012, 02:46 PM   #119
Grayspeed
Grayspeed's Avatar
Oddometer: 15
One more for the thumbs up for Charlies sidestand relocator. Here in a day, fitted in a flash, looks and works the bizz. Nice one Chas!
Grayspeed is offline   Reply With Quote
Old 12-11-2012, 03:59 AM   #120
charlie264 OP
charlie264's Avatar
Oddometer: 8,238
Cheers man.
Times are GMT -7.   It's 04:02 AM.
