Old 07-24-2012, 03:54 PM   #121
rediRrakaD
Whoopdie do
rediRrakaD's Avatar
Oddometer: 853
Originally Posted by Airhead Wrangler View Post
Next time you're there would you mind looking at the diameter markings on the master and slave cylinders? There are a few different sizes available for each, depending on the length of pull needed at the clutch actuating arm as well as the amount of mechanical advantage needed. Thanks for giving me new possibilities for squandering my income.
Me too!
Seen this yet??
http://www.speedhut.com/gauge_produc...ometer_GPS.htm
Eliminates many issues!
Ordered today for my version of HPN.
Cheers,
S.
"Death in the pursuit of happiness is triumphant!"
rediRrakaD is offline   Reply With Quote
Old 07-25-2012, 01:28 AM   #122
Dakar83 OP
Dakar83's Avatar
Oddometer: 210
Your right there is a bit more to it. I haven't got all the detail yet but Dave is going to send it through. He mentioned 2 things the master cylinder size is 10.5, the Handle bar adaptor bracket needs to be sized according to the size of any switch block fitted. In the case of the white HPM it is the largest offset adaptor. I will post more info as it comes to hand.
Dakar83 is offline   Reply With Quote
Old 07-25-2012, 01:44 AM   #123
Dakar83 OP
Dakar83's Avatar
Oddometer: 210
Originally Posted by rediRrakaD View Post
Me too!
Seen this yet??
Cheers,
S.
I like the look of those gauges, wish I'd seen those before going the Vapour route . The Vapour works ok but it is very hard to read. A combination of mounting position and backlit LCD screen (limited on Lynx dash) and too much info crammed into each screen making individual read outs too small to read easily. Even the idiot lights on the dash are hard to read when the sun is shining on the dash.
Old 07-25-2012, 04:40 AM   #124
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,627
The R100GS that is being built for me will have a Vapour fitted into a Lynx fairing. The builder twigged that the dash angle is wrong so he will be making a surround for the Vapour and then fitting that into the dash at an angle where it can be easily read. Separate idiot lights will be fitted into the dash.
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is offline   Reply With Quote
Old 07-25-2012, 05:26 AM   #125
Dakar83 OP
Dakar83's Avatar
Oddometer: 210
That sounds like a good plan. I have mounted my Zumo 550 above h vapour an use that for speed redout as its nice and clear. I might have a think about changing the angle. Have you sourced the right cable and sensor for engine temp?
Old 07-25-2012, 06:02 AM   #126
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,627
I`m going over the workshop tomorrow to get some tires fitted to my 1100GS, I`ll find out about the sensor.
David Hunn:
Old 07-25-2012, 08:50 AM   #127
rediRrakaD
Whoopdie do
rediRrakaD's Avatar
Oddometer: 853
I had my heart set on this:
http://motogadget.com/de/fahrzeugtyp...oad-rally.html
Until seeing the GPS based gauge.
NO more wire down the fork! Custom colors, 2 diameters available.
Lots of info on the small led screen.
Oh and lifetime warranty made it an easy choice.
You guys make me proud of my Aussie heritage.
Keep up the nice work.
Cheers,
S.
Old 07-25-2012, 11:46 PM   #128
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,627
Change of spec (apparently), we are going with an Acewell unit now; much the same as the Vapour, but the one we`re using doesn`t have built in idiot lights. Not having a temp gauge, so cable and sensor won`t be needed.
I haven`t got the focus to work out how to post pics here, so it you want to PM me an email address, I`ll send a pic of what my mate has done with his lynx/Vapour fitment.
David Hunn:
Old 07-26-2012, 03:01 AM   #129
Dakar83 OP
Dakar83's Avatar
Oddometer: 210
Hello Airhead Wrangler
Here is some more detail on that Magura Clutch
Part numbers included
  • 0120655 - Slave cylinder
  • 0120575 - Master cylinder 10.5mm Piston, Big space for switch, to be used with 1045mm length hose
Old 07-26-2012, 06:41 AM   #130
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,581
SWEET! Thanks. The hose is really that short, huh? I'm not near a BMW clutch cable to compare, but when I saw the available lengths I figured I'd need something longer. Good to know. I also just found this design guide on venhill's site: http://www.venhill.co.uk/Downloads/HymecSelection.pdf
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler screwed with this post 07-26-2012 at 08:52 AM
Old 07-26-2012, 09:21 AM   #131
Airhead Wrangler
Adios Mexico
Oddometer: 6,581
...also any chance of snapping a photo of how he rigged up a long enough pull rod?
Old 07-27-2012, 10:40 AM   #132
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,210
The link worked for me. Try this one http://www.swt-sports.de/sess/utn155...dex.shopscript
Then look for part number 30143
That got it for me - thanks.
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 07-28-2012, 05:09 AM   #133
Dakar83 OP
Dakar83's Avatar
Oddometer: 210
The pull rod is extended at the join you see in this picture, Dave made up the extension. I will try and get some details and better pics
Old 08-01-2012, 04:54 AM   #134
Dakar83 OP
Dakar83's Avatar
Oddometer: 210
The important points for the clutch are master cylinder 10.5 to get enough travel on the actuator rod. Ten appropriate size mounting bracket for your left hand switch block clearance. The actuator rod was extended using a stainless steel spoke cut to length and threaded to allow join and fine adjustment. Coupling is brass see close up below
Old 08-01-2012, 06:07 AM   #135
Airhead Wrangler
Adios Mexico
Oddometer: 6,581
I thought that looked like a spoke. Thanks for the writeup on that. I may add that to my list of eventual improvements.
Times are GMT -7.   It's 07:49 PM.
