Old 05-09-2012, 01:17 PM   #91
blackSP
62 6c 61 63 6b 53 50
blackSP's Avatar
Oddometer: 454
Guys, I say at KTM_OEM & Custom Tune_list that the 2012 SMC R maps for akra are out.
I guess the Enduro R will be next with days.
Update:
I just flashed the 2012 akra map on the 690 with akra header and foam duo filter with original airbox with snorkel PLUS a stoking over the intake and the result is perfect! No more stalling, very strong pull, revving is perfect, all good! You can flash it :)
2014 KTM 450 EXC - 2013 Harley-Davidson XL 1200 C
b l a c k S P e c i a l s
blackSP screwed with this post 05-10-2012 at 11:15 AM
blackSP is offline   Reply With Quote
Old 05-17-2012, 05:18 AM   #92
m0ng00se
Oddometer: 10
Originally Posted by Bartron View Post
KM765EU11B0231FIMap.hex and EPT map - This is the 'Akro' map for the 2011 models with the updated throttle bodies. The EPT map is same as the previous 'Akra' maps. The FI map is different which makes sense given the new throttle bodies.
REVIEW: We have just loaded this onto Getafix's bike and plan to make the changes as above and will report how it goes. This map is not widely available and I was unable to attach it as a zip file for everyone but will email it to TuneECU.
Hi Bartron,
Just wondered if you guys ever did load this map with the changes outlined in your post ? If so, how did it go ? I have 2011 Enduro R with Akra pipe, but bike stalls at least once a day, especially in slower traffic.
m0ng00se is offline   Reply With Quote
Old 07-07-2012, 06:29 PM   #93
Bartron OP
Bike Punisher
Bartron's Avatar
Oddometer: 713
Originally Posted by m0ng00se View Post
Hi Bartron,
Hey Man, we did try them out. The guys report smoother initial throttle action, strong low-end but with some loss of top-end. I guess that would be a compromise between usability and raw top-end race power. No complaints from the boys yet.
The nice thing is that you can always flash the ECU back to stock.
Ride on.
:: Furious Basterds: Velox, Vehemens, Oblivio
:: "For those who don't understand, no explanation is possible. For those who do, none is necessary."
Bartron is offline   Reply With Quote
Old 07-25-2012, 02:55 PM   #94
Sliverpicker
Sliverpicker's Avatar
Oddometer: 179
I just picked up the 2012 690R enduro. Went with the Leo Vince with spark arrestor, foam UNI and had it remapped from the dealer for $45. No more stalls, smoother throttle, no more jerky stuff on the lower rpm, pull is noticeably stronger and now I get third gear wheel loft without even trying. I got rid of the vapor can and the SAS crap following the instructions from "Code Orange" and it worked great---I feel better about loosing all that B/S that can go wrong. I can now smell real exhaust from the pipe and the motor does "NOT" have to breath that hot air from the motor-------
Next mod is to bypass the 2nd 3rd gear limiter----things should get better soon.
Great thread and thanks for the professional advice
Cheers
Sliverpicker is offline   Reply With Quote
Old 08-15-2012, 04:36 PM   #95
vegemanNZ
Oddometer: 53
Cheers
Hey, good stuff on unplugging the machine. I have Leo Vince and Foam filter (ktm orange but seems identical to UNI), my airbox is also drilled to let more air in, and have had the akra race map loaded.
I beleive, but hard to confirm, that this factory map supposgets rid of the 2 & 3 gear restricter so that may be already allowing the wheelies to occur :-)
2008 KTM 690E - Adventurotard - forget dual sport, get triple sport!~
vegemanNZ is offline   Reply With Quote
Old 09-22-2012, 09:44 AM   #96
pwh
Just Farkin' GO
Oddometer: 61
Just wanted to say thanks for all the great info! This morning I installed a LV slip-on and used TuneECU to upload the Akra map with your recommended changes. Bike pulls 3rd gear power wheelies going downhill now! Runs great! If you ever come to NYC I'll buy ya a beer!
pwh is offline   Reply With Quote
Old 08-05-2013, 08:45 AM   #97
Sethro303
Master of Disaster
Sethro303's Avatar
Oddometer: 354
Subscribed!!
I just picked up an 08 690 and there are some great tech write ups here!! Subscribed!!
08 KTM 690 Enduro
http://www.urbandictionary.com/
Sethro303 is offline   Reply With Quote
Old 10-27-2013, 12:40 PM   #98
El Ponkin
Bloodrunner
El Ponkin's Avatar
Oddometer: 2,113
Do you guys have the 'THAD' and 'APAD' voltages for the 2011 model ?
I want to check out my settings but I only have the Repair Manual for 2008 and can't find a 2011 Repair Manual.
Andy
Don't Tempt Fate Taunt It, Right Here Right N0W
KTM 690 EVO 1 Rally Raid Build Thread
KTM 690 EFI Idiots Guide
KTM 690 Troubleshooting Guide
El Ponkin is offline   Reply With Quote
Old 01-10-2014, 07:43 AM   #99
coarsegoldkid
coarsegoldkid's Avatar
Oddometer: 626
It would appear that this thread has lost it's life. I may be posing a question that no one will see. Here goes. I want to move the underseat map switch capability to the handlebars. Page 1 of this thread mentions the use of a Leo Vance switch to do just that. However I find no such switch for the 690 on their web site. Also other makers of KTM map switches indicate that they are for changing the ignition timing. This compounds my confusion as the underseat switch on the 690 deals with fuel mapping. However a switch is a switch and perhaps it can be adapted. The question: What device are you using?
'05 BMW R1200RT
'13 KTM 690 Enduro R
Ride tales
Utah / Colorado http://tinyurl.com/lcy2yhu
Mexico http://tinyurl.com/lhgznun
coarsegoldkid is offline   Reply With Quote
Old 01-11-2014, 06:25 AM   #100
DirtJack
DirtJack's Avatar
Oddometer: 1,600
Here's a post from the new mega-thread which has info you may find useful about the dirt bike map switches when used on a 690. They are plug compatible but do not offer the option of the standard map. The standard and "wild" do produce the same power but give it less abruptly. I think it is useful to have the poor fuel option as I usually use the "wild" rather than standard.
Also, ignition advance is a part of the maps, so those are changed too. The 690 TuneECU thread contains information about how one could change which map number is associated with which map option.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 04-27-2015, 02:15 PM   #101
markwoodlief
markwoodlief's Avatar
Oddometer: 3,680
bartron, I'm assuming that these mods to the map will work with a 2012? Not the actual map but the other changes?
Thoughts?
2012 690 Enduro R
markwoodlief is offline   Reply With Quote
Times are GMT -7.   It's 04:08 PM.
