Old 07-29-2012, 10:24 AM   #61
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Yeh, I was thinking of scoring some hubs to lace it to 17"s but I wanted some bigger rotors without buying a specific kit $$$
Will see.
I have been using powersportsplus.com, pretty much the cheapest, fast delivery (even when it stops in customs)
and reliable. Small parts is only around 12euro in shipping.
SlickSix is offline   Reply With Quote
Old 07-29-2012, 10:26 AM   #62
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Originally Posted by mcma111 View Post
Years ago when I first started hanging out around Thumper land on ADV I helped a fella whose XR600 transmission locked up and wouldn't shift. It turned out to be the real fine spring on the shift shaft.
Gearshaft Return Spring # 24624-MT3-000
Yup, thatīs the one I was thinking.
Old 07-29-2012, 10:39 AM   #63
deejay_xr
deejay_xr's Avatar
Oddometer: 496
Will see.
Yeah oversized rotors for XR hubs are a little rare, therefore expensive. I had the luck of buying a set of sumo wheels complete with entire front brake set-up
I'll remember that site !
'87 XR600R, 17's and fully black
deejay_xr is offline   Reply With Quote
Old 07-29-2012, 11:20 AM   #64
SlickSix OP
SlickSix's Avatar
Oddometer: 185
A pretty penny indeed. Iīve seen used sumo sets going for around 500e
Not going to happen, my grandpa always side "If I can make it, why buy it?" and I live by it
one to you grandpa
Iīll keep an eye on ebay and if something turns up cheap , Iīll snacth it.
Old 07-29-2012, 11:23 AM   #65
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Some small updates on the Donkey.
The clutch basket is pretty notched, but I have to run it as is for now.
A small smoothing should keep me happy until I find a better one.
Old 07-29-2012, 11:28 AM   #66
SlickSix OP
SlickSix's Avatar
Oddometer: 185
All new bearings, thanks to my brother in law
He works in a machining/tooling factory and got me ALL the bearings, including the Honda so called
specially ground bearing, and seals, except for the small one in the clutch arm, Kudos to the man.
Old 07-29-2012, 12:32 PM   #67
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,223
Any chance we can get some of that action over here?
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 07-29-2012, 01:05 PM   #68
elsalvadorklr
southern xr rider
Oddometer: 4,154
my clutch basket was exactly the same
the correct way of repairing this is to use a flat file and sandpaper and go against the grain of the "grooves"
you would never imagine I had nothing but a new clutch in my bike as its baby butt smooth
with sandpaper only you have the issue of possibly taking too much material off...or leaving a non flat surface
another trick is to grindd the metal plates (in a circular fasshion) on the clutch pack on a glass window with very coarse sandpaper and then aligning them in a pattern different to when they came off the bike
this will give you A LOT OF EXTRA MILES on an otherwise USED clutch system
cheers
elsalvadorklr is offline   Reply With Quote
Old 07-29-2012, 01:42 PM   #69
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Hey cristian, thanks, thatīs my method I do it with sandpaper and it only touches the
high spots so itīs all good. Iīve done that to my CBR clutch and after 15k itīsstill holding smooth.
Tha clutch plates already got the treatment
Old 07-29-2012, 01:43 PM   #70
SlickSix OP
SlickSix's Avatar
Oddometer: 185
What do you mean? the bearings?
Old 07-29-2012, 03:04 PM   #71
elsalvadorklr
southern xr rider
Oddometer: 4,154
well thera ya go...
awesome
I like honda clutches,,,they last
Old 07-29-2012, 06:58 PM   #72
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,223
Yup. I'm scared to look up honda prices.
Old 07-30-2012, 08:40 AM   #73
elsalvadorklr
southern xr rider
Oddometer: 4,154
left crank bearing about 50
right or special bearing 70
cs bearings about 30
other assorted another 50...
something like that jajaja
Old 07-31-2012, 12:12 PM   #74
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,223
yeah, taht's why. If I can get err thing for about a hun USD, I'd like that.
Old 08-05-2012, 09:02 AM   #75
SlickSix OP
SlickSix's Avatar
Oddometer: 185
Just posted this in another thread but if you can help, Iīd be apreciated.
On the left side crankcase cover, thereīs a small recession where the little dowel
that actuates the clutch pushrod, sits. Can you confirm that the recession on the cover
is completely cilindrical without any irregularities?
Itīs where the piece #11 sits and I had a hell of a time removing mine. So much that I broke
it. Only now realized that the recession on mine is not completely round.
Times are GMT -7.   It's 07:25 PM.
