Old 07-19-2012, 09:27 PM   #31
390beretta OP
Oddometer: 605
Again, thanks to everyone....lots of good suggestions!
390beretta is offline   Reply With Quote
Old 07-19-2012, 10:18 PM   #32
RVDan
RVDan's Avatar
Oddometer: 1,634
I have one helmet that I had to put a strip of foam weatherstrip on the inside of the top of the faceshield to finally get rid of the wind turbulence noise. My current go to helmet I've put a strip of black electrical tape folded over the edge top and bottom which made it just right.
Sometimes wheelies happen
Originally Posted by RedRocker
You can never have too much hook.
RVDan is offline   Reply With Quote
Old 07-29-2012, 07:40 AM   #33
french horn
Just Add venture
Oddometer: 339
Earplugs .... nothing better than these ... in my opinion anyway
http://www.earmold.com.au/Insta-Mold...-Earplugs.html
french horn is online now   Reply With Quote
Old 07-29-2012, 08:13 AM   #34
perterra
perterra's Avatar
Oddometer: 6,729
Originally Posted by Chiriqui Charlie View Post
Yes, seriously. I generally don't cruise any faster than 60-65 mph, and with the visor closed or open a fourth of an inch I get no "whistling" noise, but I hear the wind the same as when I used to wear a ½ helmet. Brand is Shaft, I bought it only because it was the only modular I was able to find in the entire country that fit me!
Some bikes it's more a problem than others. I never wore plugs on my Goldwing, dont leave home without them on the KLR. Other bikes have been hit or miss, needed them on some rides, not others.
You know, a long time ago being crazy meant something. Nowadays everybody's crazy
IBA 22425
perterra is offline   Reply With Quote
Old 07-29-2012, 11:46 AM   #35
AZbiker
Crunkin' with crackers
AZbiker's Avatar
Oddometer: 6,916
I had Al Schibi make me some custom plugs.
He lives in Mesa, AZ.
customearplugs@cox.net
4 years later they are still holding up well.
rubber side down,
derek
http://azbiker.smugmug.com
Got SmugMug? If not, save some cash and use my code: McYdbycdcvM5Q
AZbiker is offline   Reply With Quote
Old 07-29-2012, 12:13 PM   #36
Pantah
Red Sox Nation
Pantah's Avatar
Oddometer: 8,922
I had some custom plugs made too. They were a bust because they hurt after awhile. They were the type where they make a mold and the plugs come in the mail a couple weeks later.
My solution has been the 'gummy bears' soft earplug you get at any CVS or Walgreens. But they are somewhat fiddly to install and remove. Still, they are the most effective and comfy for me.
Yesterday I bought a custom silicon gel insert. $70. They made them on the spot and I took them home to 'cure' for 24 hours. It's early but I think these this will be the bomb! They look like shit, but seal off the sound and sort of clip into your ear cartilage to you have a solid seal. Plus there is zero 'extension' to the plug that causes a problem with your helmet.
It's called 'Insta-mold process for ear protectors for noise and water.'
Boulder CO. I think they license locals to make them. I got mine at Moto Market in Acton, MA, which is a high end gear store.
Motomkt.com
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
Pantah is offline   Reply With Quote
Old 07-29-2012, 12:36 PM   #37
AZbiker
AZbiker's Avatar
Oddometer: 6,916
Motomkt.com
That is the exact product that Al sells. E. A. R. Insta-mold.
And that's how Al makes 'em, you have to kind of swivel them into place.
rubber side down,
derek
Old 07-29-2012, 02:26 PM   #38
390beretta OP
Oddometer: 605
Thanks guys. I have some custom made molded plugs that I used for years while shooting competitive shotgun. Those are the ones I was wearing when I didn't hear the cop siren until it was a couple car lengths behind me. (I can stand around all day next to shooters shooting 12 ga. shotguns and they're fine) That's why I thought they cut out too much sound. You may want to test yours. Thanks again.
Old 07-29-2012, 07:22 PM   #39
AZbiker
AZbiker's Avatar
Oddometer: 6,916
I've tested mine with 4 years of commuting, 2 in the central 602...
I can hear just fine. They don't block as much noise as a fresh pair of yellow foam EARs, but they block enough.
rubber side down,
derek
Old 07-30-2012, 06:02 AM   #40
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 9,774
I have trouble finding earplugs that don't cut way too much noise. Most of the basic foam plugs are 32-33 npr rating and when they fully expand, I can't hear shit. At all. It doesn't help that I have extremely narrow ear canals -- so when a plug expands in my ears it may still be more compact than it would be in somebody else's ear and cutting more noise.
The only thing I've found that are acceptable are called "Traffic cones" and they are made for people who work in noisy environments but still need to hear warning noises, sirens, horns, etc, like some road construction, shop floor, etc. I think they are 28 npr or something like that.
As a plus, they also look like miniature traffic cones...
I have a lot of trouble remembering to wear my plugs though.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 07-31-2012, 11:17 AM   #41
glenn2926
Oddometer: 43
Modular helmets
Hi,
Can anyone tell me what a modular helmet is? I don't think we have them here in the UK.
glenn2926 is offline   Reply With Quote
Old 07-31-2012, 12:26 PM   #42
slide
A nation in despair
Oddometer: 21,040
Originally Posted by glenn2926 View Post
Hi,
they are the kind where the chin bar flips up to over the top of the hat giving it, while flipped up, the look of an open faced helmet.
http://motodirect.com/category-all/1...e-Helmets.html
Why be born again when you can just grow up?
slide is offline   Reply With Quote
Old 07-31-2012, 12:33 PM   #43
ScootTour
Oddometer: 1,478
I have been reading the Motorcycling Touring Bible here lately and after reading about the authors permanent hearing loss from motorcycle riding for reasons he didnt think where a factor I now never ride without ear plugs regardless of which helmet I use. Even with the ear plugs you still hear more road occurances then you would if you were in a car plus the wind sound also affects your fatigue. I know I actually enjoy my ride a lot more when I have ear plugs in.
Anyway, most of your hearing loss comes from wind noise, not traffic noise and hearing loss can never be repaired.
ScootTour is offline   Reply With Quote
Old 07-31-2012, 12:36 PM   #44
slide
A nation in despair
Oddometer: 21,040
Hearing loss can be repaired in many cases, but of course, it's best not to subject yourself to it.
When riding long distances, I ear plug always (now). Although I use the max noise reduction I can find, I have no concerns about hearing needed traffic sounds or other safety oriented sounds. In fact, removal of the wind noise along with some attenuation of traffic noise results in the traffic noise being MORE apparent than when having to fight the wind noise.
Old 07-31-2012, 12:41 PM   #45
perterra
perterra's Avatar
Oddometer: 6,729
More about this please?
I went in to a hearing specialist a couple years ago because of hearing loss due to noise exposure, 40% in one ear, 30% in the other. He told me noise damage can not be repaired. Something new out?
IBA 22425
Times are GMT -7.   It's 08:26 PM.
