Old 07-30-2012, 09:05 AM   #1
One Less Harley OP
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 3,926
Breather hose for Final Drive
Planning to do the breather mod for the final drive on an R80 G/S. I plan on using the old breather with the center section knocked out. Then press in an insert a banjo bolt fitting from a brake line can be used to attack an old brake line for the breather hose. Not sure where to put the terminating end and if it needs some sort of filter or valve on the end. I'm thinking of terminating it in the airbox. Ideas and input are greatly appreciated.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 07-30-2012, 09:36 AM   #2
Airhead Wrangler
More tacos than you
Airhead Wrangler's Avatar
Oddometer: 5,206
There's a brass plug with a sensor well you can buy that fits nicely. The ID is threaded for a temp sensor, but it'll also take a banjo bolt. I ran the hose on mine up inside of the spine tube, no filter, just high and dry.
R80ST Gets The HPN Treatment
Ducati Pantah 500SL Rebuild
Seattle to TDF on an airhead
WTB R100R Mystic sidestand and mount.
Airhead Wrangler is online now   Reply With Quote
Old 07-30-2012, 09:43 AM   #3
One Less Harley OP
Oddometer: 3,926
where can I source the sensor plug???
ID-10mmx1.0
OD- 18mmx1.5
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 07-30-2012 at 10:26 AM
Old 07-30-2012, 10:52 AM   #4
supershaft
because I can
Oddometer: 6,211
If I rode those things through water crossings like some do I would most definitely vent my FD AND tranny to a higher spot. I would probably use brake line. 100% waterproof and is harder to yank apart than some setups.
supershaft is online now   Reply With Quote
Old 07-30-2012, 11:10 AM   #5
Airhead Wrangler
More tacos than you
Oddometer: 5,206
ID-10mmx1.0
OD- 18mmx1.5
I bought mine from touratech as I used to work just down the street from them. It was for their IMO computer and I can't remember what model bike it was for, but I remember them telling me it was the last one they had in that size and they wouldn't be getting more. Check on that though as it might've changed. Try googling oil drain plug temp sensor or something like that. I know touratech didn't make it. They bought it off the shelf somewhere. It's out there. Also, I wouldn't terminate it in your airbox, as that'll put it under vacuum and could eventually suck all the oil out of your swingarm into your final drive.
Old 07-30-2012, 11:13 AM   #6
One Less Harley OP
Oddometer: 3,926
found one on ebay but it'll cost me $28.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 07-30-2012, 12:28 PM   #7
walkingbear
walkingbear's Avatar
Oddometer: 2,910
dumb monday
Being stupid today .. but don't get it this morning.
You drill a hole in the new plug ? Attach a banjo fitting with hose vent?
  • Allows Easy Fitting Of An Oil Temperature Gauge
  • Sizes Available To Suit Most Applications
This handy adaptor allows the fitting of an oil temperature gauge without having to modify the engine sump. The sump plug adaptor replaces the existing oil drain plug and will accept sender units with either M10 x 1 or 1/8 NPT thread. Available in a range of threads to suit most applications, please check the thread size and type of your sump plug.
BMWMOA 82741 ABC 8418 75 R90S ,83 R100 nake (Baron) , 88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar ,05 K1200S (Gandalf)
walkingbear is online now   Reply With Quote
Old 07-30-2012, 03:35 PM   #8
One Less Harley OP
Oddometer: 3,926
I've looked around and found that some O2 sensor plugs will work, just have to tap it out to 10mmx1.0 or possibly the 1/8 NPT will work as I have that tap. These are about $7.00
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 07-30-2012, 03:48 PM   #9
AliBaba
AliBaba's Avatar
Oddometer: 304
They still have it: http://shop.touratech.com/vehicle-eq...s-m18x1-5.html
AliBaba is offline   Reply With Quote
Old 07-30-2012, 04:05 PM   #10
One Less Harley OP
Oddometer: 3,926
not stocked in USA, but if it were it would be $13, I think I'll try the O2 sensor plug.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 07-30-2012, 04:28 PM   #11
Airhead Wrangler
More tacos than you
Oddometer: 5,206
Just give them a call and tell them you want one. They should be able to order it from Germany for you. They receive big shipments all the time and it's nothing they couldn't just drop in with anything else they ship.
Old 07-30-2012, 06:37 PM   #12
One Less Harley OP
Oddometer: 3,926
I may think about making a few up with a hydraulic hose. if people would be interested let me know. If no one pipes up I'll just make one for myself.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 07-30-2012, 08:26 PM   #13
One Less Harley OP
Oddometer: 3,926
May order the tour tech ones as it's threaded for a 10x1.0 the other one found is 1/8 NPT and I'm not sure how well it will fit the 10mmx1.0 banjo bolt. I know the threads will get a little mangled, so probably need to play it safe.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 07-31-2012, 10:05 AM   #14
One Less Harley OP
Oddometer: 3,926
found a good alternative to the tour tech option, which will work out fine. just gonna make ten of these. Just as easy to order 10 as it is one, plus it will spread the shipping cost between 10 units. Got the brass adapter and banjo fittings, just need to figure out if the hose will be a hydraulic hose or a heat pressed on hose to the banjo fitting. Heat pressed hose will be cheaper, lighter and won't come off easily.
Pretty much will look the same as what AW has done.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 07-31-2012, 10:14 AM   #15
Airhead Wrangler
More tacos than you
Oddometer: 5,206
I just used some extra 1/4" fuel line I had lying around. I used the banjo fitting like a barb and just slipped the fuel line over it. It's a REALLY tight fit so nothing's getting in there. Just curious, where'd you find the plug? Just be careful that it's nothing too long as if it threads in too deep it'll grind on the crown gear. I remember it being a very close fit.
Times are GMT -7.   It's 09:45 PM.
