Old 06-26-2012, 07:02 AM   #61
J Lewis
Numb Nuts
J Lewis's Avatar
Oddometer: 510
I have the three different sets of wheels that I'm currently testing and just recently got my rotor situation dialed in so that I can switch back and forth simply. I wanted to have two bikes at the same time but that has not happened.
So yes, soon I'll tell you what I think but from looking at the post here I have to agree with most of the comments about the performance and changes to the ride feel of the bike.
Right now I can simply say that if off-road is more of a priority there is no reason to stop you from upgrading to a 21" front. Then the 18" rear balances the bike and gives a much better tire selection to match the better front knobbies.
What I'm feeling and need to compare is the stability of the bike in relation to the wheel flex as I feel a change even when I go from the stock wheel to a Woody's Superlace of the same size. But that is pretty detailed stuff most riders would not pick up on, yet I like to know in case I'm questioned about it. This takes a back-to-back comparison on the exact same conditions.
Hope this helps answer some of the questions.
JIMMY
J Lewis is offline   Reply With Quote
Old 06-26-2012, 07:18 AM   #62
outsidein
outsidein's Avatar
Oddometer: 437
Originally Posted by hasenwerk View Post
I think it is all what you are looking for. For the front, if I had to buy new I would go 21" - just because of the better off road abilities and the fact that a 90/90 21" is much cheaper than a 19" front - the old R100 / R80 GS had 21" as does the F800 - so that speaks some merit of the 21" - tubeless can most certainly be done using a R100 rim but they are not nearly as strong as the Excel rim.
The 17" rear is the way to go - I considered the 18" for my 1100 GS and my 30" inseam and the good choice of 17" rubber made me stay with 17"
All that being said I have a Woody's 21" front and an OE 17" rear on my bike - 90/90 21 on the front and 140/80 17 on the rear - tubes on both ends. I am happy with the whole setup!
90/90-21 on the front gives you better off road abilities but at the cost of worse on road handling due to higher trail and smaller contact patch up front due to loss of 30mm width with a 90mm tread.
outsidein is offline   Reply With Quote
Old 06-26-2012, 11:11 AM   #63
nanotech9
** Slidewayz **
nanotech9's Avatar
Oddometer: 1,435
JIMMY
Isn't it a little tough to notice a difference in WHEEL flex through those goofy mounted pivoting forks the 12GS's have?
How can you tell its not just an augmentation of the forks flexing (which is way to much!) caused by varying weights of the wheels/rotational mass/etc, which would have a direct effect on the amount the forks flex side to side as you turn the bars?
Just Curious.
NANOFAB ::: Custom Kydex & Metal projects
_________________________________________________
'05 BMW 1200GS
'04 KTM 525 EXC
'02 YAMAHA TTR 125
'99 KTM 50 ADV
'86 KTM 250 2-smoker resto-project
nanotech9 screwed with this post 06-26-2012 at 11:19 AM
nanotech9 is offline   Reply With Quote
Old 06-26-2012, 11:50 AM   #64
J Lewis
Numb Nuts
J Lewis's Avatar
Oddometer: 510
Don't know till I test them back-to-back.
I'm not talking about what you feel through the bars but how the bike reacts to the ground in a similar condition.
And a lot of this is the tire, which or course is very different as well. But this is why I try stuff out in the real world.
Old 06-26-2012, 11:54 AM   #65
CannonsvilleRider
Oddometer: 424
I am not Jimmy Lewis
but I thought he explained it well enough.
"I feel a change even when I go from the stock wheel to a Woody's Superlace of the same size. But that is pretty detailed stuff most riders would not pick up on, yet I like to know in case I'm questioned about it. This takes a back-to-back comparison on the exact same conditions."
CannonsvilleRider is offline   Reply With Quote
Old 06-26-2012, 12:33 PM   #66
bigdave-gs
Explorer
bigdave-gs's Avatar
Oddometer: 2,613
DAMN IT ! ! ! If I could afford to do this to my 1150 Adventure, I'd do it in a heart beat. Regular forks,21" front, jacked up suspension with my 7.8 gallons of fuel........ The lose of the telelever front has got to shave off 20+ pounds of weight. That bike would fit my 40" inseam perfect ! ! !
I wonder what it cost to convert the frontend like that?
I'd be unstoppable if not for Law Enforcement and Physics !
When your 6'8" with a 40" inseam, the bikes that fit you are limited ! ! !
2004 BMW R1150GS Adventure for street work / KTM 950 Super Enduro for Dirt work !
bigdave-gs is offline   Reply With Quote
Old 06-27-2012, 05:34 PM   #67
fudgypup
Oddometer: 2,199
Trade-in Woody's 17" rear for 18"?
So if i want to upsize to 18" in the rear, what should i do to protect my shock? I already wore a half dollar sized hole in the Meier inner fender running the 140/80/17 Mitas E09 Dakar so I'd imagine an 18" wheel is going to tear that thing up.
fudgypup screwed with this post 06-27-2012 at 05:40 PM
fudgypup is offline   Reply With Quote
Old 06-28-2012, 01:02 AM   #68
woody's wheel works
Built to Last
woody's wheel works's Avatar
Oddometer: 3,443
if ya want to trade...
hi fudgypup,,,i#m chiming in from BMW-land,,in old Bavaria,,,am just down the street from the big kahunas,,,no one over here seems interested in talking about there perfekt mmororrad,,,,so,i'll just keep on providing the discriminating riders some better solutions...
ya may want to give my guys in the shop a call,,,the place is constantly awash in folks wanting to trade/upgrade etc,,,they'll include your needs i our ne newsletter on the new website... telll em hi from the ol man
woody
PS,,so hint hint...yesterday,spent lunch in an amazing old cloister Klosterbräustüberl Reutberg...this lil pub making homemade brews for hundreds of years...tried this unfiltered,natural cellar beer as they described it,,a classic festival beer that was standard fare in other times to celebrate Aegidius...hence the Aegidius Trunk vom Fass...ie the Aegidius brew from the keg at cellar temperature on a hot day,,looking at the Bavarian alps,,over olling green meadows...it moved to the top of the list of my many beer discoveries over there...hint hint try all the local brews from the keg...ya won't be disapponted
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 06-28-2012, 01:14 AM   #69
Quirky
Quirky's Avatar
Oddometer: 586
[QUOTE=fudgypup;19007820]So if i want to upsize to 18" in the rear, what should i do to protect my shock? I already wore a half dollar sized hole in the Meier inner fender running the 140/80/17 Mitas E09 Dakar so I'd imagine an 18" wheel is going to tear that thing up.
QUOTE]
I've only run TKC-80's on my 18" rear and that inner fender had to go.
Didn't even try leaving it in place, same as yours with hole rubbed through with Tourance rubber on oem wheels.
New tyre fitted rubs the oem shock cover often, not bad and didn't bother me to much. Keen on other ideas as well, but think the standard plastic gaurd will mostly stop rocks trashing the chrome on the rod of shocky. The wiper seal will just have to deal with all the other crud.
Ordered some wilbers suspension for my new bike before putting my Woody's on and this might reduce the tyre/gaurd contact. Can't wait to try em out!
Cheers
BMW R1200GS, Yamaha WR250R
SPOT link
Quirky is offline   Reply With Quote
Old 06-28-2012, 05:45 AM   #70
fudgypup
Oddometer: 2,199
Thanks for the tips, guys. I will call over there and see what I can work out. I will ask them about an inner fender solution as well as 18" rubber options. 18" TT is very common, TL not so much.
I also have the Wilbers upgraded suspension (beemershop.com) and want to protect that investment.
As for beer, thats good info! I cant stand the beer over there normally; its all Heineken, Stella, etc... Euro-budweiser. I finally found some of that finer stuff at a restaurant in Berlin, Augustiner am Gendarmenmarkt. You definitely have to look for the better stuff. Ive been to more northern cities (Hamburg, Dusseldorf, Frankfurt, Berlin) but not Munich or southern Bavaria yet.
Old 06-28-2012, 05:02 PM   #71
EScott
Oddometer: 59
If you'd prefer a rather cheap/simple solution to protect your shocks (I had Wilbers on my R1100S and they were great) you could consider a "shock-sock" solution.. These are pretty much just a neoprene sleeve with a velcro closure that wrap around the shock to keep the crap out. Had one on a MTB and it worked great. Thinking about getting one to help preserve these silly expensive ESA shocks..
EScott is offline   Reply With Quote
Old 07-30-2012, 07:23 AM   #72
J Lewis
Numb Nuts
J Lewis's Avatar
Oddometer: 510
Wheel Size: Know Your Size
Well, I said I would get back to you guys on this and it took some time but here is what I found out.
If you have any specific questions post them up here and I should be able to answer them specifically.
With the varying sizes of wheels on adventure bikes and the availability of options to change the sizes on your bike, here are some of the performance affects you can expect with an off-road bias as tested on a 2008 BMW GSA 1200.
The wheels were provided by Woody’s Wheel Works so I could do the testing in a back-to-back fashion as to feel the differences while riding over the exact same terrain on a 15-mile loop I set up that included all types of dirt and a bit of twisty pavement. I tested with 26 PSI front and rear and used tires that I’m very familiar with as to eliminate that part of the influence on the wheels. Especially on the 21”/18” set. Then I rode with each wheel set for an extended period of time to get use to the character and further evaluate the ride.
Stock wheels: 19” front, 17” rear with Continental TKC 80s
-They come with the bike, they don’t cost extra.
-All around performance will be considered standard or average and comments will be compared to this setup.
-These wheels felt the heaviest and the least stable but some explanation is needed. Being heavy, they like to stay in line when the speeds increase, but during slow speeds they are more difficult to initiate a change of direction, it takes more rider effort. Then when you are at higher speeds it also takes more effort to change direction of the front wheel. The stability issue has to do with the weight getting out of balance as it goes farther out of balance before you feel it, then there is more work involved to get it back. Basically it takes longer to notice that you are slightly out of line and then it isn’t as easy to get back in line. For a rider who is not that aware of the balance, the heavier wheel will mask some of the out of balance feel but when it shows up it is more drastic. If you hit something at slow speed that deflects the wheel, it deflects easier too.
-The bump compliance was the worst of the three sets. You feel more through the bars and the wheels “bounce” more on the impacts. None of the wheels changed the performance of the suspension to a significant matter but I felt some slight tuning of the rebound damping could optimize each setup. This setup tracked the ground the worst.
Woody’s Superlace with Superlight Hubs, 19” front, 17” rear with Continental TKC80s
-The biggest advantage is the reduction in weight. Four pounds front and three pounds rear. You can feel it in two ways. First is in the changing of the direction and turning in the front wheel. It is a noticeable amount easier, especially at mid-speeds around 15-30 MPH. Then there is the reduction in bump feedback. Especially in the front the wheel does not feel like it pounds the ground as hard as the stock wheel does. It tracks better and worked the best with a lighter (less) rebound damping in the shocks.
-The GS feels lighter especially when it gets light on its wheels and during the rare times when it is in the air.
-The brake performance felt better and more initially responsive. But some of this could be attributed to newer Galfer rotors on the wheels.
-For the most part the performance was very similar in every other aspect.
Woody’s Superlace Superlight 21” front, 18”rear with Metzeler Karoo (and Pirelli MT21s)
-The advantage here is that the larger wheels are able to roll over bumps better and also give a wider selection of off-road tires too. And for sure the bump compliance is vastly improved and the front wheel feels more planted and rolls over rough terrain so much better it was shocking. The improvement was so good that if I did not have a KTM950 for my more “adventurous” riding, I would run this setup all the time. But beware; many knobbies are not even close to being up to the task of dealing with a 500+ pound machine, not to mention the high horsepower as well. The Pirelli MT21’s did some pretty funny things, mostly in carcass roll and that is why I switched to the Metzelers to eliminate variables.
-The disadvantage list includes a loss of contact patch for the front tire. It is most noticeable under breaking on the dirt where the brakes easily overpower the tire. For street performance the tire choice is more important since the knobs don’t deal with the weight too well. The more aggressive of a knobby you run will have an even bigger affect that the change in size alone. It is not as dramatic as I first suspected it would be but I did prefer a less aggressive knobby for all around riding due mostly to the compromise on the street. Off-road the 21” bites the ground better and grips harder and longer before sliding out but it goes out more suddenly when it does. In soft sand or mud the tire bites in better and because it rolls over things easier it also steers in these instances as opposed to floating and sliding.
-The front brake strength is minimized a little bit and this is noticeable on and off road. The brake does not overpower a less aggressive knobby like the Metzeler on the road as easily.
-The stability goes up, especially with speed but the steering seems to fall between the stock set and the Woody’s Standard sized wheels in stability. In slow speed the 21” front is easier to turn and it will shake, or become unstable easier when you are moving. The sensation is that the bike feels lighter yet it lets you know if you are out of balance quicker. The wheelbase gets slightly longer with this setup and the trail is slightly longer which plays into the stability’s favor, despite what it feels like to the rider. I tried the 21” front with the 17” rear and the bike felt too front end high and would take some ride height adjustment to get the balance where it should be. And it was very unstable like this.
-You must remove the under fender for proper clearance and this throws up mud that you may not be used to.
-With the different sized tires, especially the rear, the paralever ratio is a little off compared to standard. When on pavement setting into turns and then getting on the gas you can feel the rear of the bike rise ever so slightly. With a looser tire (carcass or due to knob flex) on the back it can even feel like the bike is setting up to go into a slide. The front end’s feeling of being loose in the connection between the bars the front tire on the BMW is lessened ever so slightly since the contact patch is smaller.
-One advantage/disadvantage is in the gearing because of the rear wheel size. I really likes the higher final drive ratio as it let the bike pull along faster and smoother at a low RPM on the highway, plus it spaced the ratios out so I got more out of each gear. The bike has plenty of power for this. The issue is the increase in first gear’s ratio gear being taller. In slow speed, very technical riding it takes more use of the clutch which for a lot of riders, especially off road, can be an issue.
J Lewis screwed with this post 07-31-2012 at 10:15 AM Reason: wrong names!
Old 07-30-2012, 11:44 AM   #73
J Lewis
Numb Nuts
J Lewis's Avatar
Oddometer: 510
One correction to the above is that the wheelbase does not change with the 21/18 set, but it feels like it does (gets slightly longer) and the seat height goes up just a bit. I did not measure the increase but I could tell. The bike does lean over just a little farther on the side stand but not enough for concern.
JIMMY
Old 07-30-2012, 12:19 PM   #74
kktos
on a bright side of life
kktos's Avatar
Oddometer: 2,345
Thumb
Excellent write up ;)
I have the "Woody’s Superlace with Ultralight Hubs, 19” front, 17” rear" and I agree. Good analysis.
Oh yeah !
that's true...oh very true !
But Woody's will find a solution...
Vita brevis, ars longa, occasio praeceps, experimentum periculosum, iudicium difficile
08 R1200GSA Red 21" woody's
morocco 2006 | morocco 2007 | Traces of Kimangao: An HP2 in France, Spain and Italy | Morocco 2008: a F800GS test ride | where the destination is Anamur - Turkey via Greece...
kktos is offline   Reply With Quote
Old 07-30-2012, 03:36 PM   #75
3horsepack
Oddometer: 53
I have Woody's 21" Excel on the front of my 1100 GS for well over a year now and truely think this is the way the GS should have been out of the box. Zero complaints! I also upgraded the girl friend's 2006 650GS to an Excel 21" from Woody as well.
The only issue that I have, and I would love to see example of how others have solved it is now that the bike is higher off the ground, what do you do about the way too short kick stand? I always thought the 1100 GS kickstand was too short to begin with but now I have to carry a wood 2x4 block on a string that is attached to my tank bag to put under the kickstand when I park the bike - sort of light weighing anchor! This with the Touratech aluminium foot on the kick stand too. Ultimately I would like to see it extended by 5cm (2") but if one was to do that, it would interfere with the center stand. I see on the 1200 GS the kickstand isn't straight like it is on the 1100/1150 rather a bit of a crook in it - anyone do something like this to their 1100/1150? With the extra fuel capacity of the Touratech 41L tank - I need to make sure my bike won't take a nap while it is parked.
I know this might be alittle late to pipe up but being the proud new owner of a 96 R1100GS I fixed that kickstand issue buy drilling a hole thru base of Kickstand to allow a for a 3/8 bolt to go thru and then welded a 3/8th bolt to the top and them attached the 2" dia 1" thick rubber stop off a horse trailer ramp and bolted it to the bottom. This increased the footprint as well as adding some length to the kickstand. Looks very similar to the one in this thread. Took about a half hour to install. Thanks
3horsepack is offline   Reply With Quote
Times are GMT -7.   It's 11:01 PM.
