Old 08-02-2012, 03:03 AM   #151
FreeTheBeast OP
Shunpiker
FreeTheBeast's Avatar
Oddometer: 3,046
Thumb Thanks.
Thank you for your perspective. The bolt-on option certainly might be a little easier. Tapping holes in the motor - I suppose one had better do it right the first time.
Originally Posted by Voltaire View Post
My engineer mate makes these,I have a set on my bike.
The sleeves are tapped and go thru the motor. The rear mounts get drilled and tapped when you line up the engine/box/swingarm to your liking. All the original engine covers still fit too but you need to move the coils a few mm.
Raises the front up about 30mm.Overlap on shaft/final drive is reduced by about 5-8 mm.
I have touched the RH head down on a few occasions as I'm not much of a hanger offer....( maybe I need a set of Continental )
We tried out the welding method on a stuffed frame but decided the bolt in one would do as racer may go back on road one day....
Think beyond yourself.
The Hampster Ride - A mainly dirt route to ride the length of New Hampshire.
Max the Motorcycle - children's book written by Mrs. FTB
SmugMug Photo Gallary
FreeTheBeast is offline   Reply With Quote
Old 08-02-2012, 03:09 AM   #152
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,320
I think you read that wrong.
Where do your motor mounts go now?
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is online now   Reply With Quote
Old 08-02-2012, 10:25 AM   #153
FreeTheBeast OP
Shunpiker
Oddometer: 3,046
The usual places...
My motor mounts are still in the stock positions now.
Old 08-02-2012, 11:46 AM   #154
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,634
The bolt on ones have threaded 12mm aluminium sleeves that replace the motor mounting studs, The rear frame mount has been left undrilled/tapped to facilitate correct engine/tranny/drive alignment.
I like it as its non invasive and can be reversed if bike is not longer on race duty.
Voltaire is offline   Reply With Quote
Old 08-02-2012, 03:18 PM   #155
FreeTheBeast OP
Shunpiker
Oddometer: 3,046
Question shim-sham
So is shimming the driveshaft not required? I thought I read somewhere that some shimming was required when raising the motor.
Old 08-02-2012, 03:29 PM   #156
supershaft
because I can
Oddometer: 9,116
Some people move the engine forward as well as raise it. I probably would.
Remember that the engine is stressed on our bikes and a very important part of frame rigidity. That kit seems like it would negate some of that.
Old 08-02-2012, 03:47 PM   #157
LoJack
LoJack's Avatar
Oddometer: 1,605
Supershaft, It looks like it will move the engine forward about the same amount.
LoJack is offline   Reply With Quote
Old 08-02-2012, 03:49 PM   #158
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,550
You want to keep the u-joint of the driveshaft in the same spot vertically that it was before. The driveshaft is free to move up and down on the front end, but at the back the splines in the final drive are fixed. If you move the driveshaft forward or backward, up or down, you're changing the axis of the driveshaft in relation to the rotating axis of the final drive input spline. The only way these two can remain coaxial throughout the suspension travel is if the u-joint at the front of the driveshaft is directly inline with the pivoting axis of the swingarm. Not watching out for that will result in undue wear on your final drive input and drive shaft splines. Since the whole mess is drenched in gear oil, the wear probably wouldn't be that rapid though.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler is online now   Reply With Quote
Old 08-02-2012, 04:32 PM   #159
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,634
Its bolted in to the lower frame but its not really a stressed member like a Ducati of K series...imho.
Probably looking at a top mount at some point but at this stage the handling is fine for the power its putting out....what ever it is.
Old 08-02-2012, 04:40 PM   #160
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,634
Good points I had not concidered.The drive shaft is bolted up to the gearbox flange as per normal, its the other end that has its overlap reduced.
But yes the u joint is no longer is sync with the swingarm.
It is however more lined up than the stock set up.......ummmmm
The reality for my bike is that it only does not do a lot of miles per year.
I was wondering if as its a race bike am I losing power churning all that EP 90 around in the box and FD.....could I go to lighter oil?
Old 08-02-2012, 05:51 PM   #161
noman
Oddometer: 905
whazzat?
i don't know anything about jacking a motor while moving it forward, but marcus does (pic on page 2). we were yakking about his bike at the okemo event (nice build btw) and he mentioned swapping out the driveshaft from a different model for a specific reason that i forget now.
i'll be seeing him and the gang saturday, more racing.
1976 r75/6 -- mine since 1980, thx lloyd!
1985 vf500f -- v4, 6 spd, 16v, triple discs, water cooled
1997 900ss -- full sp spec
noman is offline   Reply With Quote
Old 08-02-2012, 06:00 PM   #162
FreeTheBeast OP
Shunpiker
Oddometer: 3,046
Laugh Later model swing arm
Marcus likes to use a later model swing arm. It's bigger. USCRA doesn't allow swing arm bracing. A later swing arm provides more robustness without using a brace.
I bought most of my bike from Marcus. He has many suggestions. Some of them good ones. He does prefer the RaceLine kit. He will be at Okemo this weekend, as will I.
Old 08-02-2012, 06:06 PM   #163
supershaft
because I can
Oddometer: 9,116
Our engines are stressed members just like K engines or Ducati engines. I would weld my raised engine mounts and stress the engine properly. You move the engine forward by making an aluminum spacer between the drive shaft and the tranny. Why? To move the weight bias forward. Just raising the engine moves it reward slightly. That they do not need. The spacer is pretty easy to make and you can keep the pivot point and the drive shaft real close to where it is originally. Then you run the drive shaft dry. I have worked on race bikes thusly set up with tons of track time no problem.
Old 08-02-2012, 06:12 PM   #164
FreeTheBeast OP
Shunpiker
Oddometer: 3,046
Wicked corresponding data
http://www.bmwmoa.org/forum/showpost...7&postcount=16
Seems to make sense.
Old 08-02-2012, 07:56 PM   #165
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,634
Ah Vansen now he's a guy who knows lots about BMW's, and what he says is correct...hence the rear holes in my mounts being undrilled until alignment is done.
Times are GMT -7.   It's 11:17 PM.
