Old 08-03-2012, 08:43 AM   #46
Shocktower
Shocktower's Avatar
Oddometer: 9,466
How can my squish be determined, to what it should be .
A little about my bike 1979 RD 400 with new TM 28mm carbs Moto Carerra Millinum pipes, stock porting
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower is offline   Reply With Quote
Old 08-03-2012, 01:55 PM   #47
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,261
http://www.rb-designs.com/squish-band-test.htm
dunno what good squish for rd400 would be - i would assume between 1.2mm and 1.6mm. the shape/area of the squish is as important as the measurement at the edge of the squish band.
current bikes
stainlesscycle is offline   Reply With Quote
Old 08-03-2012, 03:47 PM   #48
Shocktower
Shocktower's Avatar
Oddometer: 9,466
That guy is local I may need to take my bike parts there
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower screwed with this post 08-03-2012 at 03:53 PM
Old 08-03-2012, 06:52 PM   #49
stainlesscycle
Oddometer: 2,261
do it. he's excellent.
current bikes
Old 08-04-2012, 12:01 AM   #50
supershaft
because I can
Oddometer: 9,116
That's exactly how I measure it. Way better than clay. You can do it through the spark plug hole on some engines.
Old 08-04-2012, 12:12 AM   #51
willis 2000 OP
neo-quixote
Oddometer: 3,531
To lessen the squish clearance, wouldn't it work better to machine the head gasket surface of the cylinder?
Or the base gasket surface if one wanted to tone down a hard-to-ride power delivery?
willis 2000 is offline   Reply With Quote
Old 08-04-2012, 01:19 AM   #52
Twin-shocker
Oddometer: 1,673
In some cases there is no need for any sort of machining at all. Removing head and base gaskets is all you will need. I would be very cautious over using someone offering to machine heads on the basis of solder, for the simple reason that if the solder test isnt done perfectly then neither will the head machining. Taking the motor to someone who knows exactly what they are doing is the only real option for this type of work, but in most cases closing the clearance by the 1mm that will be provided by removing the gaskets, will be all thats needed on roadgoing motors.
Old 08-04-2012, 01:40 AM   #53
willis 2000 OP
neo-quixote
Oddometer: 3,531
What will be used to seal the cylinder? I imagine machining will be required to square up the contact points.
Old 08-04-2012, 02:28 AM   #54
stainlesscycle
Oddometer: 2,261
if you remove the base gasket you change exhaust port height and to a lesser effect intake/boost port height.. machining the head (or removing head gasket/using thinner head gasket) is the only way to modify squish without affecting port timing. most water cooled motors (and many air cooled) don't have head gasket, so head machining is the way. you can modify squish by changing the base gasket stack, but it will effect port timing, sometimes enough to have a drastic effect on the top end rpm - not always in a good way.. you can easily lose massive top end hp if your exhaust port doesn't open all the way due to no base gasket.
solder check works fine. there is a reason he asks for 3 solder samples. repeatability. it's kinda hard to do it wrong.
also, most are not just decking the head. the head gets reshaped to get better squish, and optimum combustion chamber volume. there's more to it than just turning off some of the head to cylinder mating surface.
current bikes
stainlesscycle screwed with this post 08-04-2012 at 02:36 AM
Old 08-04-2012, 02:34 AM   #55
stainlesscycle
Oddometer: 2,261
jetting and ignition timing ( and power valve adjustment - if it's got one) can adjust hard to ride power delivery. and it's reversable...
current bikes
Old 08-04-2012, 05:58 AM   #56
Twin-shocker
Oddometer: 1,673
Running without a base gasket tends to improve mid range torque and low end pick up, but the effects of this are likely to be hard to detect on road going motors. On air cooled 2T bikes which have head gaskets, in most cases its possible to run without, after lapping the head to the cylinder using fine grinding paste, and using high temperature silicone sealer on both top and bottom deck faces when building.
The main thing in favour of seeing how a bike runs without the gaskets, is that it costs very little to do, and unlike bodged machining jobs, is not going to mean a need for new parts, if there is a need to go back to stock set up.
Whether someone provides 3 or 300 pieces of crushed solder to indicate what squish clearance they might have, isnt going to alter the fact that if measuring using this method hasnt been done properly, the results are going to be far from accurate, which kind of gets away from the point of adjusting the clearance in the first place.
Old 08-04-2012, 07:29 AM   #57
stainlesscycle
Oddometer: 2,261
there are so many wrong statements in your post, i'm not gonna bother.
current bikes
Old 08-04-2012, 09:34 AM   #58
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,193
For sealing a head without a gasket. EC Birt's solution back in the day was to go to a paint store for a can of silver paint, he would reach back and get the one that has been sitting undisturbed for the longest time. Without disturbing the paint he would drain off all of the can's contents but the gooey residue paste at the bottom. He would "paint" the gasket surface with this goo to create the seal.
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline   Reply With Quote
Old 08-04-2012, 01:06 PM   #59
Twin-shocker
Oddometer: 1,673
Seems to work very well in the real world, so glad you didnt bother to reply from the perspective of a Google Gary.....................
Old 08-04-2012, 02:33 PM   #60
stainlesscycle
Oddometer: 2,261
i don't google shit about tuning. so much bad info out there.
current bikes
Times are GMT -7.   It's 10:31 PM.
