Old 08-05-2012, 10:21 AM   #1
WitchKing OP
WitchKing's Avatar
Oddometer: 56
Question Testing for spark, by myself, on a kickstart.
Is it possible to test for spark by my self on a kickstart only '76 honda mt125? Just got a brand new coil.
Sure it's quiet, for a diesel. But that's like being well-behaved... for a murderer.
-Jeremy Clarkson
WitchKing is offline   Reply With Quote
Old 08-05-2012, 10:28 AM   #2
Shocktower
Shocktower's Avatar
Oddometer: 9,480
Hold the plug kick it over Ok don't really hold the plug just the cap and look for a spark, low light helps, keep the anode that little bent metal piece toching the head or any other place it will ground
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower is offline   Reply With Quote
Old 08-05-2012, 10:34 AM   #3
blaine.hale
blaine.hale's Avatar
Oddometer: 3,167
Don't hold the plug unless you enjoy a good shock. If you want to see the spark, pull the plug, reattach the spark cable then ground the plugs threads against the cylinder. Either kick it or use your hand to kick it. You can safely hold the rubber boot that goes on the spark plug as you hold against the cylinder, or just find a place it will rest on the head.
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is offline   Reply With Quote
Old 08-05-2012, 05:42 PM   #4
WitchKing OP
WitchKing's Avatar
Oddometer: 56
Would it stay lit if I hold down the plug?
-Jeremy Clarkson
Old 08-05-2012, 06:53 PM   #5
JeffS77
cheap bastard
JeffS77's Avatar
Oddometer: 3,372
lit ??
it sparks
JeffS77 is offline   Reply With Quote
Old 08-05-2012, 11:14 PM   #6
PistonPants
Crankcase Scavenger
PistonPants's Avatar
Oddometer: 443
Physically look at the plug gap as you kick it. If you cant do that then hold the plug.
Piston
PistonPants is offline   Reply With Quote
Old 08-06-2012, 12:19 AM   #7
Twin-shocker
Oddometer: 1,673
The way to test for spark is to remove the plug cap, and position the end of the cable around 6mm away from an earth point (you can sometimes fit the cable between 2 fins on the head).
Never a good idea to have either the cap or plug involved when testing for HT spark as both parts can fail, and lead you to think there is a major problem when there isnt.
Old 08-06-2012, 12:08 PM   #8
Sturgell
Urban dirtbiker
Sturgell's Avatar
Oddometer: 81
http://www.sears.com/shc/s/p_10153_12605_00914130000P
Find a spark tester, if you work on small engines at all it's a handy thing to have.
That's not how you change a tire. He's suposed to be flailing around on a nasty garage floor with those cheapo 8" irons the rest of us have.
Sturgell is offline   Reply With Quote
Old 08-07-2012, 06:39 AM   #9
blaine.hale
Oddometer: 3,167
Totally overkill.
1974 BMW R90 /6
Old 08-07-2012, 07:11 AM   #10
Leo.G
Is still learning
Leo.G's Avatar
Oddometer: 393
Nah!
You don't need any kind of special tools for doing that, pull the plug, then put it again in the cap, hold the cap with the plug on it and make the "hook" of the plug touch some iron/steel part of the bike, like the frame...
Then, move the crank with the kickstarter, and check if there is any kind of spark between the electrode and the little "hook" in the plug..
The best sparks are the blue ones..
Good luck with that!
Greetings from Argentina!
2010 Honda XR 250 Tornado
Leo.G is offline   Reply With Quote
Old 08-08-2012, 12:26 AM   #11
Twin-shocker
Oddometer: 1,673
If you test for spark with cap fitted and the cap itself is faulty then you wont have a spark. Lots of home mechanics back this mistake and spend lots of time and money on parts that arent needed, when all that was required is a new cap.
Old 08-13-2012, 04:36 PM   #12
WitchKing OP
WitchKing's Avatar
Oddometer: 56
Pissed
kay, no spark. tested for continuity from the frame to the coil, from the coil to the beginning of the wire to the cap, and it's all good, then I tested the spark plug with one lead on the part where the cap connects, and one on the other end, not on the side electrode, on the center electrode, and nothing. bad plugs? (please) and what i meant by stay lit was does it keep sparking, or is it just for a second?
-Jeremy Clarkson
Old 08-13-2012, 04:56 PM   #13
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,270
if it stays sparking like a sparkler when you're not kicking it, let us know
current bikes
stainlesscycle is online now   Reply With Quote
Old 08-14-2012, 10:10 AM   #14
2trally
User Awaiting Email Confirmation
Oddometer: 62
I think you need to check for resistance in the plug wire instead of just continuity. If resistance gets too high in the wire, you won't get spark, but still show continuity. I've never tested a spark plug before, but if you think thats the problem just get a new one and test it.
It shouldnt stay lit, just a flash.
I'm not much help I can't remember this shit properly, used to know it pretty well but its been a few years.
2trally is offline   Reply With Quote
Old 08-28-2012, 06:01 PM   #15
WitchKing OP
WitchKing's Avatar
Oddometer: 56
The plug wire is brand new, it came with the coil. I got new spark plugs, still no spark. What's next? Stator? anybody know where to get one cheap?
-Jeremy Clarkson
WitchKing screwed with this post 08-28-2012 at 06:06 PM
Times are GMT -7.   It's 05:26 PM.
