Old 08-10-2012, 02:29 PM   #1
HalfPlate OP
What? Where?
HalfPlate's Avatar
Oddometer: 1,046
GS Trophy Challange Bike Prep
A fellow ADV Rider and I will be competing in the 2012 GS Trophy Qualifying at the end of September and I wanted to hit up the knowledge bank that is the GSpot for some advice. I am looking for advice on tires, things to remove, things to add, etc....
Here is the fun part!! -- If you had to set-up a 07 GS1200 for 3 days of off road torture what would you do?
1. most aggressive tires -- off road only, mud, gravel, and woods riding
2. weight -- obviously the panniers are out, but what else should I pull off?
3. add on -- my bike is just about stock, I do have engine guards but that's it in the way of protection, should I add stump guards and the rest for 3 days riding?
4. misc off road prep -- I am sure there will be water crossing and the like, what are the known problem areas on the GS with this type riding?
-Thanks in Advance
Halfplate
And don't worry plenty of before, during, and after pictures will be posted.
-07 R1200GS
-07 Ruckus
5th BMW GS Trophy Challenge Qualifier 2013
3rd BMW GS Trophy Challenge Qualifier 2012
IBA# 34681 (SS1000)
"luck played a fundamental role" Carlo Boffi
HalfPlate is offline   Reply With Quote
Old 08-10-2012, 06:19 PM   #2
kaosrider
kaosrider's Avatar
Oddometer: 854
-Thanks in Advance
Halfplate
I will take a stab. First I have the same bike. I have engine bars and that is it. However I switched to knobbies. I am considering going as well. I called BMW (in the East qualifiers) here is the deal. You will be traveling all loaded up on the second day to a seperate camp ground for the second night. That means everything you need for camping, you will need to bring along with you. 2nd point, they are inviting everyone and all levels of ability to join in. To me that means, they will not be putting you and all your stuff at too much risk. So I suspect the evaluation sections will be with unloaded bikes. I doubt they will want to be pulling a bunch of noobs out of rivers and such. I am guessing this will be mostly slow speed technical trials where you might knock off a mirror, but not much else. The canidate they seem to be looking for the most will likely be some computer geeks that live on facebook and such. In their discriptions the event looks like mostly GS fun, a little testing, and then they expect the chosen folks to be real good at the social media stuff. Meaning I am out of any contention there. But, I would like to just have the fun as they generally do it up right. PS. I have been their to the off road school and they tend towards the do everything right type of folks.
I asked when the cut off date is and they said when they hit 200 . I am guessing they don't want 200 stranded GS's in the woods
kaosrider is offline   Reply With Quote
Old 08-10-2012, 06:55 PM   #3
Semper Fi
Runs with Scissors
Semper Fi's Avatar
Oddometer: 872
Lucky bastard I wish could swing this
If it was me
1 TKC 80's - excellent all around off road tire and wil hold up to some Tarmac
2 put on the big BMW Skid plate you can glide over logs with it with no issue
3 GSA foot pegs
4 tire repair kit with either on board compressor or CO2
5 Camelback - hydrate or die
6 bark busters
7 strategic tie offs to haul bike out of stuff
8 rock straps and water proof bags to haul crap
9 low windshield - as I have eaten my windshield on an unexpected high side in soft sand
10 tool kit do do all major fasteners and tire change (front rear)
11 spare headlight bulb
12 padded bicycle shorts
2011 R1200 GS Adventure Smoke Grey Metallic Matt
2009 G450X White
IBA #35651
Semper Fi is offline   Reply With Quote
Old 08-11-2012, 02:12 PM   #4
Dark Helmet
Dark Helmet's Avatar
Oddometer: 694
Was looking at this too. I am kinda long in the tooth but like taking my GSA off road in pretty challenging stuff but probably not like this. Don't have any suggestions other than what is already here.
I am 58, are there any other old fools out there thinking of this?
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD -40. If it shouldn't move and does, use the duct tape
BMW 1200 GS Adventure
BMW 1970 R75/5
Suzuki DRZ 400S
Dark Helmet is offline   Reply With Quote
Old 08-11-2012, 02:30 PM   #5
Graniteone
3,2,1...Beer me!
Graniteone's Avatar
Oddometer: 424
Unscrew your turn signal indicators and zip tie them back. Loose your mirrors or upgrade to Double Take mirrors. Also rethink having a windscreen on the bike. Smile and have fun!
Graniteone is offline   Reply With Quote
Old 08-11-2012, 03:35 PM   #6
webjester
Oddometer: 44
Ski boot bags
I am using bags for ski boots. Perfect size (length, width and height!) and low budget.
webjester is offline   Reply With Quote
Old 08-11-2012, 03:49 PM   #7
Semper Fi
Runs with Scissors
Semper Fi's Avatar
Oddometer: 872
Don't dab!
By force of habit I dabbed with my left foot as I was getting a little front end slide
Save the bike but tore ACL MCL and PCL
If it goes doesn't save it
She is a torque monster and will go thru alot rather easily
Keep the tire pressure as low as you can - I use 22 up front and 25 in the back
Plan ahead as the bike has a lot of momentum
If you got ABS shut it off
And good for you!
2009 G450X White
IBA #35651
Old 08-11-2012, 09:41 PM   #8
Motomochila
Mad Scientist
Motomochila's Avatar
Oddometer: 907
Was looking at this too. I am 58, are there any other old fools out there thinking of this?
Just because you're an old fart doesn't mean you cant finesse the big girl around a dance floor. Just remember to start slow an easy... Wishing I could make the challenge but a little timing with my 20th anniversary is getting in the way. Me? 55 and still playing in the dirt every time I can. Bring back a trophy or something better.
2014 KTM 690 Enduro R, 2014 EXC500,2012 BMW GTL1600, 2015 BMW GS800 Adventure, and 16 other motorcycle projects in various stages of completion. It's an addiction thing.
Motomochila is offline   Reply With Quote
Old 08-13-2012, 11:39 AM   #9
HalfPlate OP
What? Where?
HalfPlate's Avatar
Oddometer: 1,046
This is some great info. Thanks to everyone. I need to call BMW back and figure out what I need to be able to haul, I just figured everything would be at the training center.
Thanks Again and keep the suggestions coming
-HalfPlate
-07 R1200GS
-07 Ruckus
IBA# 34681 (SS1000)
Old 08-13-2012, 03:12 PM   #10
Dark Helmet
Oddometer: 694
Ok, I am joining you HalfPlate! Registered today. Should be fun and educational (I am going to keep thinking that versus painful and expensive!)
DH
BMW 1970 R75/5
Suzuki DRZ 400S
Old 08-13-2012, 05:12 PM   #11
SloDon
Hey...where am I?
SloDon's Avatar
Oddometer: 628
Maybe I will come.........and watch!
Sent from my iPad using Tapatalk HD
SloDon
'12 R1200 GS Adv, '05 DRZ 400, '08 RE Bullet 500
http://www.youtube.com/user/SlooDon#p/u
Don't grow up.......it's a trap!!
SloDon is offline   Reply With Quote
Old 08-14-2012, 07:03 AM   #12
HalfPlate OP
What? Where?
HalfPlate's Avatar
Oddometer: 1,046
Dark Helmet,
Sounds great we will see you there. I will be trailering (to get the tkc's fresh) so keep an eye out for an all black gs on a trailer and a yellow and silver gs in a pick-up that will be another advrider and myself.
-07 R1200GS
-07 Ruckus
IBA# 34681 (SS1000)
Old 08-14-2012, 07:53 AM   #13
Eddy Alvarez
Addicited to ALL bikes!
Eddy Alvarez's Avatar
Oddometer: 2,252
I'm officially in! I took that Friday off, I sent in my application and have paid my entry fee!
Looking forward to having some serious fun! The $200 entry fee is very reasonable considering that it pays for two nights of camping, six meals, a GS trophy t-shirt and the costs of setting up and running the event. All I am planning on doing to the bike to prepare is having a fresh pair of TKC's spooned on, removing the Aeroflow, zip tying the turn signals up, taking an extra shift lever duct taped to the bottom of my seat along with some tools, extra levers and a tire repair kit.
I'll contact you soon about transportation.
Unfortunately, no riding down and watching your friends compete, I just confirmed with BMW that "No outside spectators are allowed! You must be on a 650cc or larger BMW GS and must sign up/pay the $200 fee to ride along, camp, eat and have fun..."
Link for more info: http://bmwmcmag.com/2012/08/gs-trophy-2012-be-part-of-the-usa-qualifying/
Me: BMW R1200GS KTM 525EXC. Gabriel: KTM 50. Elena: Honda CRF70. Lynn: Official Gatorade/snack girl!
Eddy Alvarez screwed with this post 08-14-2012 at 08:18 AM
Eddy Alvarez is offline   Reply With Quote
Old 08-14-2012, 09:32 AM   #14
Dark Helmet
Oddometer: 694
Dark Helmet,
Great Halfplate. I am undecided but I think I will be riding the bike up. I live a lot closer and figure I will put on a rear TKC before I leave. Its less than 200 miles to Spartenburg for me. I will be on a silver/black GSA, black helmet (of course) and have a RP2 suit on. Will also have a slipstream on the front instead of a windshield.
Bummer about no spectators.
Looking forward to seeing everyone there!
BMW 1970 R75/5
Suzuki DRZ 400S
Old 08-14-2012, 03:22 PM   #15
DualMule
Oddometer: 306
Some things that are likely to break when you go down:
1. Windscreen - take it off
2. Front blinkers - buy a set of rear mounts and swap them out (you have to drill out the hole on the stem a bit, easy) or remove them while your off-road
3. Side mirrors - remove them (at the last Roaming rally the trail I must have ran across have a dozen broken mirrors)
4. Handguards - get a set of bark busters
When it comes to weight there is not much that you can really do other than bring minimal gear. I guess the biggest weight savings I can think of is to swap out the stock exhaust...maybe throw in a lithium battery. That might knock off 15 pounds.
As for protection:
1. Upgraded skid plate (despite having the well made BMW upgrade on my current GSA, I still have a ding in my exhaust cross pipe from gravel)
2. Cylinder guards (the OEM are good, but my Adventure design extensions have saved my ass several times)
3. Headlight guard
4. TPS guard
5. Snorkel ? (One of those things that you don't know if you'll need it until it's too late...it's an easy mod. I have a post of my system on a thread around here somewhere)
Performance:
1. I've found the air temperature mod devices useful for slow technical maneuvering. Low speed throttling is smoother.
2. Steering damper (didn't know what I was missing until I picked up a brand new hyperpro here for $150)
3. Tires - the TKC has been the go to tire for most GS riders off road, but the Mitas E-09/dakar is a much better tire for the riding it sounds like you are going to be doing. I just got my first set this summer...wish I had them for the Roaming Rally in June...they are true dirt tires and since you are trailering up...that's the way to go in my opinion.
Gear:
1. I always use MX boots when I'm taking my bike for relatively serious off roading. I think Ankle support/protection is critical when you are riding a moto off road...particularly a big heavy bike. Also helps when you're standing on the pegs all day.
2. Ditch the knee pads in your pants and get MX style knee protection, I have a set of Thor something or another and they are much more comfortable and protective.
3. Knuckle protection. I don't use the MX style gloves, they are light weight and airy, but they don't offer enough protection. My Rev'it dirt gloves, have plenty of scratches on the knuckle guard to prove their point.
4. I actually don't have one, but a compression suit/roost guard etc. probably offers the best protection if you are riding exclusively off road.
5. MX goggles (if you have an MX/DS helmet). They let more air into your helmet and tear-offs make them easier to keep clean.
6. hydration pack. Amen staying as cool and hydrated as possible is critical. Forget the in the jacket crap and go with a backpack.
Equipment:
Above what you need normally, so things that I have found to be useful and don't take up much space or add weight:
1. JB Weld
2. bailing wire
3. Duck tape (they make it in black)
4. 18" inner tube? Rumor is it will get you out of a pinch and works with both rims, but I have thread on this an no one every confirmed it, I've personally usually carry two tubes, but they are bulky. The rear wheel of the BMW spoked rim has an off set valve stem, but I have confirmed that the last tube I used (for thousands of miles) was a centered stem tube. If you dent a rim or rip a tire, your plug kit will be useless...it's happened to me twice and it happened to at least one at Roaming Rally in June.
Just thinking out load here...
Have fun!
DualMule is online now   Reply With Quote
Times are GMT -7.   It's 12:23 PM.
