Old 08-15-2012, 05:04 AM   #16
WVhillbilly
WVhillbilly's Avatar
Oddometer: 11,093
I have not gotten that close to it.
Picture was taken with a lot of zoom on the camera.
Next time I'm by there I might put a note on it tho.
Are there many parts available for these old bikes?
WVhillbilly is offline   Reply With Quote
Old 08-15-2012, 05:14 AM   #17
JWhitmore44
pistolero
JWhitmore44's Avatar
Oddometer: 1,624
Not sure how good the part situation is on the older XL's. You may want to check out the XL thread http://www.advrider.com/forums/showt...ghlight=xl500s From the picture I can't really tell if it's the 500 or the 250. It looks like my old 81 500s. Either one were good solid bikes though.
84 Honda Goldwing (GL1200)
03 XR650L
JWhitmore44 is offline   Reply With Quote
Old 08-16-2012, 02:24 PM   #18
seth0941 OP
NW Adventure Rider
seth0941's Avatar
Oddometer: 481
Kickstand
So, I pulled another part out of the box yesterday.
before
Cleaned up before paint.
Finished.
seth0941 is offline   Reply With Quote
Old 08-16-2012, 06:48 PM   #19
MacNoob
MacNoob's Avatar
Oddometer: 1,671
I like the way you're going about this.
I had a green '78 DT125. Neat bike. Careful with the monoshock, they have a nasty kick back over sharp bumps.
"Persuade thyself that imperfection and inconvenience are the natural lot of mortals, and there will be no room for discontent, neither for despair."
MacNoob is offline   Reply With Quote
Old 08-16-2012, 08:13 PM   #20
WVhillbilly
Oddometer: 11,093
Are you using lots of wire wheel or chemical means to clean up parts.
Old 08-16-2012, 08:25 PM   #21
seth0941 OP
NW Adventure Rider
seth0941's Avatar
Oddometer: 481
So far I have been using a soft wire wheel on a 6" bench grinder. When it gets to the frame and other parts I will be using a soda blaster. Using the wheel takes a little time but it seems to work well.
Old 08-16-2012, 08:35 PM   #22
WVhillbilly
Oddometer: 11,093
I used to do auto restoration, used up a bunch of wire wheels.
There are other things to use, but that is cheapest and less damaging.
If you know anyone at a machine shop you can have steel items hot tanked.
Walnut shells work well as a blasting agent too.
I love to see old forgotten things brought back to life, it is one of the most rewarding things I've done.
Old 08-16-2012, 09:05 PM   #23
seth0941 OP
NW Adventure Rider
seth0941's Avatar
Oddometer: 481
Thanx for the info, this is the first project like this I have done. I am going to take it 1 piece at a time.
Times are GMT -7.   It's 02:37 AM.
