Old 07-09-2012, 03:48 PM   #556
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,478
Originally Posted by vecchio Lupo View Post
Friends, I have an 81' R100 with a 99k+ miles on the OE Drum brake 37/11 final drive. It has alot of drive lash and the diff is shot. Will a 32/11 from a 74 R90/6 bolt on without drama?
let me know asap as it's on ebay and I don't want to lose it.
You can use any 70-84 twin shock rear drive as long as it has the brake pivot hole in it. Not all 81-84 rear drives had it.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 07-11-2012, 11:40 AM   #557
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Originally Posted by east high View Post
Are these part numbers for Krauser bag keys?
No, just for the early BMW bags that had the metal latches.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 07-13-2012, 10:21 PM   #558
Milkjug
Antifriction
Oddometer: 38
Napa oil filter kit # PS4945
Milkjug screwed with this post 07-13-2012 at 10:23 PM Reason: Bad photo
Milkjug is offline   Reply With Quote
Old 08-17-2012, 06:02 PM   #559
_cy_
Oddometer: 6,188
does anyone know the part number exchange, Valeo copy starters for R80G/S?
this appear to be an Asian made nine tooth permanent magnet starter that fits, BMW R series Airhead with 9-Tooth, Replaces Valeo D6RA7, D6RA15, 12 41 9 062 425
these are probably made for a popular Japanese auto with several applications. starter mfg generally will not make new starters unless there are lots of sales to justify tooling.
_cy_ screwed with this post 08-20-2012 at 12:23 PM
_cy_ is online now   Reply With Quote
Old 08-17-2012, 06:39 PM   #560
lockyv7
lockyv7's Avatar
Location: Sunshine Coast Australia, There is no winter here.
Oddometer: 1,038
thanks in advance...
try this ,
http://www.euromotoelectrics.com/Sta...p/bmw-str1.htm
lockyv7 is offline   Reply With Quote
Old 08-17-2012, 10:31 PM   #561
Beemerboff
Oddometer: 2,311
They were on some small Renault autos.
Caltric on Ebay had them for $90- when I bought mine 3 years ag0. FWIW it has worked perfectly.
He had them listed for the auto too, but at the same price.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 08-17-2012, 10:39 PM   #562
Zebedee
Zebedee's Avatar
Oddometer: 809
... was hoping to find the cross to same part number for a small car ...
I've got a vague recollection that the Valeo D6RA7 was also fitted to things like the Citroen AX and Peugeot 205's. Not Japanese I know, but it might throw up some other part numbers to search.
Also the name Nippondenso (?sp) comes up occasionally with reference to alternative starter motors for airheads, but I can't remember more than that.
HTH ...
John
The perverse must persevere
Zebedee is offline   Reply With Quote
Old 09-11-2012, 04:46 PM   #563
doubleoseven
oo7 is IDMVFISS
doubleoseven's Avatar
Oddometer: 37
Recommended Online Store to buy airhead parts
Hi
Could anyone recommend an online store in the USA to source airhead parts from?
Tx
doubleoseven is offline   Reply With Quote
Old 09-11-2012, 05:04 PM   #564
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,358
http://www.bmwhucky.com/
---Albert Einstein
Old 09-11-2012, 07:08 PM   #565
djaabrams
BMW GS Addicted
djaabrams's Avatar
Oddometer: 49
Bob's BMW in Jessup, MD.
Blue Moon Cycle in GA
Beemer Boneyard
Max BMW, several locations I believe
That should get you started
Google should give you the websites...
Originally Posted by doubleoseven View Post
Hi
Tx
'03 BMW F650GS
'10 BMW F800GS
'80 BMW R100S Cafe
'02 BMW R1150GS
'99 BMW R1100S
djaabrams is offline   Reply With Quote
Old 09-12-2012, 05:12 AM   #566
doubleoseven
oo7 is IDMVFISS
Oddometer: 37
Beemer Boneyard
Thank you kindly, Sir!!
Old 09-26-2012, 09:45 PM   #567
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,127
Neutral Switch?
When the brass neutral switches first arrived I heard they were sourced from Ducatis. Has anyone gotten these from a Ducati dealer (or anywhere else) and what part number or application was it for?
Old 10-02-2012, 11:08 PM   #568
igormortis
igormortis's Avatar
Oddometer: 1,355
I got one off a Peugeot 306. Requires swapping the nose (?) of the starter to the BMW type. See here: http://advrider.com/forums/showpost....7&postcount=47
igormortis is offline   Reply With Quote
Old 10-06-2012, 12:01 PM   #569
Uncle Pollo
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 47,791
Replacement for oem spark plug wires? Sandia bmw can suck it. Thanks.
Uncle Pollo is offline   Reply With Quote
Old 10-06-2012, 01:12 PM   #570
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,029
Right now I have a set of pretty yellow Taylor automotive plug wires on my R80. I bought a repair/replacement set that IIRC had enough wire in it and enough crimpon terminals to cut to length and put the terminals on.
If you have any perfomance oriented parts shops or speed shops around you, you can probably get some really good wires made up to order.
And a regular on here, wirewrkr, may make up and sell them.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Times are GMT -7.   It's 05:51 AM.
