Old 03-12-2012, 01:51 PM   #16
Podmiester
Podmiester
Podmiester's Avatar
Oddometer: 32
Wicked Bits left over
Hi Daithi,
What are you doing with the original front end, lamps, clocks & mudguards ect ?
I'm thinking of GSing my Roadster.
Rgs Podmiester
"One of the gladdest moments of human life, methinks, is the departure upon a distant journey into unknown lands. Shaking off with one mighty effort the fetters of habit, the leaden weight of routine, the cloak of many cares and slavery of home, man feels once more happy."
Podmiester is offline   Reply With Quote
Old 03-12-2012, 03:24 PM   #17
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,667
He's boxing up the original body parts so one can assume he's keeping the other bits too.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 03-13-2012, 10:06 AM   #18
Daithi OP
Destination Unknown.
Daithi's Avatar
Oddometer: 176
Laugh
Originally Posted by Podmiester View Post
Hi Daithi,
Rgs Podmiester
Yeah, One Less Harley is on the right track, I won't be selling off the bits. If you have the "roadster" why not get an enduro front end and do the same as I did ? It's surprisingly easy.....
CCM404 & DRz1000
Daithi screwed with this post 03-14-2012 at 04:50 AM
Daithi is offline   Reply With Quote
Old 08-18-2012, 05:44 AM   #19
Daithi OP
Daithi's Avatar
Oddometer: 176
These things are like hens teeth, got one anyway:
I also have the inside cover from a R1100R along with the rear brake system, unfortunately the only wheel I have that will fit it is from the same R1100R, but it'll have to do till I get a spoked wheel.
I've ordered the Phosphor Bronze pivot bushing from Rubber Chicken and whe that arrives I'll bolt it all up and see how my alignment works out.....
Next photo should be of the bike complete with disk brakes on the back.
CCM404 & DRz1000
Old 08-18-2012, 09:17 PM   #20
Beater
Dirty
Beater's Avatar
Oddometer: 3,196
Whoa ... That from an R1100? What year? Is it a bolt up? This one won't have the destructive shaft issue ... right? VERY COOL.
Fred
'85 R80RT G/Sified <|> '91 R100GS Bumblebee (103K miles and climbing) <|> '73 R75/5 LWB
Airhead Zen: Ride - Repair - Ride - Maintain - Ride - Repeat
Beater is offline   Reply With Quote
Old 08-19-2012, 07:47 AM   #21
One Less Harley
Oddometer: 4,667
Originally Posted by Beater View Post
Whoa ... This one won't have the destructive shaft issue ... right? VERY COOL.
hah hah hah...you wish
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 08-19-2012, 08:41 AM   #22
Beater
Dirty
Beater's Avatar
Oddometer: 3,196
A Wonderfully Glorious and Huge Dream!!!
squashed
Fred
Old 08-19-2012, 08:59 AM   #23
Daithi OP
Daithi's Avatar
Oddometer: 176
squashed
Are you gents saying this won't work ?
I've put the drive on without bolting up and it looks ok, I can't see how the idea won't work, even
the wheel alignment seems reasonably good ?
CCM404 & DRz1000
Old 08-19-2012, 09:08 AM   #24
Beater
Dirty
Beater's Avatar
Oddometer: 3,196
I have no idea weather it will work or not ... personally, I'm rooting for you. If it does, then my '91 GS will be getting one of those when the shaft dies.
Are you replacing the swingarm as well? Are you just replacing the final drive assembly?
Fred
Old 08-19-2012, 09:17 AM   #25
Daithi OP
Daithi's Avatar
Oddometer: 176
Talking
You had me scared there, I thought you knew something
I didn't. The drive is from a K1 and pairs perfectly with the
original shaft. I'll put the inside cover from an 1100R final
drive to allow me to use whe twin pot caliper. I'm relieved
there's nothing you're aware of that would stop this from
working. This should be a bolt up job with no machining
apart from making up a shim for alignment purposes.
CCM404 & DRz1000
Old 08-19-2012, 09:27 AM   #26
Beater
Dirty
Beater's Avatar
Oddometer: 3,196
Very interesting. Besides maybe the parts being available ... what are your reasons for doing this? Is there some sort of design benefit? The R1100's are not supposed to have the shaft problems of the R100's. Is this the reason? if this is the case, why not replace the swingarm as well? Does the shaft mate differently with the transmission?
More pictures!!!
Carry on!
Fred
Old 08-19-2012, 10:05 AM   #27
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,462
The R1100 swingarm and driveshaft are longer. Also, the trans side of the shaft fits on a spline rather than a bolted output flange like on airheads. In order to use an 1100 swingarm on an airhead, you need one of the trans output adapters. Also, you need to create a new shockmount as the oilhead swingarms use a single center mounted shock.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 08-19-2012, 10:48 AM   #28
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,294
Just the age old Mono vs Para debate....keep moving, nothing to see!! But certainly looking forward to your progress!! Thanks for sharing!
hardwaregrrl is online now   Reply With Quote
Old 08-19-2012, 12:37 PM   #29
One Less Harley
Oddometer: 4,667
No I wasn't saying it couldn't be done. I think it has been done, what I was talking about was the drive shaft issues. That won't be taken care off.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 08-19-2012, 01:34 PM   #30
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,182
I don't think this is being done for shaft longevity reasons. Daithi is following Phreaky Phil's lead in putting a rear disc on R100GS(ex-PD). He is using the KI final drive because that is the same generation as the R100GS paralever, & more particularly has the mounts to allow this.
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Times are GMT -7.   It's 08:54 PM.
