Old 08-23-2012, 04:53 PM   #1
PowerCell OP
Manufacture
PowerCell's Avatar
Oddometer: 2,369
New Desert/Enduro Gas Tank for the SE950R
As many of you already know, I've been tooling up to build a midsized fuel tank for our beloved KTM Super Enduros. After many requests, I now have the final design completed, and tooling is being manufactured. Due to the limited production of this tank, we will be pre-selling these units and building specifically to order. Delivery should be in approx. 10 weeks from today.
Here's a few details:
  • Built upon the 950SM design
  • Uses either standard or gel filled SM 950 seat (not included)
  • Approx. capacity is 5.6 US gallons (125-150 mile range)
  • Requires an optional IMS dry-break or dry-break cap adapter
  • All mounting hardware will be included... seat, cap and vent are options which we will have available to purchase
  • We will be offering these units in Black or Natural (translucent)
  • You will re-use your petcocks and front seat post
  • You will also need slightly longer fuel lines which will not be included
I'm sure that I've forgotten a few details, but that's pretty much everything in a nutshell. Price will be $699.00 plus shipping and any applicable taxes. To get on the production list, PM me with your PayPal e-mail, shipping address, color choice and any options you may want... I'll get an invoice out to you ASAP. It's first come, first serve only. We will not be carrying an inventory, so you'll need to place your order so we can build it for you.
Any additional questions please feel free to ask...
Available Options
KTM Gel Seat Option: $119
IMS Dry Break Option: $225
IMS Billet Cap Adapter with Cap and Hardware Option: $75.00
IMS Plastic Cap Adapter with Cap and Hardware Option: $44.95
IMS 90 Degree Vent Option: $8.75
~ Ken
www.powercellperformance.com
PowerCell screwed with this post 02-22-2013 at 03:39 PM
PowerCell is offline   Reply With Quote
Old 08-23-2012, 05:18 PM   #2
dzrtracin
ride'n 2 live
dzrtracin's Avatar
Oddometer: 2,799
Ordered, thanks again for your time & energy on this product Ken
BRAVO!
RIDE ON!
Content, NEVER!
dzrtracin is offline   Reply With Quote
Old 08-23-2012, 06:09 PM   #3
DRjoe
DRjoe's Avatar
Oddometer: 5,096
Nice work.
What's the tank made of?
When you pull the seat off can you see the air box or does the tank cove the air box like the original Sm tank?
DRjoe is online now   Reply With Quote
Old 08-23-2012, 07:24 PM   #4
PowerCell OP
Manufacture
PowerCell's Avatar
Oddometer: 2,369
Originally Posted by DRjoe View Post
Nice work.
Crosslinked Polyethylene just like the original tank. And yes, just like the SM tank this one also is closed in the back half. This is needed to provide support for the back half, and allows the tank to feature a 1 bolt retention system. When combined with quick release fuel line connectors, you can pull the entire tank in less than two minutes...
~ Ken
Old 08-23-2012, 07:25 PM   #5
PowerCell OP
Manufacture
PowerCell's Avatar
Oddometer: 2,369
BRAVO!
RIDE ON!
Awesome!
~ Ken
Old 08-23-2012, 08:32 PM   #6
PowerCell OP
Manufacture
PowerCell's Avatar
Oddometer: 2,369
Chip Munn currently has the KTM hard parts gel seat on special... $118.99
http://173.74.246.25/munnracing/showproduct.cfm?id=1586
~ Ken
PowerCell screwed with this post 08-25-2012 at 02:29 PM
Old 08-23-2012, 08:50 PM   #7
dzrtracin
ride'n 2 live
dzrtracin's Avatar
Oddometer: 2,799
Done deal, THANKS!
Content, NEVER!
Old 08-23-2012, 09:08 PM   #8
offworlder
Oddometer: 256
Fantastic ! Thank you very much for building this !
Was just talking about the need for a mid-sized (larger than stock, smaller than the Safari) tank today...
Questions:
1: you mentioned the tank was built from the same materials as the original. Is it the same thickness as well ? (hoping its as strong or stronger as the stock tank)
2: whats the width at the knee position, and where the inside of the thigh would be (farthest rear point) ?
3: standard (plastic) tank cap is included, or... ?
4: as airflow is so critical to the rad, how's the position/width of the tank (in that area) compared to the stocker ?
5: does the fuel pump mount in the same place ? and the horn ?
- Can you talk a little more about how the tank is secured, bolted on ?
- Can we get a pic of the radiator area (from the front), and ideally one of the underside of the tank ?
offworlder is offline   Reply With Quote
Old 08-23-2012, 11:22 PM   #9
PowerCell OP
Manufacture
PowerCell's Avatar
Oddometer: 2,369
Questions:
We have the ability to mold the tank as thick or thin as desired. We're shooting for slightly thinner than stock as the OEM tank is as much as a half inch thick in places. Trust that this tank will be plenty strong.
The section between your knees is similar to the stocker, but transitions better from the seat on down. For the tall rider I've kept the profile narrow much further forward than stock as can be seen in the pictures above.
A cap option needs to be selected from the ones listed above.
KTM engineered this part so air flow is not a problem.
Fuel pump goes in the stock location. Thread inserts are in place for the fuel sender, but if you no longer use the stock (useless) sender we can leave the hole unopened. The horn location has been eliminated to increase fuel storage.
6: Can you talk a little more about how the tank is secured, bolted on ?
Rubber coated bushings support the nose and lower sections of both sides. Rubber pads support the tank resting on the upper rear frame tubes. And lastly there is a single bolt the secures the rear of the tank at the very back just below the seat. This mounting design is very similar to KTM's dirt bikes.
~ Ken
Old 08-24-2012, 12:50 PM   #10
jm65
jm65's Avatar
Oddometer: 177
waouhhhhhhhhhhhh
very nice Ken , i like the design and harmony with the original line
little question :
- no bolt fixation in the front tank , only in the rear ?
-can you post more pictures for all fixations (rubber , frame ,...)
-possible to send in France
-..."We have the ability to mold the tank as thick or thin as desired...." option ? and if so what is the price ?
thanks in advance and yet all my congratulations
jm65 is offline   Reply With Quote
Old 08-24-2012, 01:01 PM   #11
PowerCell OP
Manufacture
PowerCell's Avatar
Oddometer: 2,369
waouhhhhhhhhhhhh
Possible to send in France?
Yes
Yes. We can go as much as 25% thicker. This option would only be $75...
~ Ken
Old 08-25-2012, 12:06 AM   #12
Pitster
miniac
Oddometer: 348
How do you mount the horn if you still want to run one?
www.pitsterpro.com Pitster Pro, Mini Bikes, Pit bikes and Play bikes, Side x Side, ATV
www.nomadrider.com Adventure luggage and gear
Pitster is offline   Reply With Quote
Old 08-25-2012, 08:27 AM   #13
SauceSquatch
SauceSquatch's Avatar
Oddometer: 268
Nice work, that looks amazing... I'd love a different tank option for the 990, I never understood why it's not a little wider at the top to allow for more fuel. Seems like it would have bee a small compromise. I love what you did with this design though.
Cheers.
SauceSquatch is offline   Reply With Quote
Old 08-25-2012, 01:15 PM   #14
mountain eagle
terrorist
mountain eagle's Avatar
Oddometer: 2,920
A couple of things for clarity.
1. This will not work with the stock seat?
2. This make it the same as a SM for air filter purposes?
I just finished my custom seat then ordered the CPR air filter for the SE and if this changes all of that........... not sure I can do it.
mountain eagle
08'Husky TE610 x 2 TE/SM
KTM 950SE
my smugmug gallery
How can it be fun if there's not at least an outside chance of dying?
mountain eagle is offline   Reply With Quote
Old 08-25-2012, 01:48 PM   #15
PowerCell OP
Manufacture
PowerCell's Avatar
Oddometer: 2,369
The stock Super Enduro seat will not fit... completely different shapes. On the plus side the stock seat sux ass. The SM seat not only transitions better between your legs, it is much more comfortable. Plus the Gel version is only $118 from Munn's!
The tank will clear a stock SE filter housing as well as a Motohooligan. Not sure about the CPR unit as I don't run one. I'll reach out to Chris Parker at CPR and see if I can grab one for testing. He's only 15 minutes from my shop.
I've just added 5 additional pix to the original post to better display the single mounting bolt design and the seat/tank relationship...
~ Ken
PowerCell screwed with this post 08-25-2012 at 01:56 PM
Times are GMT -7.   It's 01:22 AM.
