Old 08-26-2012, 08:28 AM   #61
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,639
A while back, I saw another thread on this same subject of swapping out for R11 grips, was wondering if anyone remembered who did that thread. IIRC, it had additional pics and instructions, which combined with this thread would be really helpful to folks like myself, who are about to go down this road.
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 08-28-2012, 12:28 AM   #62
tommyvdv
tommyvdv's Avatar
Oddometer: 420
Originally Posted by maduko View Post
…The factory wire is .011" and the hobby shop sold me .009" diameter.
what's that in mm?
.2 mm – .3 mm ?
tommyvdv is offline   Reply With Quote
Old 08-28-2012, 01:21 AM   #63
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
This one? http://www.advrider.com/forums/showthread.php?t=347652
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 08-28-2012, 02:27 AM   #64
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,639
Originally Posted by Poolside View Post
That was one, but there was one specifically done on a 12. IIRC it was a bit different, but I'm not sure, hence the search. Didn't come across it on a google site search.
Old 08-28-2012, 03:18 AM   #65
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
A couple more:
http://www.advrider.com/forums/showthread.php?t=626812 (scroll down a bit)
http://www.advrider.com/forums/showthread.php?t=770667 (the new film-type heating element)
Old 08-28-2012, 03:47 AM   #66
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,639
A couple more:
My google-fu has failed me, those were what I was thinking of. Thanks!
Old 09-06-2012, 04:39 PM   #67
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,639
Well, that was pretty easy.
Used a small flat tip screwdriver to help lift off the rubber at the bonded spots, it came off easy, and my wife (unknowingly) provided the requisite goop for bonding.
Can't believe she uses that stuff in her hair. "Dear? You know I use that stuff to hold parts on my bike, right?"
Old 09-06-2012, 04:42 PM   #68
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 9,975
Originally Posted by drif10 View Post
can't believe she uses that stuff in her hair. "dear? You know i use that stuff to hold parts on my bike, right?"
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 09-06-2012, 05:57 PM   #69
LaurelPerryOnLand
Oddometer: 3,481
Just in the nick of time...
Nice write up. Thanks.
It's the NEXT project for my 06 GS.
LaurelPerryOnLand is offline   Reply With Quote
Old 09-07-2012, 02:15 AM   #70
asphaltsurfer1
CatManDoo
asphaltsurfer1's Avatar
Oddometer: 125
avoid replacing the grips in the first place. a trick i picked up from a GS rental in Hawaii of all places- bicycle handlebar wrap. my grips were wearing fast so i looked for the thinnest wrap i could find. it actually increased the diameter slightly and the soft suede-like feel is nicer than rubber grip alone. when they get worn just re-tape.
asphaltsurfer1 is offline   Reply With Quote
Old 09-07-2012, 03:25 AM   #71
Chubb1
Going going gone
Chubb1's Avatar
Oddometer: 77
Gs 07
I was pondering about changing mine for ages, as the old rubber was getting tacky. Did a lot of reading up on the topic and decided it had to happen. The old ones peeled off reasonably easy. I bought some pro grips 807,s I think.. A bit thicker than normal and they feel fine. Just takes abit longer for the heat to come through. Even though I bought two sets you could get away with one set. There is a lot of give in them. Hair spray work great.
Chubb1 is offline   Reply With Quote
Old 09-27-2012, 06:50 PM   #72
Hookapelli
Adventure-Junkie
Hookapelli's Avatar
Oddometer: 2,637
I didn't need new grips- I just didn't like the OEM ones.
BMW wanted like $Million to but the original grips back on and didn't have anything 'beefier' in stock (I'm use to having some thing a little thicker in my hand ) so I picked up a pair of ODI Mushroom Grips from Motorcycle-Superstore.com
I figure these are cheap and may only last a season or two- but at $10 a pair, I'll deal with it until I find a better replacement.
I started by removing the hand guard and mirror.
Then I GENTLY made a small slit and began peeling of the original rubber being VERY CAREFUL not to nick the element.
Finally- after 10 tedious minutes I had the grip completely removed and trimmed away.
Using a generous amount of Aquanet Hairspray- I coated the inside of the new grip and (with a little grunting and cursing) slipped it over the element. I didn't think is was going to fit- but it did.
I cut a hole in the end with an exacto knife (which I used to slice the old grip off with) and replaced the Kaoko throttle lock, hand guard, and mirror.
Repeated for left side.
I got nothin'....
Hookapelli is offline   Reply With Quote
Old 10-01-2012, 12:33 PM   #73
tommyvdv
tommyvdv's Avatar
Oddometer: 420
where do worn replaced grips go to die? I need the tiny wire set running from connector to resistance wire. kinda fucked mine while trying to solder it to a different heater.
if anyone has a clue or has a few of these lying around :)
Old 10-01-2012, 12:38 PM   #74
Hookapelli
Adventure-Junkie
Hookapelli's Avatar
Oddometer: 2,637
The whole assembly is removable and then you can just replace the wire. no?
I got nothin'....
Old 10-01-2012, 10:26 PM   #75
tommyvdv
tommyvdv's Avatar
Oddometer: 420
true. but I just about ran out on mine :)
I'm talking about the wire that starts at the connector thingy, runs once around the handle and crosses over through the slit in the housing/handle
Times are GMT -7.   It's 01:26 AM.
