Old 08-28-2012, 05:57 AM   #1
Alex_RO OP
Wanderer
Alex_RO's Avatar
Oddometer: 206
New fork springs - what should i get ?
Hello,
got a friend going over to the US and he's kind enough to bring back some stuff with him so... i'll be asking him to get me some stiffer springs.
Details:
Bike model:2007 Standard ADV (w ABS), standard .48 springs installed.
Rider weight: 250 now but on a diet, aiming for ...let's say 230 (with gear, no luggage).
Intended Usage: fast street and "fire" roads (these pretty much mean the same thing in Romania, you never know where you're gonna find a pothole), veeery little (and slow) offroad.
I'm hoping to get away with .54 springs since anything thicker/heavier is going to required modifying the forks somehow and there's nobody around I'd trust to get that going (shipping the forks off to SPS isn't much of an option, i'm pretty much half way around the world). If there's a guide somewhere and a "kit" for installing heavier springs, i'd love to hear about it.
Your thoughts? Should i get stiffer springs than .54 ? All input is welcomed.
Thank you !!!
Alex_RO is offline   Reply With Quote
Old 08-28-2012, 07:15 AM   #2
henryroten
Oddometer: 258
I have a 2011 R and originally went to .64 springs (with a Superplush revalve) and found that they were still to soft in hard braking and hard, rugged terrain. Went to ;70's and fixed the problem. Much better off road and particularly good on the street. The front end stays up and doesn't dive under hard braking.
If you want to try the .64's let me know and I will try to figure out how to get them to you.
henryroten is offline   Reply With Quote
Old 08-28-2012, 07:41 AM   #3
offworlder
Oddometer: 256
Weigh approx 175lbs. went with .64. Based on your weight, I'd say .64 should be your minimum.
No modifications are required if using the right springs.
offworlder is offline   Reply With Quote
Old 08-28-2012, 08:19 AM   #4
Konflict Motorsports
KM TUNER
Konflict Motorsports's Avatar
Oddometer: 860
The spring guide will need to be trimmed down for most springs of that rate, if you were having springs put in here at my shop I'd put in .68 front springs.
Konflict Motorsports & Suspension www.KonflictMotorsports.com
Konflict Motorsports is offline   Reply With Quote
Old 08-28-2012, 02:25 PM   #5
Alex_RO OP
Wanderer
Alex_RO's Avatar
Oddometer: 206
ok...
Since .70 seems to be the way to go... what modifications would be required for thicker springs ? Is there a guide somewhere ?
Thank you, Alex
Old 08-28-2012, 02:32 PM   #6
GZERO
Fixing stuff around
GZERO's Avatar
Oddometer: 265
Be carefull about hearing other peoples ideas on springs, you don't know how much weight his bike has and how much they weight.
I'll say .70 for a heavy bike with a heavy rider, if not i'll go with the .68.
BTW: i never done it, but .70 springs with stock valving seems crazy.
Having some time off bikes.....family first :(
GZERO is offline   Reply With Quote
Old 08-28-2012, 02:56 PM   #7
Alex_RO OP
Wanderer
Alex_RO's Avatar
Oddometer: 206
Yeah, doesn't seem particularly healthy to me either. I'm trying to find a solution to that... maybe a shop in Europe that can do the revalving.
In the meantime, might as well try to get as much information as possible from the OC.
Thank you, Alex
Old 08-28-2012, 08:49 PM   #8
mdfehrmann
mdfehrmann's Avatar
Oddometer: 338
I'm 165lb's with gear, Safari tanks and running se springs .59's I think?
Works great but my suspension is going to super plush over winter for S spec
and valving.
Only when you take 520lbs of motorcycle and snake it through the woods as slow as you can, will you begin to learn just how much you never knew about motorcycling. -Dieseljo-
2006 KTM 950 ADV S - 2004 Sherco 2.9
http://www.mdfeditions.com/
http://www.cjdesignsllc.com/
mdfehrmann is offline   Reply With Quote
Old 08-28-2012, 10:16 PM   #9
KM TUNER
Oddometer: 860
Thank you, Alex
.70 is a very large increase over the stock .48kg springs. With the stock valving it won't be the best ride (not any worse than you are already experiencing). I'd recommend completing a revalve at the time of a spring swap as well, and would be more than happy to share a few stacks if you are capable of doing the work.
The mid stroke is the major issue on these forks and needs to be addressed as well as the rebound valving when swapping to springs of this rate.
Typically depending on the spring manufacture the I'd of the springs is too large therefore the spring guide needs to be trimmed down 1 to 1.5mm so the guide can travel through without any binding.
Old 08-28-2012, 10:28 PM   #10
KM TUNER
Oddometer: 860
Thank you, Alex
This black spring guide needs to be trimmed down, just the ridges that guide it trough the spring itself.
The midstroke harshness you feel (deflection) is due to the poor valving without enough float if you do not modify the midstroke tap and piston:
These pictures are courtesy of KTMtalk.com located in the suspension form. These are not ADV forks, but very close in design.
Old 08-28-2012, 10:29 PM   #11
KM TUNER
Oddometer: 860
[QUOTE=Noto;19462541]Hello,
How much luggage do you carry, and how much weight? Are you using hard bags or a giant loop type system?
Old 08-28-2012, 10:41 PM   #12
Yascher
Yascher's Avatar
Oddometer: 388
Thats a great thread)))
intresting to see what the end result will be
Yascher is offline   Reply With Quote
Old 08-28-2012, 10:50 PM   #13
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,114
That's not something I expected to hear. Didn't think that midstroke harshness was a problem on my stock forks, thought they were more likely to blow through the midstroke. Are you referring to adventure forks or SE forks?
I wish I had time to try a bunch of different variations on forks, I think there's a lot of ways to skin this cat.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 08-29-2012, 02:06 AM   #14
syzygy9
syzygy9's Avatar
Oddometer: 300
.70s?? really
I am struggling to see how an increase form the stock 0.48 to 0.70 is required. I had my own (2011 990 Adv) forks resprung to 0.56 with a revalve to suit - that's an ~17% increase in spring rate and it seems fine for my 85kg 'naked' + gear + load.
On a recent trip across Australia with lots of fast and slow dirt roads (and some really gnarly sections) I am not aware of ever bottoming the forks but did use all of the suspension travel. Front and rear were set to 'max payload'; with no load this setting feels quite stiff.
I am no suspension guru so happy to defer to the experts, but my understanding was that if you are using all of your travel and not bottoming, you're pretty close to the mark. Of course, if all you are doing is riding on smooth roads than compliance may not be your primary concern, rather things like fork dive under braking, and you can get away with much stiffer and less compliant forks.
__________________________
bikeless no longer! welcome home, 2011 KTM 990 Adventure!
syzygy9 is offline   Reply With Quote
Old 08-29-2012, 02:57 AM   #15
Alex_RO OP
Wanderer
Alex_RO's Avatar
Oddometer: 206
Well.. there's no way I'm ever going to be under 200 pounds (hell, i might go back to 280 if i leave the exercise/diet thing) and i do end up on the slab a lot (i still wouldn't call romanian roads smooth). Might as well accept it and prepare for it. Either way, slab or offroad, it's still underspung.
Now, I *might* have a way to send the forks to SPS without paying an obscene amount for shipping but it's not something definite so ... might as well learn as much as possible.
Thank you, Alex
Times are GMT -7.   It's 04:49 PM.
