Old 08-28-2012, 07:02 PM   #16
JeffS77
cheap bastard
JeffS77's Avatar
Oddometer: 3,371
Did you ever check the points are set properly ?
JeffS77 is offline   Reply With Quote
Old 10-09-2012, 04:40 PM   #17
WitchKing OP
WitchKing's Avatar
Oddometer: 56
Aha! After taking off the side cover, I found the nut to hold the rotor missing. Ordered a new one, put it on, kick, no spark. Disconnected both wires for the kill switch, still nothing. So next is the points. Anybody know the correct gap?
Sure it's quiet, for a diesel. But that's like being well-behaved... for a murderer.
-Jeremy Clarkson
WitchKing is offline   Reply With Quote
Old 10-11-2012, 06:42 PM   #18
bmwdon75
Street Adventurist
bmwdon75's Avatar
Oddometer: 199
Points gap .012-.016
Plug gap .025
From this source http://en.allexperts.com/q/Motorcycl...lsinore-MT.htm
Hope this helps.
bmwdon75
K75s
bmwdon75 is offline   Reply With Quote
Old 10-13-2012, 12:38 AM   #19
Hunsta
Have guns will hunt
Hunsta's Avatar
Oddometer: 5,458
Originally Posted by stainlesscycle View Post
if it stays sparking like a sparkler when you're not kicking it, let us know
Is it me or did anyone else think this was a wind up.
I REALLY AM A NICE GUY. JUST ASK ANYONE WHO HASN`T MET ME.
Hunsta is offline   Reply With Quote
Old 10-13-2012, 11:27 AM   #20
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,257
Ok wait. The stator is screwed onto the engine case, it holds the three primary coils and the points. The flywheel (or rotor) is held onto the crankshaft via a single nut. I'm guessing you mean the nut for the flywheel was loose. Was the flywheel loose? If so, you may have sheered the flywheel key. The flywheel needs to be "clocked" to a particular position by that key. You should need a flywheel puller to get the flywheel off to access the points. Did you change the condenser? You can use a condenser off of just about anything.
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline   Reply With Quote
Old 10-14-2012, 02:43 PM   #21
WitchKing OP
WitchKing's Avatar
Oddometer: 56
Pissed
News flash (literally). I got spark! But only once. I widened the gap, and kicked over, and it sparked the first time, but after that, nothing. What does this mean?
Wk
-Jeremy Clarkson
Old 10-15-2012, 01:52 PM   #22
JeffS77
cheap bastard
JeffS77's Avatar
Oddometer: 3,371
the key was still in after you noticed the flywheel nut was loose ?
Old 10-15-2012, 03:25 PM   #23
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,617
Are you using an old plug? If so try a new one, if that doesn't work try a new condenser.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is online now   Reply With Quote
Old 10-15-2012, 03:31 PM   #24
WitchKing OP
WitchKing's Avatar
Oddometer: 56
No. I didn't mention a few steps. The key was sheared, so I replaced that too. And while I'm at it, the threads where screwed up ( pun intended) so I cleaned them up with a chaser. I also replaced the spark plugs and the condenser is part of the ignition coil.
-Jeremy Clarkson
Old 10-15-2012, 03:48 PM   #25
JeffS77
cheap bastard
JeffS77's Avatar
Oddometer: 3,371
on your bike the condenser is up by the coil but it is still replaceable .
Old 10-25-2012, 06:17 PM   #26
WitchKing OP
WitchKing's Avatar
Oddometer: 56
I know, i meant that a new one came with the coil.
-Jeremy Clarkson
Times are GMT -7.   It's 09:39 PM.
