Old 03-07-2012, 07:38 PM   #1
vuganeja OP
Oddometer: 72
Vario Top case: Common for 650/800 twins and 1200 GS?
Folks,
is it true that a vario top case is the same for a F650/800gs twin and a 1200gs? Only the mounts differ?
I'm trying to buy a vario top case for my 2009 F650gs twin and any help/guidance will be appreciated.
here is the fleamarket thread. thanks in advance!
http://www.advrider.com/forums/showt...7#post18163087
vuganeja is offline   Reply With Quote
Old 03-08-2012, 02:57 AM   #2
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,345
Part fisch for both parts at below links.
The Vario for the twins sells new for $585.
http://www.maxbmwmotorcycles.com/fic...6&rnd=03252011
On the 1200s, it sells for $675.
He's asking $525. Why not just got spend the extra $50 bucks and buy the brand new one that you will know fits your bike?
BlastOff Adventures
Nothing (ad)ventured, Nothing Gained
Everything you want is on the other side of fear.
Dorito is offline   Reply With Quote
Old 03-08-2012, 03:37 AM   #3
GH41
Oddometer: 822
I can't verify fitment but the boxes don't look the same. I am comparing the pictures in the ad to my bike as I type. I gurantee you the rack and hardware will not work on your bike. The seller's asking price is fair. Probably less than 1/2 replacement cost. GH
GH41 is offline   Reply With Quote
Old 03-08-2012, 05:30 PM   #4
vuganeja OP
Oddometer: 72
will buy new.
Thanks. Looks like I'll go the new case way.
I've been looking for a used set for 3 months now, and not one posting!!!!
Old 03-11-2012, 01:10 PM   #5
DaneelOlivaw
Irv Seaver BMW; Parts Mgr
Oddometer: 439
Case differs only cosmetically.
F-twin is black plastic.
RGS is metal-clad.
DaveTownsend@IrvSeaverBMW.com
714-532-3700
DaneelOlivaw is offline   Reply With Quote
Old 03-17-2012, 08:54 AM   #6
Hicks
der Überluber
Hicks's Avatar
Oddometer: 457
12GS vario topcase is imho MUCH bigger + that metal plate.
R1200GS 2013 LC, F800GS '08 (130 000+km)
.de + .at + .it + .sk + .pl + .hu + .li + .ch + .fr + .es + .p + .and + .lu + .be + .nl + .uk + .sco + .ork + .slo + .hr + .bih + .srb
Hicks is offline   Reply With Quote
Old 03-30-2012, 06:21 PM   #7
IQm3
IQm3's Avatar
Oddometer: 28
Basically they are the same.
The VARIO for the Twins is all black and for R1200GS has the aluminum top. The mounting base is also different.
You can fit the 1200 to any of the Twins as long as you have to proper base.
That’s it!
IQm3 is offline   Reply With Quote
Old 03-31-2012, 01:22 PM   #8
Hicks
der Überluber
Hicks's Avatar
Oddometer: 457
That’s it!
doubt that... will research ;)
Old 08-30-2012, 08:38 AM   #9
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,790
OEM Topcase Options
Since there is some debate here, and we all like pics....this post should end it!
Both of our bikes have had the 1200GS topcases installed. One is the 658 and the other an 800GS. Install the OEM topcase mount for your twin and either of the topcases will fit. The early 1200 topcases used to crack at the rear mount and often departed for a trip of their own. I bought 2 1200 topcases for $50 complete with road rash. I installed two bolts on the rear to permanantly fix them in place. So if you're buying the 1200 case, make sure you look at the rear latch area for cracks unless it is the later modded version. Don't have a pic of my crack
You can also mix and match provided you install the proper mount.
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Times are GMT -7.   It's 09:49 PM.
