Old 10-22-2005, 01:55 PM   #1
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,912
New Ohlins on my R100GS, what is the correct ride height?
It's on and I love it... problem is I am confused about setting the correct ride height. Got it from Ohlins USA who did the initial set up with the correct spring.
Here's what I have currently:
Free Sag 30.2mm (this is what the MX/Offroad spec says it should be)
Ride Height 60.3mm MX is spec'd at 100mm +/- 5, and offroad is spec'd at 30% of the total stroke. My manual says the total stroke in 80mm, so 30% would be 27mm, which is less than the free sag?????
HELP!!!!!! what is the correct (or what works for you) in the free sag and ride height department??????????????????
SL
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 10-22-2005, 04:37 PM   #2
deerslayR
Spodely Adventurer
deerslayR's Avatar
Oddometer: 3,028
SL
Could you be confusing shock stroke and wheel travel?
The shock "stroke" may be 80mm butt your wheel travel over the same
80mm may be 275-280mm due to the angle of the shock mounting.
Just a thought.
deerslayR
PS
I set my weighted sag a bit less than 4". Prolly 3 1/2" 'coz I like a bit stiffer
ride.
AMA 'MOA
ECEA 'RA
ARRA DHMC
TCSMC: teamhammer.org
"I'm a choker!" ask me how
"They're ALL dirt bikes.....some work better than others"-----Harley Huey
deerslayR is offline   Reply With Quote
Old 10-23-2005, 02:01 PM   #3
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,912
Thanks DS,
point well noted about wheel travel versus shock travel, hence my confusion.... guess I'll call Ohlins in the morning.
My weighted sag is 60mm which is ~2.4 inches... your 4 inch sag works out to be 101.9mm (25.4 mm's per inch) which is what Ohlins suggests for an MX shock.
I'll post what Ohlins says.
SL
Originally Posted by deerslayR
SL
Just a thought.
deerslayR
PS
ride.
R65LazaruS
Times are GMT -7.   It's 04:07 AM.
