Old 06-09-2009, 10:31 PM   #31
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,613
I am sure the cases could leak into the bottom of the combustion chamber and reek RPM havoc.
Have you gone to Kawasaki triples worldwide . com ?
http://www.kawasakitriplesworldwide....pBB2/index.php
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is online now   Reply With Quote
Old 06-10-2009, 05:07 PM   #32
P B G
Oddometer: 10,001
Did you let the sealer set up before firing it up?
Old 06-11-2009, 10:15 AM   #33
Tundra Tom OP
XLR8
Tundra Tom's Avatar
Oddometer: 63
I did but used the red high temp. silacone rather the recommended 3 bond 1194 which I now have a tube of (of course). Yeah, the triples site is a weath of info. The kick started was never wound right on the spring.
The K3 site had links to photos etc. on the proper install.
I've got sooo much on my plate right now pulling the motor again will have to wait. Hey...it starts with a couple kicks at least!
"When my time has come I prefer to be in the Saddle, rather than the Recliner"
2008 Suzuki Bandit 1250SA / 1999 BMW F-650
1975 Norton 850 Commando / 1974 Kawasaki 500 H-1
And yes I ride all four
Tundra Tom is offline   Reply With Quote
Old 06-11-2009, 01:06 PM   #34
P B G
Oddometer: 10,001
You've seen this bike right?
Old 06-11-2009, 01:15 PM   #35
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,511
That looks like a Norton tank.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 06-11-2009, 01:21 PM   #36
P B G
Oddometer: 10,001
Roughly but the knee portion is more contoured than the norton.
iirc it was a custom aluminum jobber.
http://www.hotrodhomepage.com/hrhp/2...00-wh2-engine/
Old 08-14-2012, 12:43 PM   #37
Tundra Tom OP
XLR8
Tundra Tom's Avatar
Oddometer: 63
Believe it or not I got the H-1 running...again. Turns out it had the wrong coils in it hence the magic smoke coming out of them.
Also replaced all the points with new. I was always kind of underwhelmed by the power considering all the hype with the triples. Well now it have a MUCH better spark and hence at 7500 rpm it sounds like three chain saws running WFO and is now far too fast for the chassis and cheesy brakes...as it should be. Not to mention the dry rotted tires....hmm better order up some new tubes and skins....
Tundra Tom screwed with this post 08-14-2012 at 02:04 PM
Old 08-24-2012, 08:48 PM   #38
anonny
anonny's Avatar
Oddometer: 5,613
Did you set the timing with a dial gauge? How many degrees before TDC?
Old 08-25-2012, 04:33 PM   #39
Twin-shocker
Oddometer: 1,673
Replace all 3 condensers, as having the wrong coils fitted will almost certainly have damaged them. Pressure test the motor before stripping it, as this will determine exactly where the leak is, and will save an awful lot of work.
You will also find that bikes pretty dangerous in the turns, as moving the shock mounts and fork tubes, will have reduced ground clearance quite a bit, and will mean center stand, pipes, and footrests will all ground out very easily.
Old 09-04-2012, 02:29 PM   #40
dan-c
Back
dan-c's Avatar
Oddometer: 13,689
I thought the H1's were always CDI . Seem to remember the little lightening bolt under the CDI badge on the old refrigerator white tanked ones.
dan-c is offline   Reply With Quote
Old 09-04-2012, 02:41 PM   #41
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,330
They were, even the 69 said Electric on the side cover meaning CDI. He is talking about replacing the pick up coils on the CDI he refers to them as condensers.
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 09-04-2012, 02:54 PM   #42
dan-c
Back
dan-c's Avatar
Oddometer: 13,689
I was kinda thinking that until I read this:
Cleaned the points and checked gap.
Old 09-04-2012, 02:56 PM   #43
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,330
yeah, that's odd right there. But there is a gap, an air gap on those pick up coils.....and they can be cleaned.
Old 09-04-2012, 03:00 PM   #44
dan-c
Back
dan-c's Avatar
Oddometer: 13,689
Yep just like the pick-up on my Lawn Boy
Old 09-04-2012, 03:28 PM   #45
Twin-shocker
Oddometer: 1,673
H1A had CDI system, HIB points, and all the subsequent KH bikes CDI
Times are GMT -7.   It's 11:08 PM.
