09-08-2012, 10:45 AM
#16 |
terrorist
In just the H2W set up?
Or in the CPR set up? or in any setup to get the most out of the carbs? and then where would one source a different needle? Heading out now to run in the 165's and see the plugs look........
mountain eagle 08'Husky TE610 = everything a KLR want's to be 07'KTM950SE, my smugmug gallery How can it be fun if there's not at least an outside chance of dying? |
09-08-2012, 02:59 PM
#17 | |
Oddometer: 2,145
I still cannot understand why a snorkel that has larger inlet area than the carb inlet can restrict the flow (as far as top power is concerned) it makes no sense to me. I don't dispute anybody's experience, but it is a mystery to me nevertheless. |
09-09-2012, 06:02 AM
#18 | ||
I <3 Energizer Bunny
Oddometer: 555
I tested airjet combinations on k&n pods...back in '07. I know what I came up with on the dyno, real world, and through the use of an onboard o2 meter...after many hours and many different settings. YRMV
Yet Another New Air Filter for the KTM 950 - $150 |
09-09-2012, 06:37 AM
#19 | |
Oddometer: 2,145
For the record, 950SE Jetting is H2W sans prefilter with snorkel, stock airfilter/airbox and 160/165 mains Akras with large inserts 30C @ sea level Nothing lost compared to prefilter setup gained a bit power on top of the rev range. mousitsas screwed with this post 09-09-2012 at 06:57 AM |
09-09-2012, 09:05 AM
#20 |
terrorist
FP version? What's FP?
09-09-2012, 01:14 PM
#21 |
Oddometer: 277
FP = factory pro
09-09-2012, 03:20 PM
#22 | |
Oddometer: 555
09-09-2012, 03:54 PM
#23 | |
Unwounding
Oddometer: 4,318
Moose, sounds like my experience with the K&Ns. Good for you. Ken's advice to me was that the bottom stuff should be close and the mains very lean. Exactly my findings and the bike carburated far better with a snorting pull to the limiter with the 170s or thereabouts. I expected to need to rejet everything over and over but the mains really did the job.
09-09-2012, 10:26 PM
#24 | |
Oddometer: 2,145
By the way, had a longer ride yesterday, actually low end and midrange might as well be stronger than the prefiltered setup and also smoother, definitely more crisp. No vibes anywhere. The trick with H2W is not the prefilter....it is the bottom jetting. I sense you want to prove that something which is not rocket science actually is. Similar to the 'you need vacuum' for crisp throttle response fixation going on for years in advrider, an opinion widely popular within 'the experts' mousitsas screwed with this post 09-09-2012 at 10:38 PM |
09-09-2012, 10:35 PM
#25 | |
Oddometer: 2,145
09-10-2012, 07:47 AM
#26 | |
Oddometer: 555
Guy, I was trying to help you... Thats ok. Ride your own ride. FWIW, as I indicated in an earlier post, I did a tremendous amount of r&d with this, and with an onboard wideband too. I have ran what you are running, I have logged the results from sea level to 6000'. I know exactly whats going on with your mix, and what the airjets are doing to the midrange, which ones give the better results and which ones don't. Cold hard numbers, not a butt impression... Here's the problem as I see it. There is no shortage keyboard genius know it all's that will post as an 'expert' to every thread regardless if they happen to have a clue or not. Some do it so long around here that they actually pick up a shred of knowledge which reinforces their self image as bike guru extraordinaire. Thing is though, without a background of real experience or professional education in this stuff, these guys are often wrong, misleading and post information that's unhelpful to the reader faced with picking out a hidden nugget of gold in a mountain of obfuscated cow shit. I'm only posting information I know to be factual, writhed from 6 years experience with these carbs and 30+ years of tuning and development. From your posts, you're saying that you bumped your mains, put the snorkle back on and viola, its just peachy now. That's great! Consider this, you may have had a fat girl with a sloppy gash...traded her in on one a little better looking, but still a little heavy and her tits not so big, and think you're on the top of the world now. Paulina Rubio came knocking at your door and you aren't answering, because you're elbow deep in bed with this chunky A cup girl who you've convinced yourself is the best you can ever do. You hear the knocking, she's right there and you're yelling through the door, 'Fuck off, this isn't rocket science. You experts were all wrong'. She turns around and leaves you to your chubby lover, muttering, 'WTF is this guy talking about...why do I even bother'.
09-10-2012, 08:10 AM
#27 |
Oddometer: 204
What would be the optimum jetting for my mostly stock SE950. 2 into 1 pipe with an Acra silencer with spark arrestor. All pollution equipment removed and needles moved up one clip position. I get no popping on deceleration but it only gets about 30 mpg. How many turns out should the fuels screws be set at? The bikes runs very well as is but goes through a lot of gas. Thanks, Bruce
09-10-2012, 08:12 AM
#28 | |
Oddometer: 2,145
![]() Point is that cool hard numbers have nothing to do with what we are talking about. For me in jetting, all I want numbers for is when it comes to mains to not run lean (or very rich) on the top end. But KTM did the work for us here, by setting the ballpark. Also you and H2W and K2M did a lot of wideband work, I acknowledge that and gave us a nice running low-midrange. From there on I really don't think I need any numbers, I only rely on my feeling of what a nice running engine should be like. And if the two are in dispute, I would always tune to what feeling is telling me. |
09-10-2012, 08:14 AM
#29 |
terrorist
Fat girls need love too..............
09-10-2012, 10:44 PM
#30 |
Oddometer: 277
Thank you all, a lot of valuable information!
As a conclusion, I thought about following setup going from H2W prefilter setup to CPR filter when it arrives: Main Jets 175/175 front/rear Idle Air Jet 50 Mixture Screws 2 turns Float Level 4mm install Factory Pro needles (I have FP kit), 3rd clip? Did I miss anything? |
