Old 07-30-2012, 08:24 AM   #1
mouthfulloflake OP
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,277
Another Bosch fuel pump 69222 installed
replaced the fuel pump in my 1995 r1100gs recently.
pump is $65 from advance auto part number 69222
$20 coupon code ES123
$49 with tax
fits well, much quieter than stock, lifetime warranty even!
replaced fuel filter in tank also, was BMW part date coded 2003, it would drip fuel from the input, but not from the output, I think it was clogged.
also bought some 5/16" brake line at the auto parts store and bent a "U" shape to replace the $32 BMW rubber hose.
all in all its working well, bike no longer pings like it was, I do think it was starving for fuel for the last couple of years ( and getting progressively worse)
currently I have gone back to the stock rose colored CCP, and removed the Ice II air device, to get a new baseline to experiment with.
thanks to Vintagerider, Roger_04rt, crackhead, poolside, JJ and everyone else that has taken the time to document, and share the knowledge on here!
Tilt your head, not the taco. - Pati Jinich
Charter member: T.O. club.
mouthfulloflake is offline   Reply With Quote
Old 07-30-2012, 11:06 AM   #2
vintagerider
vintagerider's Avatar
Oddometer: 1,963
Keep your suction screen receipt to validate the lifetime warranty. Great maintenance for just about all 11xx out there at this point. An ounce of prevention...
They are small enough to carry as a spare if venturing off to the dark continent. The Bosch kit is likely to be discontinued as the cars for which they are designed become obs. Not a bad idea for inmates to pick one up now, especially at this price and while still available.
edit: Ordering tips: Rockauto.com great to deal with. 30 day Rock warranty plus Bosch warranty. If ordering from Advance then you need the a "car" application. Read the terms of Adv "lifetime warranty" carefully. If carrying as a spare where oem is installed then carry Posi-Lock barrels. Soldering on the supplied pigtail socket plug to the pump plate is obviously preferred but Posi-Lock barrels should work as they are nylon (not tried). As already noted, the suction screen for the 69222 has a different attachment than the oem screen. Be sure to order one.
durability: These are lightweight pumps. Have not experienced any failures but carrying a spare is reasonable because of the lower weight and size. Carry in air-tight tube to prevent bearing corrosion. Lower current draw is another advantage.
vintagerider screwed with this post 09-11-2012 at 11:41 AM Reason: ordering tips
vintagerider is offline   Reply With Quote
Old 07-30-2012, 03:44 PM   #3
Hootowl
Oddometer: 1,262
My 1100GS is running stronger since fitting the Bosch fuel pump
Keep it Wild, Keep it Free
'07 990A
'12 Super Tenere
Hootowl is offline   Reply With Quote
Old 09-09-2012, 06:30 PM   #4
blues_bleu
Oddometer: 144
[QUOTE=mouthfulloflake;19245453]replaced the fuel pump in my 1995 r1100gs recently.
$49 with tax
[/QUOTE
Hi guys, wanna check where can i get those pump with lifetime warranty??
there seem to be limited shop selling it.
also is the warranty goes for a 1 to 1 exchange is the pump is screw up of there are other term and condition???
thanks!!
blues_bleu is offline   Reply With Quote
Old 09-09-2012, 11:22 PM   #5
R1100purist
Which way is north?
R1100purist's Avatar
Oddometer: 151
Hmm where did you find the one for $44
Going to that website, the only one I could find was for $73 even after the discount code? Here:
http://shop.advanceautoparts.com/web...222&showTitle=
Am I missing something?
R1100purist is offline   Reply With Quote
Old 09-10-2012, 08:43 AM   #6
mouthfulloflake OP
Not afraid
Oddometer: 17,277
I just checked, apparently the price increased
the pump is now $80 , it was $65 when I bought it
code ES123 still gets you a $20 savings though.
not sure why its more for you, possibly location makes a difference?
here is a screen capture that I just looked up.
Old 09-10-2012, 10:34 AM   #7
RFK
Oddometer: 117
Check the site again over the next few days and the price may drop back to $65. I came across this a few weeks ago and the price was 84.99 for 2 or 3 days... checked again and it was back at 64.99.
RFK is offline   Reply With Quote
Old 09-10-2012, 01:41 PM   #8
blues_bleu
Oddometer: 144
Looks like they are trying their luck...... or someone is behind this!!!
Old 09-10-2012, 02:21 PM   #9
R1100purist
Which way is north?
Oddometer: 151
haha I'm ready for conspiracy theories!
Okay thanks guys, I will book mark that and keep my eye open!
Old 09-11-2012, 07:46 AM   #10
picinisco
Scottish Transplant
picinisco's Avatar
Oddometer: 482
Autoparts123.com has it for $63.50 with free ground shipping.
Cheers...John - 2004 BMW R1150GS, 1978 R100 (G/S Frankenbike)
Bikes That have Moved On:
1978 Suzuki GS550E, 1978 Kawasaki KZ1000P, 1982 Honda XL500R, 1995 BMW R1100RSL
picinisco is offline   Reply With Quote
Old 09-12-2012, 04:12 AM   #11
blues_bleu
Oddometer: 144
does anyone has any coupon for this pump??
Old 09-12-2012, 02:04 PM   #12
RFK
Oddometer: 117
Another option...
I came across this deal on Ebay... it's actually $3 cheaper than the Advance Auto deal when you factor in the tax and shipping. When I got mine from advance, it came to $58.59 shipped to my door. I just picked up one from this ad for a spare tank project I am doing.
http://www.ebay.com/itm/Bosch-69222-...16%26rk%3D2%26
Old 09-12-2012, 02:29 PM   #13
blues_bleu
Oddometer: 144
Laugh
but this one only has a six month warranty
Old 09-12-2012, 02:42 PM   #14
RFK
Oddometer: 117
I still have the warranty from Advance for the first one I got... I'm covered. The rest of you slackers will have to roll the dice
Old 09-28-2012, 06:35 AM   #15
blues_bleu
Oddometer: 144
hi guys, i have found something for the R1100gs.
but i dunno if this is the perfect swoop from the original pump.
can any expert help me with it.....
http://www.highflowfuel.com/i-892781...1995-2004.html
price wise is still not to expensive as they will provide free shipping within US.
and best of all, it comes with the lifetime replacement warranty.
i think this will gives us a peace of mind!!!!
maybe we get in bulk, there might be some discount.......
who know.....
Times are GMT -7.   It's 06:17 PM.
