Old 09-10-2012, 10:14 PM   #1
ked OP
Oddometer: 350
DL650 sluggish turning question
1st time ever, i rode a 2006 DL650 today and was surprised at the resistance to turning at slow speeds. seemed like it didn't want to turn! nothing wrong with the bearings, just met with resistance. is this due to the "high center of gravity"?
my g/s seems so effortless in slow speed turns.
ked
If a man speaks in the woods, and a woman is not there to hear it, is he still wrong?
ked is offline   Reply With Quote
Old 09-10-2012, 10:52 PM   #2
greywolf
Unpaved road avoider
greywolf's Avatar
Oddometer: 993
Does it have a fork brace? I didn't realize it made a difference at slow speed until a Montrose CO police motor officer and his instructor declared their DL650 a whole new bike after doing a few figure eights in a parking lot after a brace was installed. Lowering the front by raising the fork tubes 10-15mm also makes steering quicker and prevents high speed aerodynamic lift by the fairing.
Pat
in order of ownership
1971 Honda CB350, 2 1973 Honda CB500s, one was stolen, 1974 Can-Am 175 TNT, 1978 Yamaha XS11, 1978 Honda CX500, 1975 BMW R90S, 1983 BMW R65LS, 2005 Suzuki DL650 totaled, 2007 Suzuki DL650A, 2012 Suzuki DL650A
greywolf is offline   Reply With Quote
Old 09-10-2012, 11:03 PM   #3
Jamie Z
Jamie Z's Avatar
Oddometer: 7,710
Do you know which tires?
I know when I first installed a Shinko 705 front tire the steering felt quite a bit different. Worn tires of any type could have that effect, too.
Jamie
I'm the Tent Space Guy Sign up to host fellow travelers here.
Budget Travel the Jamie Z Way
Jamie Z is online now   Reply With Quote
Old 09-11-2012, 01:21 AM   #4
PeterW
Oddometer: 2,663
So do tyres that are seriously underinflated.
If it was a 'dealer bike' - low tyres is likely.
My 06 DL certainly had a worse turning circle than my old F650, but it wasn't noticeably 'bad' in comparison, you just needed a bit more width to make a tight turn.
Pete
PeterW is online now   Reply With Quote
Old 09-11-2012, 03:36 AM   #5
Pecha72
Oddometer: 4,059
+1 on checking tyre pressures. But if its the OEM Bridgestones you were riding with, then it'll never feel very good, until you fit.. well, pretty much any other tyre
Pecha72 is offline   Reply With Quote
Old 09-12-2012, 10:29 AM   #6
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,794
ked
A full tank of gas kills handling. It is heavy.
Hate gets you nowhere.
Old 09-12-2012, 10:31 AM   #7
pjm204
Oddometer: 2,000
I know on mine the handling is very sluggish because the steering stem bearings are toast. Hopefully my new ones arrive this week.
Current bikes:2006 DL650
Past bikes: 2008 WR250R, XT225, TTR125, '04 CRF50 '74 DT125,'70 TS250,'85 v45, '89 zx600c, '78 GS400x, '99 GS500E, '01 GS500E '05 Z750s, '77 GS400e, '82 GS1100ez, '97 GSX600, '07 VFR800, '03 KLR650, '03 FJR1300, '06 DL1000, '00 KLR650, '99 WR360, '08 DL650, '05 DR650, '08 EX650r, '96 CR500, '82 GS450T, '06 Ural
pjm204 is offline   Reply With Quote
Old 09-12-2012, 12:52 PM   #8
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,192
everyone gave you good ideas to check.
One more thing might be if the rear is lowered at all. It seems pretty common for people to lower the rear or take all the preload out of the rear shock and that kills the handling too.
My real bet is on underinflated tires though. Its amazing how many people don't check their tires and some shops are horrible about this too.
A well setup strom actually handles very well and drops into the turns just fine.
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning screwed with this post 09-12-2012 at 01:42 PM
BlueLghtning is offline   Reply With Quote
Old 09-12-2012, 01:31 PM   #9
devo2002
-Devo
devo2002's Avatar
Oddometer: 3,878
Something's off if there is resistance, I've never felt any. Every other used bike i go to test ride has under inflated tires that throws handling and response out the window.
2014 DL650 Vstrom
devo2002 is offline   Reply With Quote
Old 09-12-2012, 04:00 PM   #10
Jamie Z
Jamie Z's Avatar
Oddometer: 7,710
Did we lose the OP?
Old 10-26-2012, 06:22 AM   #11
ked OP
Oddometer: 350
Originally Posted by Jamie Z View Post
Did we lose the OP?
LOL! no, you didn't lose me. it was the tire pressure.
thanks guys, ked
Old 10-28-2012, 10:54 AM   #12
Goran69
MNE
Goran69's Avatar
Oddometer: 838
Fork brace does not have anything to do with this....and yes I do recommend it...after installing you are riding a different bike...
Fuel tank is higher..maybe higher then other bikes but that also is not a problem.....so it had to be tires...
But then again I always check tires before riding...especially someone else s bike
Goran69 is offline   Reply With Quote
Times are GMT -7.   It's 12:03 AM.
