Old 09-11-2012, 08:13 AM   #931
grndzr0
its Ground Zero
grndzr0's Avatar
Oddometer: 601
Originally Posted by vanbc View Post
I've outgrown the twin F650 GS.
What mods can I get done to the bike vs. getting a bigger bike?
She is okay for around town but on the open highway I'd like something that isn't maxing out.
sprockets? can the chip be upgraded?
thank you.
A power commander, and exhaust and opened up intake can help for a FEW extra HP. There is a thread on here about Touratechs build they did on an F8 and I think they cut open the top of the air-box cover. I believe I read somewhere (hey, its the internet!!) that most of these mods need to be done in conjunction with each other for them to have much effect.
You could put taller gears on it for the highway, but your acceleration will suffer.
Ryan
2010 F800gs (Mine) 2011 F650gs (Wifes)
grndzr0 is offline   Reply With Quote
Old 09-11-2012, 08:52 AM   #932
grndzr0
its Ground Zero
grndzr0's Avatar
Oddometer: 601
Originally Posted by 4TooMany View Post
I was going to, but I don't like the BMW crash bars. I put SW-MOTECH crash bars on it 3 days later.
My dealer sold SW Motech
Also, Just an FWI for other riders that might be interested, I bought my bike out of state by a few states, and mailed my skid plate as well as a few other farkles to them and they installed them for a very reasonable price. I had a long trip home after picking up the bikes and didnt want to take the risk
Also, Th 650 uses 7/8 in bars, so I found some renthal/pro tapers in the $60 range, so they should work well. Ill post up some picks when I get them in.
Ryan
Old 09-12-2012, 12:45 AM   #933
LukasM
Oddometer: 5,426
thank you.
What do you mean by "maxing out", are you running out of revs or out of power to pull to the limiter?
A free flowing exhaust system and a Power Commander to inject more fuel would be a good start.
Old 09-12-2012, 05:21 AM   #934
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,209
Originally Posted by Sutherngintelmen View Post
I bought these for my f8gs when my bars absorbed too much energy.
And stupid questions get stupid answers.
Crash bars - yep, go buy SW MOTECH.
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 09-12-2012, 05:49 AM   #935
grndzr0
its Ground Zero
grndzr0's Avatar
Oddometer: 601
You must only prop yours on flat ground
Old 09-12-2012, 06:25 AM   #936
JRWooden
Oddometer: 4,289
I ordered speedbleeders but have yet to install them. just a thought if the OP does replace them.
About a year back I wanted to get a set of speedbleeders but they only had the size for the calipers and didn't have a little one for the master cylinder (required for ABS only). Do they now have the smaller sized one? If so I'm writing someone a check!
Old 09-12-2012, 06:28 AM   #937
JRWooden
Oddometer: 4,289
Originally Posted by grndzr0 View Post
Anybody know of some cheap aftermarket bars that fit the 650 twin? Or does anybody have some stock F8 bar mounts they want to get rid of?
Wife took a spill or 2 this weekend, and her bars are looking like they belong in a Dr. Sues book.....
Ryan
As someone mentioned Renthal makes some bars that will work, you may have to drill/tap some mounting holes.
Also note that the bar diameter of the F800GS bars is larger than than those on the F650GS 28mm vs. 24mm or something like that ...
Old 09-12-2012, 06:53 AM   #938
pkbinder
Kissing Moose
pkbinder's Avatar
Oddometer: 283
Semi-noob needs help
Another embarrassing moment.
I put my rear wheel back on after changing my tire. I am fairly certain I have all the spacers, washers, absorbers and the sprocket lined up. When I torc down the axle nut I CANNOT move my rear wheel, it will not turn at all, WTF. I tried 3 times with the same result and consulted the MAX BMW fiche to make sure things were in order. It isnt the brakes shoes because I stretched them out and they were not binding. HELP! Paul
Life is suffering until you realize that life is suffering.
pkbinder is offline   Reply With Quote
Old 09-12-2012, 07:46 AM   #939
grndzr0
its Ground Zero
grndzr0's Avatar
Oddometer: 601
I would pull everything apart, and just look everything over really good. Make sure your wheel bearings are spinning ok and feel good, and double check that all of your spacers are in the correct places in the right directions. Also check to make sure you didnt bend your brake rotor.
Ryan
Old 09-12-2012, 11:07 AM   #940
pkbinder
Kissing Moose
pkbinder's Avatar
Oddometer: 283
Thanks Ryan. I'll double check everything and especially the brakes. Paul
Old 09-12-2012, 06:28 PM   #941
pkbinder
Kissing Moose
pkbinder's Avatar
Oddometer: 283
It was a spacer. I was spaced out. Paul
Old 09-12-2012, 08:14 PM   #942
xxxshiftxxx
Oddometer: 207
Coming to a stop
So, sometimes when I am comming to a stop, at a stop sign for example, I notice a slight vibration in the bars right before I come to a complete stop. feels like something is lose and moving back a forth...
Any ideas?
xxxshiftxxx is offline   Reply With Quote
Old 09-12-2012, 08:41 PM   #943
ebrabaek
Oddometer: 4,804
Any ideas?
Do you have the 20mm tt bar raiser blocks??????
Erling
ebrabaek is online now   Reply With Quote
Old 09-12-2012, 09:01 PM   #944
xxxshiftxxx
Oddometer: 207
No, suspension, bars, and brakes are completely stock. 2010 with 7k miles....
Old 09-13-2012, 08:39 AM   #945
grndzr0
its Ground Zero
grndzr0's Avatar
Oddometer: 601
What tires are you running?
Ryan
Times are GMT -7.   It's 01:05 PM.
