Old 09-13-2012, 10:20 AM   #721
BeerTownGS
Oddometer: 42
Quick and dirty shift lever rubber pad repair
Riding home the other day I started having trouble finding neutral and it felt like the shift lever rubber was rolling on my shoe. Sure enough, it had split most of the way across.
Not having a spare I started digging through the garage for something suitable to get me by and viola, I now have a use for the 1" heat shrink tubing that came in the 5 pack form Harbor Freight.
Cut to length and slips right over the rubber, shrink with a lighter and good as new. I think I'll carry a extra precut length under the seat in case a roadside repair is needed in the future.
BeerTownGS is offline   Reply With Quote
Old 09-13-2012, 05:27 PM   #722
sp600
Oddometer: 59
Wink
Saving to read later.
sp600 is offline   Reply With Quote
Old 09-19-2012, 06:55 PM   #723
scout18
scout18's Avatar
Oddometer: 939
Wow took a while but I got through it. After all this It seems my first task is to work on that sloppy rear wheel on my 74 R75 /6
Alis Volat Propiis
scout18 is offline   Reply With Quote
Old 10-04-2012, 10:10 AM   #724
Uncle Pollo
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 48,124
Originally Posted by Zodiac View Post
No changes in carb settings, runs great - but not much heavy riding to test these days, busy planning a sneak attack on the front end soon....
Well ...
Uncle Pollo is offline   Reply With Quote
Old 10-04-2012, 10:51 PM   #725
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,558
That's a good tip. I find a new lever rubber is likely to crack in short time, and your trick might help preserve them.
boxerboy81 is offline   Reply With Quote
Old 10-05-2012, 03:58 PM   #726
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,060
That is a good tip. Also, if you aren't conveniently located to a HF or NT where you can get cheap heat shrink, my ST had appropriately sized heater hose or other water hose type on the toe piece when I bought it.
It actually seemed to hold up better than the BMW rubber I've replaced it with.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 10-15-2012, 07:06 PM   #727
Doug5150
Oddometer: 6
Front Drum Brakes
Anyone have a opinion on replacement front brake shoes for my r75/5?
Doug5150 is offline   Reply With Quote
Old 10-16-2012, 09:52 AM   #728
brocktoon
brocktoon's Avatar
Oddometer: 257
The general opinion I've heard is that EBC and Ferrodo are fine, and may even use the same braking compound re-branded. OEM brakes are better, but more expensive and quality control is sometimes an issue. The best option, but very pricey, is having the brakes professionally re-lined. Vintage Brake offers this service.
brocktoon is offline   Reply With Quote
Old 10-16-2012, 07:35 PM   #729
Doug5150
Oddometer: 6
second good word I've heard about Vintage Brake. I will check them out.
Old 10-25-2012, 08:20 PM   #730
xackley
Oddometer: 6
I replaced the cross over pipe on my R75/5 with a $10 plumbing extension pipe found in the under-sink aisle.
They are 12 inches long, brass inside, chrome outside, 1 1/4 inches in diameter..
I ground the threaded section off of both ends of the extension, never-seized the header and slid them on.
Slide it on further than the original, right up to the welds.
No clamps needed.
Much quieter and prettier than the 7 hose clamps and rusty tin the PO had wrapped around the old crossover.
1958 BMW R69, 1972 R75/5, 1980 Yamaha xs650, 1982 Honda GL1100
xackley screwed with this post 10-25-2012 at 08:29 PM
xackley is offline   Reply With Quote
Old 10-25-2012, 08:29 PM   #731
Les_Garten
Les_Garten's Avatar
Oddometer: 732
No clamps needed.
Brilliant!
You should post a pic of that!
Les_Garten is online now   Reply With Quote
Old 11-08-2012, 08:23 PM   #732
patanga
BMWAirheadsDownunder
patanga's Avatar
Oddometer: 161
Simple technique on speedo cable boot replacement
Just loaded this tech tip on our web page. Thought you guys might be interested. The speedo cable boot is often neglected and is a common source of water contamination in to the gearbox. Easy enough to do for the experts but can be a pain for the less experienced. A quick & simple method. http://rter.co.nz/Airheads/airhead_t...ocableboot.pdf
____________________
"The only reason people get lost in thought is because it's unfamiliar territory" (Joe Garcia)
Check us out on facebook at "BMW Airheads Downunder", (The Australia and New Zealand Airhead Community). "B.A.D"
http://www.facebook.com/groups/anzairheads/
patanga is offline   Reply With Quote
Old 11-20-2012, 06:35 PM   #733
headtube
6 mesas de invierno!
headtube's Avatar
Oddometer: 322
Originally Posted by Les_Garten View Post
Brilliant!
+1 on the pics.
headtube is offline   Reply With Quote
Old 01-02-2013, 03:05 PM   #734
patanga
patanga's Avatar
Oddometer: 161
Spun rear wheel hub repair
Hi folks. Hope you're all enjoying the season. We've just listed a new technical bulletin at our website on the topic of a repair method for spun rear wheel hubs (i.e. early models with bearing stack assembly). If you're interested feel free to check it out. http://rter.co.nz/Airheads/airhead_tech/spun_hub.pdf
patanga screwed with this post 01-02-2013 at 03:12 PM
Old 01-06-2013, 06:42 AM   #735
Jim K in PA
Jim K in PA's Avatar
Oddometer: 1,173
Thanks Patanga. Nicely presented.
Jim K in PA
1979 BMW R100T - Otto - Returned to the road - 5/12/11
1975 BMW R90S Hack - Olga - Olga's story - adopted 3/22/14
Viktor - Coming to a thread near you - eventually
Jim K in PA is offline   Reply With Quote
Times are GMT -7.   It's 10:35 PM.
